Gen III oil filter wrench
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jensent, Sep 2, 2009.
  1. Philosophe
    Philosophe 2010 Prius owner
    437
    72
    Montréal, Québec (Canada)
    I did my oil change this weekend and confirm: 64mm is the correct size. I bought the wrench on eBay. Works perfectly, perfect fit (was a bit hard to remove!).
  2. Grateful11
    Grateful11 Member
    107
    Central, NC
    215 in. lbs. is equal to 17.9 ft. lbs. That still sounds a bit tight but I'm sure
    Toyota knows what they're doing.
    As far as 64mm cap style oil filter wrenches, I think my liquid cooled
    JD rider uses the same size. The JD filter was on so tight from the factory I had
    wrap one layer of a paper towel over the end of the filter and then put
    the cap wrench on to keep it from slipping. Are these cap style tools
    measured across two inside parallel flats?
  3. texas112
    texas112 Junior Member
    45
    DFW
    I went to a Toyota dealer close to work today at lunch. I was picking up an oil filter and oil filter wrench. I know I could get them cheaper on-line but this was quick and easy, or so I thought.
    I had the part numbers but when the counter guy asked me what I needed I told him an oil filter and wrench for a 2010 Prius. He took off to the back before I could give him the numbers so I thought he knew what he was doing. He brought a can type filter up front and tried a few filter wrenches to see which fit. When I told him the filter is a cartridge type he said, "Oh no, this is what they all use." When I insisted the 2010 is different, he went to talk to a tech about it.
    While he was away I picked the TOY640 wrench off the display and laid it on the counter. He finally returned and had the correct filter, but now he told me I didn't need the wrench as there was a socket wrench type hole in the cartridge housing. I insisted again that the wrench was needed and he left to talk to the tech. He returned with a used wrench to compare to the one I had got and said, "Yeah, that's it." I guess now he's the expert :)
    I'm glad I have decided to do my own oil changes.
  4. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    At least they sold it to you. My dealership swore Toyota specifically forbade them from selling tools to consumers
  5. radiocycle
    radiocycle Active Member
    550
    78
    Vallejo, CA
    Man, that's pathetic! Would be funny if it wasn't true but... just plain sad!
  6. bps
    bps Active Member
    304
    119
    As a heads-up, the eBay seller that folks have been using has raised his price from $6.95 to $9.95. Shipping is still $4.95. Also note that you have to look around for the $9.95 price. He also has the same item listed for $17.95...
    Since I'm doing all of my own oil changes, I just picked one up at the $9.95 price.
    Bryan
  7. Vaughn
    Vaughn Junior Member
    37
    Lubbock TX
    First trip to my dealership went about the same way, wrong filter and can't sell tools to customer? Had to argue about the filter and just gave up on the cap wrench, I used amazon for that. Really sad situation!
  8. RadioZero
    RadioZero Member
    154
    59
    Orlando
    2018 Prius
    i tried my 65/14 i had "in stock" but it was too loose. i bought the OEM 64/14, it was snug but in a good way.
  9. esoniat
    esoniat Junior Member
    79
    Marietta
    Re: Gen III oil filter wrench, $21! yow
    I've been search this forum for links to wrench but only the expense ebay is available.
    If anybody knows where to not get gouged for a wrench please post it.
  10. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    I bought mine from this guy... its built like Fort Knox and well worth the money.... 10.00 bucks plus 4.75 shipping.
    3 people like this.
  11. esoniat
    79
    Marietta
    Thanks for the link. When I search for it it comes up $17.00, but with your link it is $10. If NAPA doesn't have it then you just saved me $7 bucks.
  12. windstrings
    6,280
    378
    Central Texas
    I'm not pushing for this guy as I don't know him and a cheap one would work just fine, but seriously, this thing has heavy welds and is built quite strong.
    I doubt its stainless but it looks like it!
  13. esoniat
    79
    Marietta
    I found these 2 for 5.99 plus shipping, guess you could sell one but
    they look really light duty.
    http://www.amazon.com/gp/product/B002INMQH2
    and the part number for the Asenmacher wrench is:ASTTOY640
    Best price I found was about $13 plus shipping it looks like it might be shallow good for a cartridge in a tight space but not for a canister since some bulged on top.
    Assenmacher Specialty Tools TOY640 - Toyota 64mm Oil Filter Wrench
    I bought the one on ebay for $10 if you follow the link provided by windstrings.
    The best search term form me has been "64mm 14 flute"
    Don't forget to buy your magnetic drain plug too!
    Now go get that dirty oil out of your car.
  14. Philosophe
    437
    72
    Hum... I bought a 14 flute and confirm it works.
  15. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    just ordered mine. Dealer couldn't fit me in when I'm off, so I'm doing, I guess.
  16. windstrings
    6,280
    378
    Central Texas
    Whatever you get... just make sure it has 14 flutes or its not going to fit.
    Copied from the ebay link I provided:
    BTW. the pics on that amazon link doesn't specify flutes "that I saw" and they do look very cheap and thin. If they are the right size I'm sure they would work though... if they don't bend where the socket extension fits.
  17. esoniat
    79
    Marietta
    Thanls for catching that, I corrected the typo.
  18. tumbleweed
    tumbleweed Senior Member
    4,067
    690
    Eastern Oregon
    I verified the torque values with the Toyota maintenance procedure, 18 ft/lbs for the filter cap and 27 ft lbs for the drain plug are the recommended values. My previous vehicle had a canister type filter with a plastic lid also and its recommended torque value was the same, 18 ft lbs. The 27 ft lbs for the drain plug seems a bit high to me but I think that is the value required to properly crush the crushable washer?
  19. Mr. Bill
    Mr. Bill Generation III
    86
    222
    Dunedin Florida
    I bought the proper size 64mm from .........
    Assenmacher Specialty Tools TOY640 - Toyota 64mm Oil Filter Wrench $12.78
    Product Id: ASTTOY640
    Internet Price = $12.78
    Suggested Retail Price: $15.95
    Availability: Usually ships the next business day.
    Price does not include Shipping ..... Shipping cost me almost as must as the wrench (bummer). There may be more cost effective solutions out there ..... but this is one option that I can speak about. Painless transaction, shipped within 24 hours of booking the order on line - received the wrench 4 days later ...... did the job nicely.
    Happy Hunting ! As they Say .........
    Mr. Bill
  20. Mr. Bill
    86
    222
    Dunedin Florida
    Mr. Bill :rockon: :rockon: :rockon: :rockon:
