1. Teacherjoe
    Teacherjoe Junior Member
    29
    Ok, wife's 2005 is showing the following codes;
    p3021
    c1259
    P0A80
    b1200
    c1310
    p3000
    b1271
    b1421
    b1207
    I'm all ears for answers.
  2. JC91006
    16,933
    8,643
    P0A80 is a bad hv battery.
  3. Teacherjoe
    29
    I took it out and checked each module. Only one was low so I changed it out, put it all back together and it's still in same condition. Now, though, it won't even engage to drive as it did before I changed the module. Could the 12v battery be bad and causing this issue?
  4. JC91006
    16,933
    8,643
    Disconnect 12 volt negative for 20 seconds
    SM-N900P ?
  5. usnavystgc
    3,159
    990
    Tucson, AZ
    No, check this.
  6. usnavystgc
    3,159
    990
    Tucson, AZ
    No to TeacherJoe not you JC
  7. Teacherjoe
    29
    So am I replacing the fuse or just taking it out and putting it back in, like resetting it?
  8. usnavystgc
    3,159
    990
    Tucson, AZ
    Fuse???? No, you are executing step 9 on pg 21-118. More specifically, step 9. (c)
  9. Teacherjoe
    29
    Did it but red triangle still on. Even disconnected 12v negative for 20 seconds just in case. What to do about triangle? On a good note, all other warning lights went off!
  10. usnavystgc
    3,159
    990
    Tucson, AZ
    Ok, does the "Ready" light come on? Does the car start? Does it drive properly?
  11. Teacherjoe
    29
    Test drove it after disconnecting neg terminal and locking
    NGO the safety link and all is well. Thanks for everyone's input, I was tired and at my brains end and you all came through. Great jobs!
  12. JC91006
    16,933
    8,643
    Those codes mean something is wrong with those systems. I would first check and make sure your 12v is healthy. Then you would have to address the other problems. They don't just go away because you disconnected the 12v for 20 seconds. They will come back and remind you there is something wrong.
    Next time you see the warning lights, read them and we can go from there.....
  13. usnavystgc
    3,159
    990
    Tucson, AZ
    I believe all those codes were caused by lack of power (caused by the safety interlock not properly set). I'm betting his codes don't come back and all is well with that car however, I am betting he will have problems with the battery pack again due to just replacing one module and no rebalancing.
