Central Florida H E L P
Discussion in 'Gen 2 Prius Main Forum' started by 4-robinsnest, Mar 7, 2011.
  1. bretaz
    bretaz Member
    475
    52
    Surprise, Arizona
    Did the dealer do the recall work? You need to atleast start with that. It isn't going to cost anything.
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,518
    38
    Santa Fe, NM
    That's a good place to start. No sense in doing anything if the 12V is iffy, and the IC pump needs to be replaced anyway. It would also be very helpful to have the individual block voltages read off, V1, V2 ... V14. They should have done this as part of pulling the diagnostic codes. For example, if one of the block voltages is 0, that usually indicates a broken sense wire, while having one of the block voltages 1.2V less than the rest means a bad cell in one module.
  3. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Yes good idea. With so many different codes it would be a good idea to be sure of the 12V battery before doing anything else.
    Robin : Follow my link in reply #12 above and get a voltage reading for the 12 volt battery.
    Also, can you let us know of any driveabilty issue you're having. Does the car lack power and the engine rev a lot? Do you notice rapid swings in the "state of charge" display (the 8 bar purple/blue/green display that indicates traction battery charge). Please list any driveabilty issues you noticed during or leading up to the problems you're currently having.
  4. sub3marathonman
    sub3marathonman Active Member
    557
    75
    The first story I would be interested in is what dealer was the car taken to? An "odd code P0A93," "pretty sure that means that the crankshaft position sensor is showing a malfunction." Is he joking?
    Do a search on this forum. P0A93. Clearly for the Inverter Coolant System Performance. Got it right here on the Advance Auto Parts printout they did gratis. Here is one of 100K other links on the Internet telling about it: Toyota Questions - what does code P0A93 in a toyota prius mean - JustAnswer . If these numbskulls don't know what P0A93 is they shouldn't be mechanics.
    All the other codes, while extremely serious if they were true, are HIGHLY questionable. I would guess that the original battery has never been replaced, and is the culprit. You can get the elearnaid Optima battery and be much better off, if you can do it yourself. Here is the thread on that: http://priuschat.com/forums/gen-ii-...eshooting/90763-need-replace-12v-battery.html . Otherwise you'll have to use the Toyota battery and probably pay an exhorbitant price to a dealer to install it. If you could get the car and either one of the batteries to Bartow I could install it in 10 minutes for you as my good deed for the day.
  5. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    She can buy the battery from the dealership. I think the going rate is about $140. The unknown is how much the dealership will try to charge for the installation.
    Very kind of you to offer to put the battery in. At least for me, the first DIY of most things in the Prius is a bit of a head scratcher, the second time is a breeze and I wonder why I was so slow.
  6. 4-robinsnest
    4-robinsnest Junior Member
    Polk City, FL
    Thanks again to all for your assists.... Here is an update as today is Wednesday since we last connected on Mon/Tue. Today I drove my son's college car the "Tomato" Dodge Neon to the Winter Haven Toyota Dealership with the original hybrid battery in the trunk that was swapped out for the replacement hybrid battery which has all of the error codes from the first report. My Dad found one on e-bay in the Tampa area, my husband & I went to get it and we swapped out the batteries by the Techie sites instructions on the internet. So now- we will have a diagnostic run on the original battery to see if there is any different of an outcome... ? I will post the new report so we can have a comparison on the two batteries and which is better to move forward with . . . Stay Tuned . . . : ) Robin
  7. bretaz
    bretaz Member
    475
    52
    Surprise, Arizona
    Has the recall work been done yet? Did you replace the 12v battery?
  8. SageBrush
    11,627
    2,533
    Southwest Colorado
    I'm stunned. Not electrocuted, but definitely stunned.
  9. sub3marathonman
    557
    75
    No, it can't be.
    So does this mean that instead of changing the 12V battery, which is extremely simple, then getting the Inverter Coolant Pump recall done, which is free, another main hybrid battery was found in Tampa and swapped with the one in the car? So several hundred dollars and probably five hours of work, at least that when you count driving to Tampa and back?
    My opinion is that now you've got two fine hybrid batteries, one swapped into the Prius and the other sitting on the floor of the garage. Time for the BMS+ system so you can use this other battery.
  10. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Ok I'll be interested to hear how it turns out. Make sure you let us know. :)
  11. 4-robinsnest
    Polk City, FL
    O.K. Here it is . . .To all of my local and long distance helpers, I just stopped at the Winter Haven Toyota after my a.m. Physical Therapy appointment and the Hybrid Technician (or so he is called, he seemed very nice though ;) was sitting in the driver seat with a VIO Notebook in his lap hooked up to a cable that was connected to a plug in spot under the steering wheel column. He said he was still running the diagnostics after the original battery was put back in and he says P0A90 is the only error code he is getting, He says he thinks the original battery is definitely the one to leave in the car going forward and will call me this p.m. after he checks some items that might be a side bar error message related to the P0A90. He will call me to let me know what they have ultimately found out. So that is where it stands…. Does anyone know what the P0A90 means . . . ?
  12. 4-robinsnest
    Polk City, FL
    R-e-s-e-n-d-i-n-g just to be sure the earlier post went to the correct Prius Chat Forum, or shall I start a new thread . . . ? O.K. Here it is . . .To all of my local and long distance helpers, I just stopped at the Winter Haven Toyota after my a.m. Physical Therapy appointment and the Hybrid Technician (or so he is called, he seemed very nice though [​IMG] was sitting in the driver seat with a VIO Notebook in his lap hooked up to a cable that was connected to a plug in spot under the steering wheel column. He said he was still running the diagnostics after the original battery was put back in and he says P0A90 is the only error code he is getting, He says he thinks the original battery is definitely the one to leave in the car going forward and will call me this p.m. after he checks some items that might be a side bar error message related to the P0A90. He will call me to let me know what they have ultimately found out. So that is where it stands…. Does anyone know what the P0A90 means . . . ?
  13. Patrick Wong
    18,200
    6,501
    DTC P0A90 "Drive Motor A Performance".
    There is a problem with the drivetrain, and the repair manual suggests several tests. If the tests do not reveal a problem then the transaxle will need to be replaced which will result in a major repair bill, well into four-digits - $6K or so for installation of a new transaxle.
  14. seilerts
    3,326
    1,518
    38
    Santa Fe, NM
    It can be the HV Battery current sensor. It depends on the sub code.
  15. 4-robinsnest
    Polk City, FL
    Once again to all my local and long distance Toyota Prius helpers here is what the final diagnostics test from the W.H. Toyota service center states . . . .
    I am told by the hybrid mechanic specialist that the P0A90 means that the Transaxle needs to be replaced. The original battery is still good. They have completed the floor mat recall & the other pump recall, stating that was not the error code. The estimate for the repairs bills on the Transaxle replacement are as follows.
    The labor to replace the transaxle is $813.50. The actual part has a cost for a new transaxle of $2,656.68 or for a used transaxle $1,700.00. There is also an additional cost of replacing the main seals & anxle seals. That cannot be determined until they get into that portion of the repair ? Some may/may not need replacing?
    I have family that own Pruis but they are all in Indiana and take their Prius to the Ft.Wayne, IN Toyota dealership religiously. That dealerships hybrid specialists have found that many times the sensors are the culprit of what has actually gone bad. Many times only the sensor needs replaced but many dealerships knowing this are after the bottom line dollar, not what is best for the customer. My brother was told that he needed a new Hybrid battery ($3,500 to replace) from a Michigan dealership (he lives in Michigan) He took his Prius (6hr drive) to the Ft. Wayne dealership and only had to replace the sensor that told the diagnostic systems to replace the HVBattery… Ugh! Some of these hybrid mechanics know this first hand and take peoples $$$ to buy a new HVBattery and then sell the old one (that is actually not bad) to others. . . ? The W.H. Hybrid Mechanic will not be back at the service center until Monday so that I can question him about the validity of the sensors on my current problem…?
    I would like to see if I can purchase the part on a parts website and find a local independent mechanic to assist me in the repair saving $$$ Are there any instructions available for the actual replacement of the transaxle. Does anyone in the central florida area do this type of work . . . ? Please advise . . . ?
  16. seilerts
    3,326
    1,518
    38
    Santa Fe, NM
    About the lowest you might expect to pay to have a used transaxle installed is $1500. That involves sourcing a salvage trans yourself from a junkyard and finding an independent shop to install it. An independent with a Toyota focus would be a good choice. Typical practice is to drop the engine and trans together and separate them outside the car, as it is a PITA to leave the engine in place. It is not too different from removing the transmission from a conventional FWD car. But, going this route carries little or no guarantee if it doesn't fix your problem.
    You have been offered a very generous deal on the new transaxle. The installation price is very reasonable for a dealership, and the part itself is deeply underneath MSRP. It appears to me like they are going above and beyond to help you out.
    The only sensor that could be faulty is the current sensor in the HV battery pack. With P0A90, there are additional 3 digit codes called sub codes or INF codes. If you could get the INF code and post it here, we could tell you if the current sensor was one of the questionable components. But, I don't get the feeling that the dealer is trying to pull one over on you.
  17. 4-robinsnest
    Polk City, FL
    Thanks to all who are following this saga . . . I have just returned from the WHToyota Dealer and here is the new Diagnostic Report . . . The only error with the original battery in is . . . P0A90 Drive Motor "A" Performance The following are the DTC codes that were in the Report . . .P0A90/239 & P0A90/241 & P0A90/602.
    Labor $846.00 Coolant $20.85perGallon 2 Gallons needed/$41.70.
    w/a New Transaxle Part $3,470.18 = $4,316.18 (+coolant &whatever seals need to be replaced? = $4,725.19 Estimate
    w/a Used Transaxle Part $1,770.19 = $2,616.19 (+coolant &whatever seals need to be replaced? = $2,955.00 Estimate
    So . . . Let me know what you all think ? and if I have included the right INF? codes asked for previously ?
  18. Patrick Wong
    18,200
    6,501
    It sounds like the transaxle needs to be replaced, and your dealer's pricing appears to be quite attractive (except that only 1 gallon of Toyota SLLC coolant is needed.)
    You'll have to decide whether you are willing to have a used part installed, since a new part only costs $1,700 more. Good luck with your repair.
  19. 4-robinsnest
    Polk City, FL
    Mr. Seilerts . . . What say ye to the following . . . Thanks to all who are following this saga . . . I have just returned from the WHToyota Dealer and here is the new Diagnostic Report . . . The only error with the original battery in is . . . P0A90 Drive Motor "A" Performance The following are the DTC codes that were in the Report . . .P0A90/239 & P0A90/241 & P0A90/602.
    So . . . Let me know what you all think ? And if I have included the right INF? codes asked for previously ?
  20. seilerts
    3,326
    1,518
    38
    Santa Fe, NM
    Robin, I'm so sorry to hear about this. Yes, those are unfortunately the "replace transaxle INF codes." The only caveat is that the crankshaft position sensor (CPS) is a possible source of trouble, and your car did have a P0335 for a CPS problem at the initial dealership visit. You could ask for the resistance measurements that they made on the CPS and its wiring harness to the ECM, just to make sure that they actually ruled out the CPS.
    As far as the estimates.... a new trans at $4725 is typical whether it be dealership or independent shop. A used trans at $2995 is expensive, but maybe they are giving you a 1 year warranty in the process, which would explain that. Having an independent shop install a used trans might run $1500-$2000 as I described earlier. I would urge you to think about this, as reputable salvage parts dealers (LKQ etc) will guarantee their parts for 90 days - one year. The cost of new from the dealer is more than twice the cost of salvage installed elsewhere. Perhaps sub3marathonman knows of a trustworthy independent shop in your area.
    P.S. if the dealership tries to scare you about how only they can do this work, you should take a look at this thread, where an aircraft mechanic changed out his trans with a salvage one at home.
