Good quality aftermarket HID headlights
Discussion in 'Gen 3 Prius Accessories and Modifications' started by fairfieldwizard, Oct 1, 2010.
  1. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Ugggg 10,000K? Really? Return them and get the 5,000K bulbs. 10,000 is ridiculously purple and will not put out much light. In fact they will put out less lumens than your stock halogen bulbs. 10,000K = Ricer :rolleyes:
    Please Khoi, return them and get better bulbs mate. You'll thank me later. :)
  2. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    Ditto above. More ks less lumens. It's the lumens which enable you to see. I have 4500k bulbs in mine. beutiful white light. sure helps avoid kangaroos. They do as much damage as deer.
  3. lpe350
    lpe350 Member
    56
    32
    Long Island
    I got a set of Phillips D1S OEM HID bulbs (4300k) rebased from ebay years ago and used OEM Toyoto balllasts. The whole set cost about $180. They worked flawless for years but I just checked and no one does that anymore.(re-based bulbs)
    I've also had good results with Sportiva HIDs from Ebay. They're about $60 and have digital ballast and don't flicker.
    Stay away from the Zentec/$30 HIDs, you get what you pay for.
    Paying a bit more for QUALITY is the way to go, I've had cheap HID bulbs "pop" in the headlight leaving a mess of hot glass and fogged up the lens on a Miata years ago. (back when the cheap $30 kits used to cost $450 and the factory kits were $1500)
  4. SuperchargedMR2
    SuperchargedMR2 Diehard Rams Fan
    673
    179
    Vancouver, WA
    You all need to read this article. It has great info on light color, quality & HID info in general for anyone thinking of using HID bulbs. :cool:
    http://www.hidretrofits.com/
  5. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
  6. Southbound
    Southbound Member
    91
    29
    Palos Heights, Il
    I I don't mean to hijack this thread, I put this here b/c it's related . My apologies. My question is: now that i have solid info on HID's; what is better? 35W 4100 to 4300k HID's w ballasts or the addition of fog lights or both of those options.? I have a modest amount of $ I'm willing to spend and i do not like the lighting of my stock Prius II headlights. What are my best options that will imrpove night time driving re headlights with solid, clear light spray? Thanks and if i overstepped by tagging on...sorry
  7. Sfcyclist
    Sfcyclist Senior Member
    1,621
    375
    SF, CA
    what's a modest amount? With a HID kit, you won't need to use fogs lamps anymore.. unless you drive in a lot of fog?
    My set from KBcarstuff, the Xenon Depot 4.3k 35 watt system. No issues since I got them 2 year ago.. About $100 or less if you can find the discount code. H11 Volt HID Digital+ HID Kits
