Chassis Brace is a Prius MUST HAVE!
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Azipod, Oct 11, 2010.
  1. Azipod
    Azipod Member
    139
    NorCal
    NICE review! The Strut-Tower bar option is equally as impressive. I got the Tanabe one .. Going rate is about $90-120, depending where you buy.
    The install on the strut tower bar is a lot more work, it involves removing the windshield wiper, and motor assembly to get full access to the strut tower bolts. It's a lot of work, but not difficult at all.
    GadgetDad has a full write up on the install along with pictures.
    The strut tower bar is another highly recommended mod for the Prius!
  2. bogeybob513
    bogeybob513 rtc513
    147
    Myrtle Beach, SC
    Be advised that the G-7 brace has slots, not pre-determined holes, which is why they require a hex head bolt to fit in the slots. Will it loosen over time?
  3. Supreme
    Supreme Hypebeast
    182
    Philly
    FYI - Megan Racing makes a very affordable strut tower brace that can be found all over ebay, last time I checked it was between $30-$60 tops.
  4. pEEf
    pEEf Engineer - EV nut
    720
    580
    Berkeley, CA
    Do you know if this is confirmed to fit the Gen II? It's awfully tight in there, and also even the expensive custom ones have had clearance problems.
  5. Azipod
    Azipod Member
    139
    NorCal
    The G7 has holes on the passenger side, slots on the drivers.
    The JuicedHybrid is the same (uses hex head bolts as well!)
    The factory bar is the same.
    I'm going to assume the BT Brace is the same as well.
    What else is new??
  6. SyCo
    SyCo Member
    207
    17
    Quebec
    I've ordered my G7 brace. Will see if that combined with my previously installed B&G springs will make any noticeable difference ;)
    Any link you can post or send me ??
    Thank you!
  7. a_gray_prius
    2,927
    783
    IL
    Hey does anyone have the C-ONE tower brace? Yeah, I want some JDM bling.
  8. Supreme
    Supreme Hypebeast
    182
    Philly
    Sorry forgot to mention that you need to search for either a corolla or matrix/vibe strut bar on ebay, no hits come up for prius. Corolla and Matrix strut bars have been confirmed by owners on this forum to fit.
    One example, a jdm strut bar for $10 new!:
    http://cgi.ebay.com/ebaymotors/Toyo...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
    Confirmation that corolla bars fit:
    http://priuschat.com/forums/gen-ii-prius-modifications/60243-another-strut-tower-brace-option.html
  9. pEEf
    720
    580
    Berkeley, CA
    Snatch! That's pretty cheap, so I couldn't resist. I'll let everyone know how well it fits. Thanks Supreme!
  10. Prius Happy
    Prius Happy New Member
    114
    Irvine, ca
    I wouldn't trust those Ebay strut tower bar... I've bought those before for my other cars. You can notice how cheap they are cost the actually piece bends so easily. Imagine if your car is taking hard turns... those bars will just snap off easily.
  11. TheSpoils
    TheSpoils Member
    304
    49
    New Jersey
    I want to be hopeful that this thing would work, but i guess i will have to be the down-er here. The plate has the same bolt spacing as the original, i don't see how it could be any more effective than the original. Lets say the original was 3 inches across the bolts, replacing with a 20 inch but using the same bolt spacing does not change anything. If you were adding a triangular pattern attached at a third or even forth location I believe would add much more stability. What may be the worlds worst sketch is attached, but you get the idea
  12. macmaster05
    macmaster05 Senor Member
    4,050
    730
    I believe the placements of the bolts is less relevant than the width and strength of the actual plate, which is what people are paying for. When the plate is wider, its metal pushes against the metal of the car more (which runs perpendicular to the length of the plate). Think of it like an "H". The - is the bar and the | | are the metal pieces the plate attaches to. If you have a thicker - when the car sways or turns there is going to be less movement between the | |. I think this is where you get the extra stability.
    I'm always skeptical too, but I challenge you to try it for yourself and see if you notice a difference.
  13. pEEf
    720
    580
    Berkeley, CA
    Yeah, I too am skeptical of the benefits of the bottom unit, but we've got a lot of good reports here. Are they placebos?
    Engineering-wise, the aluminum is much stiffer than the OEM unit, so if the body is experiencing torsion, the stiffness might help, but it's hard to know without some definite evidence. It also might be subjecting the part to tension, and that thick block of aluminum will definitely have more tensile strength.
    Maybe a better test is to pull it completely off and try some highway speed lane changes (cruise control locked at 60 lets say), then repeat with it on.
    Who knows, but for the cost, it's not much to gamble!
    I haven't put mine on yet, so I have no honest opinion so far.
  14. Azipod
    Azipod Member
    139
    NorCal
    C'mon guys!
    The G7 bar is $37. Granted it cost more than a tank of gas, it's still a heck lot cheaper than the $165+ brace from BT and Juiced Hybrid!
    The G7 made a huge improvement on my car. It made improvement on some others as well. There's never going to be any definite way to measure the gain. Handling is a very subjective thing.
    Placebo or not, for $37, this sure floats my boat.
  15. TheSpoils
    TheSpoils Member
    304
    49
    New Jersey
    Ok, Lets look at the bigger picture. Consider the two left tires and the two right tires, with the brace in the middle (attached to the same two bolts as the original.) How are the same two bolts at the same two locations going to offer anymore stability?
  16. Supreme
    Supreme Hypebeast
    182
    Philly
    So Azipod...do you produce this chassis brace? :D
  17. striker308
    striker308 Three time Prius owner
    302
    43
    Evans, NY (USA) / South Williamsport, PA (USA)
    I'm still looking for one sold that doesn't come from eBay, or requires Pay-pal to buy it.
    I have had to have four credit cards frozen because of these two sites.
    I'm still not paying $165................
  18. Azipod
    Azipod Member
    139
    NorCal
    Nope. I'm trying to share what works for me with my Prius-friends here.
    But it looks like some of our skeptical partners here are too busy trying to rain on our parade! :cheer2:
  19. donee
    donee New Member
    2,956
    198
    Chicagoland
    Prediction - By the the end of the day Sunday we will have a several people asking what they can do to stabilize the Prius in winds. These people will be predomonantly from Minnesota, Wisconsin, Iowa, Illinois, Indiana and Michigan.
    Just tell them to put on one of these plates.
  20. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    Thanks for the pictures. I ordered the part yesterday and today visited Harbor Freight to get a set of metric hex sockets ($6.99). I would never pay $100 plus for such a simple part. The $10 ebay Strut brace doesn't look to have the heft to accomplish anything.
