Confirmed!!! Gen5 nav 9.1 works in 2006+ prius!!
Discussion in 'Gen 2 Prius Audio and Electronics' started by LIPriusFreak, Jul 21, 2011.
  1. LIPriusFreak
    LIPriusFreak Can I haz JDM?
    449
    34
    Long Island, NY
    After numerous bouts with trying to burn gen 4/gen 5 9.1/10.1 software and not getting it to work, I decided to take the plunge and purchased a used original gen 5 9.1 disc
    it loaded up just fine...wonder if I could copy it?
  2. pabbas
    pabbas Junior Member
    Bloomington
    Will you try? :D
  3. 2Nutz
    2Nutz New Member
    S.F. Bay Area
    If you have the disks available, make a block by block copy as a back-up and see if it work ?
    :confused:
  4. ualdriver
    ualdriver Member
    358
    63
    Midwest US
    So refresh my memory......if I have a 2008 Prius and I purchase an original gen 5 9.1 disc, will that give me a newer database than the one that came with my 2008? By how many years?
    And if it is a newer database, how much does this disc cost?
  5. LIPriusFreak
    449
    34
    Long Island, NY
    the 2008 prius should've come with 7.1 which means my disc is 2 years newer (2009-2010 data)
    I will try to copy this weekend...if it works....I will start a list as to whom needs copies and I will forward via UPS.
    THe disc is $199 at Toyota..I paid $60 (which is what I felt it was worth)
  6. 2Nutz
    2Nutz New Member
    S.F. Bay Area
    Good luck and may the force be with us
  7. mynameisjim
    mynameisjim Junior Member
    16
    I'm interested
  8. ss_neogeo
    ss_neogeo Junior Member
    22
    Arizona
    If the backups do work, then indeed sign me up on the waiting list!
    I've tried burning a 9.1 and a 10.1 from links I found here, both from a Lite-On burner using Verbatim discs, and while they did update the Agree display page, they both failed to update the maps. I'll try to provide any other information if I come across it.
  9. Debprius
    Debprius New Member
    Virginia
    Hi. I'm new to this forum.
    So, all I want to do is update my map. What else besides the map does the dvd do/update/change?
  10. just_older99
    just_older99 New Member
    24
    hamilton,ontario canada
    how did you get it for $60?
    if it works in interested!!! :)
  11. FreydNot
    FreydNot Member
    214
    37
    Seattle, WA USA
    I don't want to rain on anyone's parade, but I think you will find the gen5 DVD reader in the Prius will simply only read factory pressed, silver disks (not any form of writable disks). I would be happy to be proven wrong.
    The reports I have read say that the gen5 drive in the Prius is the only one with this "problem". Gen4 drives in the Prius seem to work. Gen5 drives in other Toyota/Lexus cars seem to work.
    Good luck.
  12. volkl
    volkl Junior Member
    I don't think there is an inability in the reader of gen 5 dvd units, because I was able to make a fully functional copy of a 7.1 disc. The inability only occurred with the 9.1 disc. It is interesting that the powers that be should decide to implement a form of copy protection in the firmware of the gen 5 and not others. I believe the limitation is caused by the firmware checking the sector scheme of the disc --- if it is the scheme of a burned disc, then no go.
  13. FreydNot
    FreydNot Member
    214
    37
    Seattle, WA USA
    Interesting. I have the gen5 stock 7.1 disk in my 2008 now. Maybe I'll try to replicate your copying of the 7.1 disk.
    Can you give me details of what worked for you? What brand of media, what burning software, book type, etc.
  14. volkl
    volkl Junior Member
    <responding to FreydNot>
    Sure. Just pulled out the old 7.1 copy that I used in my 2006 prius. Note, I purchased an OEM 7.1 as my source, and only made the copy because I was paranoid of a valet stealing my OEM disk.
    It is a Verbatim DVD+R DL and I used a Macbook Pro running Toast Titanium 8.
    I have read posts about setting the book type, but if I recall correctly, I just used the copy setting defaults of Toast.
    I tried many times to burn the 9.1 and have not ever had any luck.
    Oh, one more thing...the dealership that sold my 9.1 OEM said that once one puts a 9.1 disk in, then a prior disk will never work again. My assumption is that once one puts a 9.1 OEM diskette in, it upgrades the firmware of the reader, and this includes code that checks that the formatting scheme is that of a factory pressed disk as opposed to a burned disk. If the dealer is right about not being able to revert to a disk prior to 9.1 after 9.1 has been installed, then your experiment is meaningful if you have not installed 9.1 OEM.
  15. FreydNot
    FreydNot Member
    214
    37
    Seattle, WA USA
    Thanks for the info. Mine has never seen a disk other than the factory 7.1 disk it came with so it should be a good test.
    First I will try to burn a copy of the 7.1 factory disk and see if that works. When I eventually purchase a 9.1 (or 10.1) version OE disk I'll see if I can figure out how to edit the files on the disk such that the only the 7.1 firmware is present on the frankenstein'd DVD. It will be interesting to see if the 7.1 firmware will be able to read the 9.1 data. Since I will have a true OE 9.1 disk in hand, if it doesn't work I can simply plug the true disk in and everything should work out okay. That's my thought at the moment anyway.
  16. FreydNot
    FreydNot Member
    214
    37
    Seattle, WA USA
    I was able to successfully make a copy of my factory stock 7.1 gen5 nav disk. I use windows so I tried Imgburn first. It complained about the layer splits not being optimum and refused to burn the disk. Next I tried using DVDFab. I used the Clone mode which is found under DVD Copy. That worked prefectly.
    I didn't have any Verbatim media on hand so I used the Ritek DVD+R DL media that I did have. I'll keep using the copy in the car and see if it has any problems.
    I'll need to acquire a OE 9.1 or newer gen5 nav disk for my next set of tests. Anyone know where I can get one for cheap?
    Here is what Imgburn had to say about the factory disk...
    PHP:
    PIONEER DVD-RW  DVR-111D 1.23 (ATA)
    Current ProfileDVD-ROM
    Disc Information
    StatusComplete
    State of Last Session
    Complete
    Erasable
    No
    Sessions
    Sectors
    3,999,616
    Size
    8,191,213,568 bytes
    Time
    888:50:16 (MM:SS:FF)
    File System Information:
    Sectors3,999,616
    Size
    8,191,213,568 bytes
    Time
    TOC Information:
    Session 1... (LBA0)
    Track 01  (Mode 1LBA3999615)
    LeadOut  (LBA3999616)
    Track Information:
    Session 1...
    Track 01 (LTSA0LTS3999616LRA3999615)
    Physical Format Information (Last Recorded L0):
    Book TypeDVD-ROM
    Part Version
    Disc Size
    120mm
    Maximum Read Rate
    10.08Mbps
    Number of Layers
    Track Path
    Parallel Track Path (PTP)
    Linear Density0.293 um/bit
    Track Density
    0.74 um/track
    First Physical Sector of Data Area
    196,608
    Last Physical Sector of Data Area
    2,221,436
    Last Physical Sector in Layer 0
    (Last Recorded L1):
    Book TypeDVD-ROM
    Part Version
    Disc Size
    120mm
    Maximum Read Rate
    10.08Mbps
    Number of Layers
    Track Path
    Track Density
    0.74 um/track
    196,608
    2,171,394
    Layer Information
    Layer 0 Sectors2,024,829 (50.63%)
    Layer 1 Sectors1,974,787 (49.37%)
    And here is what Imgburn had to say about my new copy...
    PHP:
    Current ProfileDVD+R DL
    Disc Information
    StatusComplete
    Complete
    Erasable
    No
    Sessions
    Sectors
    3,999,616
    Size
    8,191,213,568 bytes
    Time
    Sectors3,999,616
    Size
    8,191,213,568 bytes
    Time
    TOC Information:
    Session 1... (LBA0)
    Track Information:
    Session 1...
    Track 01 (LTSA0LTS3999616LRA0)
    Disc Control Blocks Information:
    PIONEER DVR-111D
    (ADIP L0):
    Disc IDRITEK-D01-01
    Book Type
    DVD+R DL
    Part Version
    Disc Size
    120mm
    Maximum Read Rate
    Not Specified
    Number of Layers
    Track Path
    Opposite Track Path (OTP)
    Track Density
    0.74 um/track
    196,608
    16,580,607
    2,283,519
    (ADIP L1):
    Disc IDRITEK-D01-01
    Book Type
    DVD+R DL
    Part Version
    Disc Size
    120mm
    Maximum Read Rate
    Not Specified
    Number of Layers
    Track Path
    Track Density
    0.74 um/track
    196,608
    16,580,607
    2,283,519
    (Last Recorded):
    Disc IDRITEK-D01-01
    Book Type
    DVD-ROM
    Part Version
    Disc Size
    120mm
    Maximum Read Rate
    Not Specified
    Number of Layers
    Track Path
    Track Density
    0.74 um/track
    196,608
    16,580,351
    2,196,543
    Layer Information
    Layer 0 Sectors1,999,936 (50%)
    Layer 1 Sectors1,999,680 (50%)
  17. gaover
    gaover New Member
    port saint lucie, fl
    If possible I would like t get a copy of the disk.
  18. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Someone has to be the wet blanket and point out the obvious: This software and data are copyrighted - distributing this to others is illegal.
    From a more practical standpoint, Toyota employees often read these forums. I would feel a little funny making offers like this where they can be read by Toyota employees.
    End of lecture, but you have been warned.
    Tom
  19. GHoray
    GHoray New Member
    pennsylvania
    First time posting but couldn't resist if I can get copy of updated map(S). I have a 2007. will this be newer? Very interested.
  20. Wolfie52
    Wolfie52 Senior "Jr" Member
    143
    124
    No. Carolina
    Funny, that was the first thing I thought about, qbee42, when I read the guy was going to copy the Navigation DVD and then sell them!
    People, don't leave paper trails of your criminal intent. It may seem "harmless" to you, but it is illegal.
