Energy Saver A/S to be replaced by Defender
Discussion in 'Gen 3 Prius Fuel Economy' started by GaryD1, Jun 7, 2012.
  1. GaryD1
    GaryD1 Active Member
    302
    138
    Seagrove, NC
    Got exactly 1k miles on tires now. The temperature is hot here only difference, battery staying charged up. This last tank was 51.2. I just filled up all the way to the spout top, we'll see on this next tank. Yes if you are driving into a good strong wind or rain that will kill mileage also. I've never used normal mode so don't know about the difference in mileage, unless it accidentally got put in normal mode. I'm driving this weekend, I don't use cruise control like my wife does. I usually get some speed up on downhills and about speed limit when I top hills.
  2. GaryD1
    302
    138
    Seagrove, NC
    I just drove 105 miles today, the read out showing 55.2 so the tires are showing signs of improving. I can't do anything about my wife's heavy foot. She just drives the heck out of car. I can't blame the low mpg on tires. My wife usually drives about 2/3 of tank of gas then I use the other 1/3 and get mpg up. It was suppose to be my car when we bought it but the wife took it over. She drives about 400 miles a week to work, it helps the gas bill.
  3. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    Updates with my Energy Saver A/S tires
    I've got over 300 miles on this tank and my indicated MPG is 66.5. It is on par with what I was seeing with my heavily worn Yokohamas. Actually, my Yoko had me at an indicated 70 mpg a few times recently, but this tank has been adnormal, with trips to my Mother in Laws and extra trips to my parent's house, in which I don't get as good MPG as I do on my normal commute to work. I'll gas up on Wednesday or so and we'll see what Thursday and Friday have in store.
  4. GaryD1
    302
    138
    Seagrove, NC
    the most I ever got on mine was 62.5 on a 225mile trip, probably had a good tale wind then. How many mile you got on the Energy Saver A/S now? I got close to 2k now. Today its showing 53.7 for about 300 miles, and I brought that up from 51.3 today on a 100 mile trip. I tell my wife I'm getting her mpgs up.
  5. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    Gary, what pressure are you running your tires at? I'm at 46/44psi cold right now. I added pressure the other day because of colder temps but now that we're back in the 90s and 100s (tomorrow and next week) I am noticing how much easier it is to glide. I'm just curious to hear your thoughts on the ride and handling.
    I turned 300miles and was sitting at 66mpg but a couple of bad trips (non-commute) dropped me. I had to struggle to get back up to 64.5. I hope to bring it back up to 66mpg by the end of the tank. It's so tough when you hit 400miles. Those 10ths of a gallon are a struggle sometimes. LOL
  6. Codyroo
    1,826
    515
    Pleasanton, Ca
    OK, I filled up this morning. I was at ~570 miles and the HSI read 67.0 mpg (the tires were new when this tank started). Unfortunately, I don't have an accurate calcuated value because the gas tank overfilled and a little fuel spilled out (grumble). So, instead of being around 63+ calculated, it was 61.9 calculated. Assuming my next tank fills "normally", I can average the two (I didn't reset my B trip, just in case). I'm noticing that the car does glide longer and smoother than my worn Yokohamas and that they also tramline worse than my Yokohomas did (I never noticed it with the other tires, but definitely do with these). Fortunately, I don't hit much grooved concrete, so it isn't a big issue for me.
    My round trip to work today was 70.2 mpg displayed. After a trip to my mother in law's, the car is at 67+ mpg displayed with a little over 100 miles on this tank. I'm not seeing much of an MPG drop off with these new tires (if any). The car definitely rides smoother and has better grip than with my worn Yokos (no big surprise there).
  7. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    David, what do you have the tires at right now?
  8. Codyroo
    1,826
    515
    Pleasanton, Ca
    Currently running 44 PSI fronts and 42 PSI rears. They were initially inflated to 44/42 when it was 100F outside. When temps were in the high 50's/low 60's, I rechecked the pressures and inflated up to 44/42 (they were down about 3 PSI).
  9. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    That is what I am currently running. Or is it 46/44? Wait, I think it is the later. lol
  10. GaryD1
    302
    138
    Seagrove, NC
    running 42/40 tire pressure. I'm fixing to take a trip next Monday, about 450 mile. I think I will up the pressure like you have first thing Monday morning. These tire ride a lot better than the Yokohomas. I'm seeing better mileage now, last tank 54.5 mpg. I got to change oil this Saturday, using Mobil full synthetic 0w-20w.
  11. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    Nice. :)
    Make sure to check your oil and ensure they didn't over fill it.
  12. Codyroo
    1,826
    515
    Pleasanton, Ca
    Update time:
    I've driven 1153.9 miles and used 17.881 gallons on my last two tanks for an average of 64.5 mpg. When I summed up my previous 6 tanks (May 1 - last tank with old tires) my average was 65.0 mpg. I would like at least one more tank to draw some conclusions, because my first tank on the new tires was vastly overfilled, and I'm hoping I had a "normal" fill this time around. Assuming I get a "normal" fill up on my next tank, the overfilled gallonage will have been addressed.
    Observations
    The ride is smoother with these new tires. I can glide longer. There are roundabouts as I go home and I don't need to get up to the same MPH as I did with the Yoko's to coast through the roundabouts at a safe speed. While the overall average seems to have decreased by 0.5 mpg, I think this is within normal "noise" from different fillups (i.e. the error bars would be larger than the averages).
    At this time, I can honestly say there was no significant MPG decrease with these tires, and it is debatable if there is any MPG decrease at all compared to worn Yokohamas.
    When my Yokos had ~5,000 miles on them (June 2010) I averaged 59 - 60 mpg on my trips.
    28,000 miles (June 2011), I averaged 63 - 64 mpgs on the Yokos.
    50,000 miles (May 2012), I averaged 64 - 65 mpgs on the Yokos
    1,000 miles (June 2012) I'm averaging between 64 - 65 mpg with my Michelin's.
    F8L likes this.
  13. GaryD1
    302
    138
    Seagrove, NC
    I changed my own oil, the trip was 460 miles, read out was 62,1 mpg. I had 65,1 going to the coast and that dropped to 62.1 for total miles. Its got close to 600 miles on tank, need to fill up in the morning. I up the tire pressure 46 front and 44 rear.
  14. Codyroo
    1,826
    515
    Pleasanton, Ca
    OK, these tires do not suck (gas that is!)
    I'm at ~300 miles on this current tank. I've had more short trips on this fill up than I would normally. I started my weekly commuting with ~100 miles on the tank with a displayed value of 65 mpg. I'm now at 300 miles with displayed MPG of 69.0 mpg. Despite having a "bonus" 6 mile drive to the mall....let car sit for 2 hours....and then 6 mile drive home on Monday and a "bonus" 8 mile drive to get my hair cut....let car sit for 1 hour....before going to my parents, I've averaged a displayed value of 71.2 mpg. Cut these two short trips out and you could easily add another 1 - 2 mpg for my current tank.
    F8L and markabele like this.
  15. McLintock!
    McLintock! New Member
    81
    Baltimore-Washington corridor in MD
    I wish this tire came in 205/55/R16.
  16. Codyroo
    1,826
    515
    Pleasanton, Ca
    Final stats for this tank =
    671.2 miles on 10.017 gallons of gas for a calculated average of 67.0 MPG.
    For the first 3 tanks
    1825.1 miles driven
    27.898 gallons of gas
    65.4 MPG
    This is superior to what I was seeing with my worn out Yokohamas. Great tires for MPG's if you can still get them.
  17. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    67,000 miles now on the Energy Saver AS tire, 195x65x15 with 44 psi in all four tires (max sidewall pressure
    indicated). I will need to get new tires in about 5,000 miles or so. Tire wear is even
    and proper. The Energy Saver tire did increase MPG's about 2-3 mpg over the factory Yokohama Avid
    and the warranty of 65,000 miles is pretty close to what you can expect....
  18. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    Aww David. What happened?
  19. Codyroo
    1,826
    515
    Pleasanton, Ca
    I chickened out! LOL. I overfilled my first tank with these new tires (stupid pump didn't turn off). When I did my second fill up, I "assumed" it was a normal fill-up and compensated for the overfilled tank, but I couldn't be SURE that this was the case. Since my daily commute is nearly 70 miles, I have to be very sure that I can make it back to the station at home to fill up. I was sitting at 670 miles, so do I push it to 740 miles on a tank that I'm not confident is filled (using 11+ gallons of a 11.9 gallon tank) or do I just cut it "short" at a mere 670 miles and fill up.
    I opted for the latter. Besides, I figure I still have 2 months of good, warm weather driving to push it. Even still, as the tires wear, I may even beat this tank quite easily.
    For what it's worth, the 70.2 Displayed MPG is my new "high score" for the car. I suspect that this new high score won't last too long, however, but it is a good start.
    Also, as I logged onto Fuelly to record my new high score, I saw the 74.5 mpg for MarkAble on the sidebar. It stole my thunder even before I had thunder! LOL
  20. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    Costco is currently running the $70 rebate for Bridgestone tires AND $30 off tire mounting/balancing. This is quite a deal! I think this would make the Ecopia EP422 lower cost per mile to run than the Defender and could put it pretty darn close to the Energy Saver A/S since the Ecopia EP422 and EP100 start off so much cheaper even with the discounts.
