Compost pile
Discussion in 'Environmental Discussion' started by SSimon, Aug 24, 2007.
  1. Darwood
    Darwood Senior Member
    5,259
    268
    Weeds make excellent compost, and yes, you do risk seed germination later, but who cares? If you care for your garden, it's no big deal to pick a few weeds, and proper mulching prevents most of them anyways.
    Dandelions are a particular risk, as the yellow heads will perk up and send off the seeds even after being picked, so make sure you put some grass clippings or older compost over them to keep them from blowing all over your lawn.
  2. SSimon
    SSimon Active Member
    1,426
    N/W of Chicago
    <div class='quotetop'>QUOTE(Darwood @ Aug 28 2007, 02:30 PM) [snapback]503355[/snapback]</div>
    Um, I care. Melilotus and medicago carpet my garden. After spending two full days of pulling these nasty weeds, no way I'm spreading more of the dastardly seeds in my garden. Some weeds are far too invasive to welcome back into one's yard, especially if one's not going to manage their existence by pulling them as they sprout before going back to seed. These weed seeds escape into our natural areas and cost a tremendous amount of money to manage. Volunteers bust their butts pulling this crap too. I ain't feeling this one. You get two thumbs down. Insert mean face here ____.
  3. Darwood
    5,259
    268
    Sorry! Guess it depends on the weeds in question.
    The weeds I pull aren't a problem in the compost pile. Most seeds are killed by the heat. Those that survive and are in the compost can't get up through the garden mulch where the compost is used. Those that do are much fewer in number than the new weeds that arrived via normal weed seed dispersal from neighbor's yard and the like.
  4. 4futrgens
    4futrgens New Member
    Most of the weeds that I have are shallow carpet type weeds. I have a rather large garden that has weed stop and then stone on top. The weeds that actually do get in there are able to root in the stone dust and are easy to pull out. Just been a little too busy this summer to keep up with them so there is a lot.
    I'm not too concerned with the seeds getting everywhere, except maybe in transport to the bin in the backyard. But the weeds have been particularly present this year. I read due to more CO2 in the air, but I think the neighbors have slacked a bit on their weed control, and I'm seeing the end result. <_<
    Thanks! I'll just stuff 'em right in!
  5. SSimon
    1,426
    N/W of Chicago
    I'm excited. I just ordered two compost bins. I ordered the garden composter that others here have indicated they use. I also ordered a compost turner which inserts in the bin like a rod and when you pull up on it, two blades pop out and allow you to turn the pile.
    These bins don't have a bottom, so the contents will lay on the ground and hopefully welcome worms and other insects that will aid in the compost process. This will actually serve as a nice compromise for my needs and my husbands concerns. I get the exposed matter to the ground potentially attracting the critters to help speed the process, yet the waste is encased and not an eyesore to the neighbors.
    I have mice and chipmunks near me, so I'll lay two sheets of chicken wire on the ground underneath the bins (secured by garden stakes) so that these animals cannot enter the bins. From what the supplier told me, these animals will seek out the warm composting matter and bring it back to their nests for warmth. I don't want them messing with my compost so I'm locking them o-u-t, out.
    The other nice feature of these bins is that you can purchase additional tiers to make the bins larger as your needs expand. In the meanwhile, I purchased two so that one can compost while I add fresh scraps to the other.
    Good on all of you for all the tips and helping better guide me and my husband to this final decision. You can all rest well that you've been instrumental in helping to remove approx. 26 gallons of waste from the waste stream on a weekly basis. I'll have the bins by next week!
  6. jimnjo
    jimnjo Member
    117
    2015 Prius c
    <div class='quotetop'>QUOTE(SSimon @ Aug 29 2007, 02:21 PM) [snapback]503861[/snapback]</div>
    Good job! I just looked this thread over quickly, and have just this to add:
    We have been composting for many years...using essentially the 'let it rot' unscientific process. But one thing that changed our compost for the better was plenty of carbon - that is brown stuff. newsprint would qualify, I think. Leaves are the easiest to find (fall leaves). Coffee grounds are great too...and you can bulk up at the local coffee shop if they will put them in a bucket for you. Filters can go right in, too!
    http://www.compostinfo.com/cn/index.htm is a fun way to see how it can work.
    Jim
  7. Prius 07
    Prius 07 Member
    715
    Toronto, Canada
    Good on you for ordering it and having so much enthusiasm. Lots of advice on weeds - I would just like to add that not all weeds are created equal. Some are much harder to get rid of once you have them and once a weed gone to seed it may spread through germination. To add weeds to compost or not - it depends on what weed, also how hot will your compost get. Will the heat kill the weeds / seeds. Some weeds are so bad that it's not for any compost and the advise is to just bag them. Having said that most garden waste can be put in there.
    Fall is just around the corner and your fallen leaves are great (carbon) for your compost. If you can shred them the broken down leaves will break down that much faster. You can break them down by using a leaf shredder/vacuum or just run over the pile of leaves with your lawnmower. If you have lots of them save some on the side and layer it on your compost with time.
    After every 6 inches in your bin you may want to layer in some soil this will add micro organism to speed up the process.
    Good luck
    Gabe
  8. SSimon
    1,426
    N/W of Chicago
    If anyone is thinking about composters, I haven't started using mine yet but thus far my experience is positive. They are packaged minimally. After assembly you have one box to recycle. There are no other packing debris to dispose of. The composter is wisely packaged so that the box is much smaller than that of the composter, it's stacked inside. It's easy to assemble and requires no tools.
    After experiencing the weight of this bin, I'm happy I listened to the comment about the difficulty turning the rotating bins due to weight. I can imagine that when my two bins are loaded, they'd be very hard for me to manipulate.
    Anyhoo, I saved up my trash for the last week or so and will start composting straight away.
    My composters ended up on back order, so I just received them a couple days ago.....just in time for me to turn on the radio on the way to the gym to hear about the state of our landfills. The largest landfill in the nation is closing soon, as are many others. Our disposal rate per capita has increased almost 100% from the 70's (I'm fairly certain this is the percent increase. Don't hate if it's not accurate.). We've become a consume/dispose nation.
    Seeing that I just hopped on the composting wagon is it to soon for me to preach? :)
  9. PriuStorm
    PriuStorm Senior Member
    2,239
    149
    Davis, CA
    UC Davis has a wonderful composting program here called Project Compost that is student run. Several times a year they have a vermicomposting workshop for the invited public, and I attended one earlier this spring and started my own worm bin. UC Davis now collects all their compostable material from the cafeterias and sends it to a plant in a nearby town, resulting in a drastic reduction in the number of garbage trucks going to the dump... something like 55 trips per week cut down to like 10 (I don't remember the exact numbers, but it was incredible) just by removing the compostable waste from the trash. Imagine the impact we could have if every restaurant, grocery store, and other high-vegetation waste producer in our town did the same...
    My worm bin has been going since early spring and it's doing wonderfully. As long as you have set up the worms with good bedding and comfortable oxygenated, dark and moist environment, they are happy. You have to have the correct worms to vermicompost... putting regular earth worms into the bin will just result in 'escapees' as earth worms need a different type of environment than red worms (one of the types used for vermicomposting). So, don't worry about the worms getting out of the bin.
    Also, don't worry about the worms overproducing. They will reach an equilibrium based on the size of their bin, and when their population reaches its maximum, they will maintain that all by themselves.
    I used to put my kitchen waste in a black bin outside, but the fly problem was horrible. Now I put all of my kitchen waste in my vermicompost bin (which I keep inside). I did have a learning curve to figure out how to keep that bin without fruitflies, but the key was maintaining the correct bedding, not allowing airholes to be too large (so that the flies can get in and out), and not allowing the bin to be too moist. The stackable vermicompost trays are good, but I would not use them if I was going to put ANY fruit waste into them at all, as these will allow fruitflies en masse. The bin I use now (which is what the ProjectCompost group suggests) is a regular Rubbermaid bin (I think it's 18 gallons, but you can also use a smaller 10 gallon one), drill to add air holes, add bedding, worms and food. You only need a pound of worms to get started, and once your vermicompost bin is thriving, you can share your worms to start other bins (or give to family members... imagine that... Happy Birthday, Aunt Sue, look what I got for you :lol: ).
    My outside compost is now only regular green and brown plant materials, which I keep in a pile covered with a tarp. Several times throughout the year I turn this pile and add moisture (it's so hot and dry here in the summer). No weeds for this pile. Every time I turn it, I'm amazed how much it's shrunk.
    I tried the tumbler bin... I think it's just too dry here for that to work properly. I only succeeded in creating extra dry material, not compost at all. I guess I should have been watering it a lot more than I did (I was watering about once a week).
  10. Prius 07
    Prius 07 Member
    715
    Toronto, Canada
    <div class='quotetop'>QUOTE(PriuStorm @ Sep 15 2007, 06:43 PM) [snapback]513131[/snapback]</div>
    you're correct - namely you need red wigglers for vermicompost
  11. SSimon
    1,426
    N/W of Chicago
    Months after setting up both of my compost bins, I really do appreciate them. My waste output has been cut by about 75%. And it's truly amazing how fast the contents in the compost bin break down. I still haven't had the need to start filling my second bin after all this time.
    But I had one troubling thought the other day. What happens to all of the pesticides and herbicides that are present on the produce that I purchase from conventionally grown sources? Do these break down in the composting process or will I be spreading them around my soil interfering with my intended organic land use approach? Based on my research thus far, it appears that if one has diversity in the pile, and the correct air and moisture ratio, the pesticides and herbicides will degrade into inert byproducts. If one doesn't manage this delicate balance, the pesticides and herbicides will exist in your finished compost product. Here's a link.......
    http://www.ibiblio.org/ecolandtech/SoilWik...3/msg00103.html
    It seems that worms do an excellent job of breaking down the pesticides and herbicides and a microbial inoculation can help to also break down these chemicals.
    I have to do more research on Chlopyralid and picloram. These chemicals (herbicides) are mentioned on various websites I've reviewed and they do not break down in the composting process. I've no idea if this chemical is used in our agricultural process but it's licensed for homeowner use, so I wouldn't doubt it.
    I'm still researching all of this but am saddened to have to wonder if my trash is better off with all of your trash in a landfill where the contamination is at least contained.
  12. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    That makes a lot of sense SSimon.
    Not that you are likely to find DDT in your local produce but we all know how that breaks down into DDE but that is about it for quite some time. It wouldn't be a huge leap of intellect to assume there are other chemicals used in the agricultural process that will not break down in the compost bin. I'll see if I can remember to ask some of my professors next week. :)
  13. PriuStorm
    2,239
    149
    Davis, CA
    SSimon,
    One might wonder why you aren't supporting your local farmers, or buying organic to begin with since you're planning on growing organic... :wink:
    That'd take care of your concern right there... :)
  14. SSimon
    1,426
    N/W of Chicago
    There are no food coops near me.
    I was trying to locate a municipality from which I can rent a plot to grow my food. I was unsuccessful. The only village I know of that has such a program is discontinuing it next year. Still checking around.
    Right now I buy organic as available. For a vegetarian with a diverse palate for veggies, organic is not always an option.
    Unfortunately, conventionally grown crops still make their way to my fridge and into my compost. Working on this........
  15. PriuStorm
    2,239
    149
    Davis, CA
    <div class='quotetop'>QUOTE(SSimon @ Nov 25 2007, 11:20 AM) [snapback]543939[/snapback]</div>
    I just noticed where you're from, so I apologize... I think your initial reaction above is probably right on, that it'll break down. Since you eat the conventional fruits and veggies anyway, don't you think much of the questionable chemicals will be washed off prior to your own consumption? I vermicompost as well, so if unsure, you could always feed those portions to the worms who do a most excellent job. Good luck with your organic gardening project! :)
