Dashcam Hardwiring
Discussion in 'Prime Technical Discussion' started by PixelRogue, Feb 15, 2025.
  1. PixelRogue
    488
    86
    US
    TLDR: Which wires would one tap for an 'always on' and 'on when car is turned on' to wire a dashcam (w/parking monitor. worth noting parking monitor turns off if/when battery level depletes.)
    Have the rear camera wire full run (panels remain out for a few additional updates.) Time has arrived to install the hardwire kit for the camera. Kit is to tap into fuse box. I haven't seen a blog, write up or video where tapping into fuse box doesn't leave an exposed wire preventing the fuse box lid from fitting back on (short of drilling an access port through the lid) and in all cases looking like questionable hack by the end, random wire leaving the box. If there is a way to tap the fuse box and look OEM then let me know and I'll go that route.
    Given the fuse box concern (lid not sitting back, looking odd w/random wire) I'm leaning towards the tapping wires directly instead of fuses. If this is a BAD idea let me know. So curious which wires (w/enough slack and located somewhere under the drivers side dash (actually ok w/under passenger side dash or behind MFD for that matter) would be tapped (one for always on (parking mointor) and the other for on when ignitiion is engaged (cam itself?)
    TIA
  2. RandyPete
    RandyPete Active Member
    409
    171
    Santa Margarita, CA, USA
    2024 Prius Prime
    XSE
  3. PixelRogue
    488
    86
    US
    RandyPete likes this.
  4. RandyPete
    409
    171
    2024 Prius Prime
    XSE
    OOPS, gave 2024 link for a 2021 prius question. You might want to search the 2021 Prius forum for that info. Sorry.
  5. PixelRogue
    488
    86
    US
    NP. Will do. Thank you.
