Finally, a usable though non-ideal iPod solution
Discussion in 'Gen 2 Prius Audio and Electronics' started by efusco, Feb 22, 2008.
  1. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    I've had several frustrations trying to get the ipod integration solutions to work. I've tried the DICE (currently for sale in the Private sales), the Scosche AXTIPA, an FM modulator...all failed to work properly.
    Finally I found ahttp://www.amazon.com/dp/product/B000IMFUEG?tag=priuschatcom-20 an ipod charger (uses connector on the bottom) and cassette adapter (uses mini plug). I used my DICE dash mount and the charger plugs into that with the wire from the cassette adapter going to the ipod directly. The wire from the cassette is a little ugly, but I hid the wire for the charger mostly behind the vent cover. So all in all it looks pretty decent and works though I have to access via the iPod itself.
  2. sparkyAZ
    sparkyAZ übergeek
    311
    Mesa, AZ
    Glad you finally found a workable solution, Evan! I used to use one of these in the previous vehicle that only had an AM/FM/cassette deck to interface to a portable CD player. You can at least get better audio from these than with an FM modulator.
    It's too bad Toyota didn't have a simple line-in jack on the 04/05 stereo. :angry::noidea:
  3. tkil
    tkil New Member
    158
    I used a cassette adapter + 12VDC charger on my old iPod for years -- almost three years, actually -- and was content.
    I'm trying out a DICE unit now, and while it's more than occasionally frustrating, I'm doing lots of long (multi-hour) drives, and once I beat it into submission, it behaves quite nicely.
    Still halfway think I should've gone with the VAIS unit to get a backup camera, but can't quite stomach the ~1k USD for a full rig at this point. And I've gone three years without the backup camera, so what's another few years? :)
    One thing I did notice with the cassette adapter was a bass emphasis, which I blamed on the inductive coupling. The DICE at least gives me line-in capability, and titles when it's not being temperamental.
  4. barbaram
    barbaram Active Member
    912
    70
    Trenton, NJ
    hopefully toyota is listening and ipod will be integrated in upcoming models
  5. Flying White Dutchman
    4,374
    313
    i wanted to post this cassette adapter :D haha remarkable that someone beat me to the same idea
    i only read about the expensive solutions and then i found a really cheap en good solution and wanted to post it and.... haha then this topic:D
    well soon i get one to:)
  6. efusco
    19,891
    1,194
    Nixa, MO
    At the time I didn't have an iPod and could really appreciate all the people bitching and moaning about the lack of an aux port for their MP3s and that were upset that the CD player wouldn't play MP3s. Now I understand!!:twitch:
    The Cassette adapter is not convenient and i'll probably only be able to make significant use of it on longer drives. But I usually listen to XM on my commute anyway.
    On thing I noticed is that base seems a bit more prominant than I'm used to. It may be my equalizer setting on the iPod, or it may be something with the cassette adapter itself. I'm curious to hear others' experience (Dutchman, you listening?)
  7. galaxee
    galaxee mostly benevolent
    9,810
    468
    MD
    i never remember to plug in my ipod for short drives anyway. our ipod adapter is typically only used on longer trips too.
  8. tkil
    tkil New Member
    158
    Evan, if you scan my comment a few posts back, you'll see that I mentioned exactly the same things (extra bass when coming in through the cassette adaptor). I just used the audio settings to compensate for it, -2 Bass made it reasonable.
    (I'm guessing it's simply due to the physics of the situation, with a coil of some sort being used to generate the magnetic field, I wonder if it imposes some sort of unwanted filtering on the signal...)
    But anyway, I don't think it's just you.
  9. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    Evan,
    I followed your odyssey trying to find a fully operational, easy to use, reliable iPod integration with the greatest interest. It seems that of all the posters on all the threads, you had tried most if not all of the currently available units. I had great hope that you would find The One. Thanks for your work on this, I know that it has been a frustrating experience
    I used a cheap generic cassette adapter in an earlier car. In that car the player had to be running for the signal to cross over from the adapter to the player. In time the wheels in the adapter started making swishing sounds which gradually got louder, and finally intrusively loud. It had to go.
    This is the $40 Belkin unit that I then bought:
    Belkin : Auto Kit for iPod w/ Dock Connector
    Not only does it charge the iPod, but it has a headphone jack. Radio shack sells a male-to-male connecting cable that is only 6 or 8 inches long. It makes a relatively neat setup in the center console. I've not had any humming problems, so perhaps it has the ground loop protection built in. I am very happy with this arrangement.
    Although I don't have one, this $30 Belkin item looks like a neat, secure way to hold an iPod in a convenient location so that the controls fall readily to hand.
    Belkin : TuneDok™ for iPod®
    I listen mostly to recorded books, so once I get started I don't much fiddle with the iPod controls. I usually keep the Ipod in the little shelf in the center console. If not there, then in the box below the radio.
  10. efusco
    19,891
    1,194
    Nixa, MO
    Thanks,
    If you notice the picture there are two parts to the kit I got...the charging cable that plugs into the base of the iPod (or, in my case, the back of the DICE iPod mount and the iPod rests on that to charge), and then the cassette piece that plugs into the mini-jack. I've got the cord for the charger hidden well behind the vent so the install is fairly clean. I don't have pics of the current set up, but there's one when I first got the DICE installed and it's pretty much what it looks like now just with the wire from the cassette to the top of the ipod. I can't post it from work but go to Flickr: Photos from efusco and look in the Prius collection and you can find it.
    Here's another thread about the DICE mount. http://priuschat.com/forums/audio-electronics/35700-proclips-mount-dice-ipod-cradle.html
    My wife uses a cassette adapter for her XM in her Highlander Hybrid and it's got a pretty annoying rattle too...I'll keep an eye out for that.
  11. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    My first post was a litle vague -- hadn't had my AM cafein fix yet.
    For other seekers of truth and wisdom, the beauty of the Belkin unit is its simplicity. The single wire from it to the docking port keeps the iPod charged and also routs an audio signal back to the charger. From the headphone jack on the charger a short male-to male connector gets the signal into the AUX jack. Neat, clean, and out of sight. (Right arm an' out of state! Dude, that's way cool.)
    Until a stand alone, plug-and-play iPod integrator comes along that has simple, intuitive controls, the Belkin unit offers an inexpensive, though far less than perfect, iPod hook up.
  12. koa
    koa Active Member
    980
    45
    Hawaii
    I also have this unit and just so you know Belkin customer service is also very good. My connector broke where it plugs into the ipod and they sent me another whole unit for free. I had to send my old one back at my expense within 20 days. It basically has a lifetime warranty.
  13. hasseman
    hasseman New Member
    Sweden
    This one looks like a nice solution:
    ULTIMATE IPOD
    Together with:
    LOCKPICK 3
    I have no idea if it is hard to install. Maybe someone else know?
    Would be nice to navigate the Ipod with the buttons on the wheel and to see the songs in the prius multidisplay.
  14. efusco
    19,891
    1,194
    Nixa, MO
    Oh, I see what you're saying..but I don't have an audio jack in my '04.:censored:
  15. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    Oops! Never mind, newbie error. But you did get the sauna didn't you?
