Electric Porsche!
Discussion in 'EV (Electric Vehicle) Discussion' started by daniel, May 14, 2009.
  1. qbee42
    qbee42 My other car is a boat
    18,058
    3,077
    Northern Michigan
    Correct. The power curve for an electric motor will differ from that of an ICE, but they both have a power curve. More speed will translate to more power, up until the point where losses cancel the gains.
    Tom
  2. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    yep. edited my post because i could barely understand the point i was trying to make
  3. JSH
    JSH Senior Member
    2,605
    140
    PDX
    I wasn't able to find a HP vs RPM graph for an Advanced DC electric motor like the ones used in many electric car conversions. However this is for a PMDC (Permanent Magnet Direct Current) motor like the ETek used by many electric motorcycles, scooters, fighting robots, etc.
  4. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    well that shows that efficiency is near the upper range of the RPM range? well ya, but momentum, gravity, and the resulting current velocity all play a part as well. so running efficiently appears to still mean running at or near max RPM's which would be aided by downshifting?
    not sure that combining torque (which should be constant) with amps which most definitely is not makes this chart easier to understand
  5. JSH
    JSH Senior Member
    2,605
    140
    PDX
    Peak power and peak efficiency are not necessarily the same. My understanding is that peak torque comes at low RPM and high current. That would not translate to good efficiency.
    Again, this is from reading posts on the EV list and people saying that they upshift for more power. For example to maintain speed on an increasing grade they upshift. Some quotes for the Electric Vehicle Discussion List:
    "You do know to hold the trans in lower gears as long as possible, right? Don't upshift too early. Stay in lower gears for lower motor heat and better range, upshift if you run out of steam and/or need faster acceleration. Yes, UPSHIFT for more acceleration!"
    "If you want more horsepower (for climbing a hill or accellerating), a 96v pack only gives you one choice; upshift (like from 2nd to 3rd gear) Note that this is the *opposite* of what you'd do with an ICE. Upshifting slows the motor down, which makes it draw more current. For 2x the horsepower, you need 2x the current; 96v at 380 amps."
    "I'm thinking of reversing the operation of the downshift cable, have it pulled to passing gear for normal driving to keep the RPM up in the efficient region, and let it drop out of "Passing gear" to upshift when I need more torque."
    "My EV ('92 Celica) has a 9" ADC motor, stock 5 spd/clutch/flywheel, and is driven with 14x8V flooded cells through a Raptor 600 controller. Compared to the ICE motor, the DC does pull better at low RPM, and (as you imagined) does seem to "go away" at higher RPM's. With only 112V nominal to work with, I can only draw about 150 Amps near redline (about 5000RPM and 45 mph if I remember correctly). So if I stomp on it in second gear, it pulls hard (at about 400 battery amps), and then eases off as the speed goes above about 30 mph (estimating about 3500 RPM). It continues to pull, but takes forever to get to
    40 mph. If I shift "early" (at about 30 mph) my current will stay high, and my speed will increase faster.
    Everything I've read tells me to keep the RPM's high, which helps cooling, and range, but if I'm pulling out into traffic, I have to shift at lower RPM's.
    If I drive at a steady 40 mph, I can drive in 2nd or 3rd gear. The difference in current drain (for constant speed) is hardly noticeable between the gears, and often I go ahead and upshift, anticipating the need to go faster. (and at lower RPM, I'll have more acceleration at the ready if I need it).
    My range is about 35 miles, which is all I need, but if I had to do it over, I would probably go with a higher voltage pack (to give me more torque at the higher RPM's)."
    So, if Daniel's EV is like these people's he might be driving it opposite of how he needs to get best acceleration and range. These people claim that to get the best range you need to cruise at high RPM and upshift to a lower RPM for more passing power. This is exactly opposite of what one does in an ICE.
    Daniel, If you haven't already I would recommend you join the Electric Vehicle Discussion List. They have moved from direct email to a yahoo group now. It has some very knowledgeable people that can help you with your range and acceleration issues.
  6. daniel
    14,487
    1,519
    Spokane, WA
    First to answer Dave's comment about the charger:
    Paul disregarded my preference as regards charging, and he did me a favor! I have a 28 kWh pack. The pack charges at about 25 amps (at the pack, as measured by the car's e-meter, not at the wall, where I have no way to measure) so it should take about 8 hours to charge from empty. Theoretically the chargers are drawing a combined 36 amps at the wall. If I had a 100-volt, 20-amp charger, it would take 32 hours to charge!
    110 v X 20 a = 2.2 kW. (A 110-v charger, at the wall.)
    25 a X 144 v = 3.6 kW (My charger, at the battery)
    220 v X 36 a = 7.9 kW (The presumed combined draw of my chargers at the wall)
    This means my chargers are 45% efficient. If a 110-v charger is 50% efficient it would put 1.1 kW into the pack. 1.1/0.4 = 2.75. So a 110-v charger, on my car, would give me a little less than 3 miles of range for an hour's charging. If we are talking about useful opportunity charging, a 110-v charger would be essentially useless. Now, with my 8 kW charging system, an hour's charging should give me 3.6 kWh, or 9 miles.
    The comments above about power, efficiency, and range are correct. Ideally, for maximum efficiency and range I should be driving in the lowest gear I can, to keep the motor's rpms up. However, above a certain speed (as the graph shows) there is no power, and it is not safe to drive in a condition where you have no power available for acceleration. So I may have been driving in too high a gear for best range.
    OTOH, I can tell you that if I floor it from a stop in a lower gear, I move out faster than if I floor it from a stop in a higher gear. So it's not entirely true that you get more acceleration in a higher gear.
    However, my problem with the 70-mph test was that this car just doesn't have what it takes to go 70 for an extended time. After about 20 or 25 miles, either the battery didn't have enough voltage (being by then down about half its safe, usable range) or (as Richard thinks likely) the controller, pulling 250 or 300 amps for 20 minutes or so, was starting to overheat and was reducing power to protect itself. Either way, this is not a 70 mph car. (Paul had told me it would do 100 mph, which maybe it would do for a short time on a full pack, but not for long, or when the pack is down.)
    Upshifting would have given me more acceleration to get back up to speed, but not if the controller was overheated or the battery voltage was too low to provide the power.
    Richard recommends running in as low a gear as possible, and I modify that for safety to the lowest gear that still leaves me room to accelerate if I need to. I am more interested in efficiency than acceleration.
    Of course, it's one thing to understand the principles, and another to know what gears under what conditions to use at what speeds. That's a matter of learning by experience. I've only had this car for a week, and I've only been able to charge it up since Monday.
    People are saying this car could be improved. But as I may have said before, I bought this car to drive it, not for it to be somebody else's science project.
  7. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    i have to agree about the overheating. the Tesla didnt it have cooling fans? maybe that is all you need. there are a lot of Zenn owners who installed small fans on their chargers because they seem to kill chargers at a high rate. (i am on my 2nd) but there is a guy who installed a small fan on his and he has over 3 years using same charger as we have
  8. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Interesting: you still have belts in the ex-engine compartment.
    Is that power-steering and A/C compressor? How do you get any
    power steering when you're close to a standstill if the main
    motor isn't turning very fast, or is that bottom pulley connected
    to something else?
    As far as the hesitation -- here's a question: do your Li modules
    have on-board smarts and cut-off transistors? If you have sets
    of two in parallel [always seemed like a bad idea but it's done
    in any number of laptops], and one decides it's had enough and
    disconnects itself from the string, the other one might be able
    to still handle the current but you'd see an overall reduction.
    Either that your the Curtis was going into some sort of self-
    protective current limiting mode, similar to to what was already
    mentioned.
    Very nice new toy, though.
    _H*
  9. daniel
    14,487
    1,519
    Spokane, WA
    Everything has fans. The controller has two fans. The chargers each has a fan. LiFePO4 does not need fans, unlike the li-ion laptop batteries in the Tesla, which need liquid cooling from a refrigerator built into the car.
    Yes, I have power steering and A/C driven by belts from the motor. As you figured out, there is no power steering or A/C when the motor is not turning. At a stop, I can shift the car into neutral and give it some pedal to turn the p/s pump and the A/C compressor.
    The real surprise is when you shift out of gear going into a turn because you want to downshift, and then you have no p/s for the turn. But it's still easier to turn without p/s than the Super WD-4 tractor I drove for a while on the farm, which had no p/s. The trick is to leave it in gear because you seldom really need to downshift. You never need to worry about lugging or killing the engine by leaving it in too high a gear as you slow down. This is something I need to get used to.
    In second gear (which is what I use in town) even the smallest amount of motion is enough to make it not too hard to steer, and at just a few mph, it steers fine.
    The power brake booster is electric, and not affected by the motor. It makes a funny noise from time to time as it pumps up the pressure. The car is noisier than a Prius in electric mode, but quieter than a Tesla with its refrigerator. I sure wish Toyota would built a 150-mile pure EV!
    I don't know the answer to your battery questions, but the chargers have built-in BMS. I would have said before that Paul knows what he's doing, because he's been doing this a long time and whatever he does will be the right thing. That may indeed be true, but I no longer have the confidence I did.
    The front bit of the wheel well liner had broken loose and was hanging down. So I took it to the Porsche dealer to look at it. It turns out that it was fastened to nothing, because Paul had removed the radiator bracket along with the radiator itself. And the A/C condenser was loose on one side because Paul had tied it into place with a plastic tie-down! They've ordered parts and will secure everything. But this was sloppy work.
    On the positive side, it handles beautifully and is fun to drive, and it's electric. I hate gasoline, and I'm willing to put up with a lot, in order to be able to drive electric. The Porsche does not turn heads the way the Xebra does. But it's a better car. :cheer2:
    The Porsche dealer is happy to work on any original parts of the car, and is willing to look at any part of the electric system that may need work, and tell me if they think they can work on it or not.
  10. hyo silver
    hyo silver Awaaaaay
    15,266
    1,603
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    As much as I admire your pioneering spirit, Daniel, a Porsche that won't do 70 is kinda...well...neutered. Which I suppose isn't any great harm if it won't get you laid anyway. :eek:
    Sorry, man. Somebody had to say it. Nothing personal. :)
    Hey, how much to get your knees fixed so you can ride a bike? (May as well get the nastiness over with all at once. I'll try to be nicer tomorrow. ) :redface:
  11. daniel
    14,487
    1,519
    Spokane, WA
    I agree about the lack of performance of the car. It's a disappointment. But then, life is full of disappointments.
    It wasn't my knee joint. It was the IT band where it passes by the knee. Probably not fixable. But the bigger issue is that I cannot stay upright on a bike. It was less of an issue in ND where there were maybe a dozen cars an hour on the rural roads out where I lived. Here in town, forget it: I'd be dead in a week.
    Better to be driving a neutered (but it's not a stinker!) Porsche than to be dead because I lost control of a bicycle in traffic.
    Yesterday I had a long conversation on the phone with the president of the EV car club in Post Falls, ID. It was a breath of fresh air! Everyone else has been telling me how angry I should be because my car does not perform as promised, and how I ought to demand satisfaction from the builder. Gordy's reaction was, Of course it does not perform as promised. EV's never do. Even the Tesla Roadster doesn't do as well as promised (though it's a fabulous car). You've got the coolest car in two counties, and you're going to have great fun driving it and be the envy of the entire car club, and maybe tweak it a bit and make it a bit better.
    He had nothing negative to say about what the car won't do, just positive things to say about what the car is. Really boosted my spirits, because in spite of the disappointment, it's a beautiful car and fun to drive and a big step up from "the Snail."
    Darell's car will go farther than mine, but mine will accelerate faster. And except for the guy who posts as "PeakOilGarage," who drives (or soon will be driving) a Tesla Roadster, I've got the coolest car on PriusChat. And it has ZERO pollution (gets its electrons from hydro power). I've got the only water-powered Porsche on PriusChat, so who cares if it can't maintain 70 mph for more than 20 miles or so, as long as it can get to Coeur d'Alene and back at 50 or 60 mph? I'm the only one on Prius Chat, except for Allan, who can even get to Coeur d'Alene and back in less than half a day, and he'd have to drive a stinker to do it!
    So there!!! :cheer2: :D :rockon: :car: :whoo: :peace:
  12. icarus
    icarus Senior Member
    4,884
    976
    earth
    Speaking as an old Porsche hand,,, while I applaud the intent to get a cool/green efficient commuter car,, the idea of ripping apart a fairly complex, fairly expensive classic that has and will hold value and put in the hands of some back yard tinkerer is a bit silly.
    I can see all kinds of 'minor flaws" that would have to be worked out to make this project viable,, such as ac, power steering issues etc. (does the car have regen capabiltiy?)
    It seems to me that for the purchase price of a 2002 911 of say $15k? why wouldn't you spend $2000 on a mint Hyndai, or Honda of the same vintage, put the $13k into the conversion and at the end of the day at least have a car that comes close to your goals,,, including the cost of the project? Somehow the idea of driving around in a 911 "Chick magnet" with the spare tire bungeed down in the back seat, a couple of 50LBS bouncing around in the trunk seems to be making a sow's ear out of a silk purse.
    It seems it you are looking to experiment,, a better platform to start with would make better sense. To assume from the back yard tinkerer that you will get X range, X miles per kwh with no beta to compare is optimistic at best,,, foolish at worst. My fear is that sooner than later you will find that the car doesn't come close to expectations,, the headache factor of the quirks out weigh it's cool factor, the battery life and longevity will be poorer than expected and more expensive to replace because of deep draw downs etc, and you will be left with an interesting relic,,, not a 911,, not a EV.
    Sorry,, but just one person's opinion.
    Icarus.
    In the interest of full disclosure,,, I have been know to do similar things myself. The difference is that I squandered my time and energy for the sake of the exercise,,, not my money to let someone else figure out the pitfalls. Some times worked out,,, (solar water heat) often didn't, (small scale wind)
  13. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    I would like to pick up an old Geo Metro and try an EV conversion. For some reason, the 3 cylinder Metro's didn't last long, and assuming they were not crushed, should be cheap
    I like to tinker, but taking a pretty car like a 911 and tearing the guts out of it, doesn't sit well with me
  14. mojo
    mojo Senior Member
    4,519
    390
    San Francisco
    A Gen 1 Prius would be the best candidate as you have regenerative braking.
  15. hyo silver
    hyo silver Awaaaaay
    15,266
    1,603
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Indeed. Sorry, I thought it was your knees.
  16. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    I think that's a pretty good way to look at it Daniel, and if you're satisfied, then that's great. But for what you paid and the range being a scant 1/2 of expected wouldn't be acceptible in any commercial EV. 10,20, 30% less than advertised is one thing. The performance thing...not a big issue for me, just bragging material really.
    But if you're happy, then that's what matters.
    --evan
  17. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    This is just a rant.
    Unless the power company runs a transmission line from the hydro plant to you house, you cannot tell where the electrons are coming from as the hydro plant is tied to the grid.
    My utility company keep sending me letters to ask me to paid 10% more for green electricity, I will not paid a dime more unless they can prove the electricity comes directly from the solar or hybro plant to my house.
  18. icarus
    4,884
    976
    earth
    While this is technically correct,, in fact, and in the real world the issue is somewhat different. If you pay X% more for the promise that YOUR consumption comes from sustainable sources, (PV, wind, GOOD hydro etc) in the aggregate the percentage that you pay for green power will come from green sources. Can the utility claim that the exact kwh that it takes to write and send this comes from green power,,,no,, but the fact that I am willing to underwrite the extra cost for green power, allows the utility to pay extra for it and resell it. It is and does happen in the real world. Witness the wind farms in Eastern WA and OR, that is where my 10% subsidy is going,,, and I am happy to do it.
    The reality is if you want to assure that the exact KWH that you use comes from green sources,,, invest in PV solar and get on a net metering program from your utility. Over a calendar year you may put more into the grid then you use,, but even then, you may sell some green power back to the utility and ergo to someone else, and you may indeed buy KWH at night from the utility that is not "green" but in the aggregate,,, you might generate more green power than you will use non-green power.
    If you believe that we should pay the real cost(s) of our energy choices,, then by all means you should be willing to pay for them personally. If you accept that coal, or natural gas or nuclear are not sustainable, then you should be willing to pay as much as you can afford to bring about the change that we need to make. (If you cn afford to drive a Prius,, you can afford 10%. Hell you can save that 10% by conservation without breaking a sweat! I'll bet I could walk into your house and find 10% net energy savings within an hour,, most with no change in life style.
    If you are just looking for cheap,,, feel free to buy coal fired electricity,,,, and make your kids and grand kids pay the price,,, assuming they will be around to!
    Icarus
    In the interest of full disclosure once again. We live ~1/2 the year off grid and generate all our electrical power off grid solar. We use Propane for fridge, water heat and cooking. We heat with wood.
    The other half we live on utility power. We heat with wood, propane. Our electric bill is ~$25/month, including pumping water for two houses. We do heat a hot tub off of grid power which is far and away our biggest user net/net. We buy the maximum green power that Puget Power allows.
    Icarus.
  19. daniel
    14,487
    1,519
    Spokane, WA
    Your concerns are legitimate, so I will address them. First of all, Paul is not a "tinkerer." He runs an established EV conversion shop. My mistake was that he had not previously had experience with lithium batteries. I was not aware of that.
    Why a Porsche? Because I like the looks of it, and I wanted a car that is safe and handles well. This is not a classic car. This is a recent-model car, which I selected for its looks and safety features.
    My car does not have re-gen. Re-gen recaptures a relatively small amount of energy in flat terrain, and it was a decision I made with Paul's advice.
    Your notion of the prices of used Porsches and conversions is way off. I did consider a Civic as the donor car, but decided I wanted something that looks a bit more like a Tesla. Since the biggest part of the cost of a conversion is the batteries, I saw no reason to skimp on the donor car.
    It's true I didn't get what I had hoped for. But in hindsight it's easy to say what I should have done differently. The president of the nearby EV club thinks that for all its shortcomings, I have the coolest car in two counties!
    Yep. Life is full of disappointments. So we dwell on the past, or we move on.
    I wanted to pay my power company for green power. They told me they don't have a green power program, because all their electricity comes from the Bonneville dam, except for a very small amount from wind.
  20. hobbit
    4,089
    469
    Bahstahn
    Look up "renewable energy credits". It's a bit of a shell game
    and rather intangible for the end subscriber, but it *does* push
    some numbers around in favorable ways and the hope is that it
    shows long-term trends that people are willing to spend their
    money on green sources.
    _H*
