Dealer serious about nitrogen tires!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by 2009Prius, Jun 16, 2011.
  1. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Nitrogen and air expand at the same rate (at least much closer than you can measure with your tire gauge).
    They are called the "gas laws" instead of the "gas suggestions" for reason.
    qbee42 called it right, "placebo effect"
  2. Insight-I Owner
    Insight-I Owner 2006 Insight-I MT + 2011 Prius
    505
    100
    Essex, CT
  3. richmond2000
    richmond2000 Junior Member
    Winnipeg MB Canada
    @ the fleet I work for we tried nitrogen in our tires and found the tires /rims do LAST longer and hold PSI better BUT NOT worth the cost if you can NOT return to the Nitrogen centre for refill/topup when needed so in town YES out on the hiway NO
    Fountain Tyre charges 15 Dollers PER tyre BUT will throw it in for FREE if asked during new tyre fitting or change over AND they WILL top up for free
