Ev mode
Discussion in 'Prius c Main Forum' started by Amacattack13, Jan 24, 2014.
  1. Amacattack13
    Amacattack13 New Member
    Downingtown, Pennsylvania
    Hi all! I have questions about ev mode for my Prius c. I just got the car in December and was using the ev mode frequently. It would work when I was going 25mph or lower as long as I wasn't rapidly accelerating or climbing a hill. Now it seems I barely get up to 10 mph before it clicks of saying "ev mode deactivated excessive speed". This happens when I break to come to a stop or when I slowly accelerate. I took it to where I bought it and the kid rudely told me to read my manual so I did and this isn't covered. I have lost 10 miles on my mpg and I have been doing the same commute since I got this car. Before I was getting 52.3 now I'm lucky if I get 40.
    Does this happen to anyone else all the time? I video taped it today for the car dealers to see.
    Thanks!
    Allison
  2. vskid3
    vskid3 Active Member
    773
    228
    Have enough air in the tires?
    EV mode is mainly to keep the engine from turning on if you're just moving the car around the driveway or parking lot. A practiced foot is much better, otherwise. The electricity all comes from gasoline in one way or another, and with all the loses from each conversion, its best to use it sparingly. Unless you're accelerating very slow because conditions don't let you accelerate any fast, you're better off using the engine to accelerate, then backing off and coasting or using EV when up to speed.
  3. usnavystgc
    3,159
    990
    Tucson, AZ
    Great advice vskid3.
  4. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    You are referring to EV only mode with a press of the button. This has a max "warm" speed of 25 and a max "cold" speed of 9 mph.
  5. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    (I am betting that it is colder than when it worked)
    EV mode is a 'gimmick' far more useful for parking lots than streets.
    Use of EV mode while driving will lower MPG, as you are converting motion to electricity to chemistry and back to electricity and then back to motion.
  6. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Note* this is only true if you drive farther than your battery.
  7. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    True if you never drive your Prius c more than 1 mile in your life, it never needs to recharge. Why would you buy a car you only intended to drive one mile?
  8. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Or if you only need EV mode for less than a mile. :rolleyes:
  9. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    If you EVER drive it again you have to recharge the battery, and your MPG will be less than if you never used it at all. You only 'win' if you never drive it again.
  10. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Ever is such a strong word... and false. If you use EV up to the top of a big long hill and then coast down the hill, you can recharge the battery back to full (given that the hill is long enough). :D Careful with your descriptors. :D
  11. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I do not live in the fantasy world where you can EV up hill.
    To the OP, aside from ztanoes, the rest of us live where EV mode is almost useless for driving, but great when parking. Use it when your preference is for quiet operation, not maximum MPG.
  12. vskid3
    773
    228
    If you EV to the top of a hill and fully charge the battery coming down, you've broken the laws of physics. Doesn't matter how long or steep the hill is, you'll always use more going up than you can ever regen coming down.
  13. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    I don't live in this world either, I was just pointing out that conditions exist that this could arise.
  14. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Eventually, yes. But in segmented drives, it is possible.
    I use mine when pulling in and out of my neighborhood. Works great, speed limit is 25 mph and when I leave in the morning I'm pulling out onto a road that is 50 mph so I'm using the engine anyhow. No excessive loss and it hasn't changed my mpgs one way or the other if my battery is fully charged or not when I'm doing 50.
  15. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    If it has not lowered your MPG, where did the energy in the battery come from? It HAS to use gas to make electricity.
  16. drysider
    drysider Active Member
    823
    336
    Liberty Lake WA
    To the extent that the engine runs to charge the battery, it uses gas...although even then, the Synergy firmware only uses excess engine energy. The battery energy reclaimed through regeneration does not have any gasoline cost associated with it. The process of burning the gasoline in the cylinders is not reversible and has not causal connection with whatever happens afterward. Using the battery energy is one of the best ways to increase your mileage. That is one of the main reasons highway mileage is less than city mileage....you do not have the opportunity on the highway to use the battery very much. By using the battery, I do not mean running in (push the button) EV Mode. You use it to extend your glide and to negotiate road conditions without running the engine. Generally, running in EV Mode is not an efficient use of the battery energy.
    coyote303 likes this.
  17. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Yep... and even full charged, running at 50 mph, I'm running with "gas"...
  18. vskid3
    773
    228
    So you're saying if you stop several times going up the hill, you'll be able to regain all that energy by going back down the hill? Because you won't. Start with a full battery (we'll assume this is a plug-in or full EV car that won't have a gas engine kick on) at the bottom of the hill, drive to the top however you want using that battery, and drive back down using regen, you won't have a full battery.
  19. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    If I'm at the top of the hill with an empty battery and go down the hill where I turn the car off, segmentally, this will be a full recharge at the bottom. That's what I'm saying.
  20. vernon birdman
    vernon birdman Active Member
    330
    141
    Vernon BC Canada
    Perhaps at the Magnetic Hill in Moncton, New Brunswick
