Headlight Ballast?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by stevenspoint, May 3, 2012.
  1. stevenspoint
    stevenspoint New Member
    WI
    Hi All-
    I've been searching this forum trying to find a headlight troubleshooting guide. Most of what I find relates to replacing the bulbs.
    I have a 2007 and the passenger side headlight goes out almost daily. It will be on when I start the car, but almost always goes out before I get to me destination. My wife has been pulled over twice for it.
    I replaced both bulbs with Phillips, as suggested by many posts, with no luck. How can I begin to troubleshoot the ballast and ECU? Is there anything else I should look at? I hate to throw parts at it that cost hundreds of dollars.
    Is there a good source of these parts either OEM or aftermarket?
    Thanks!
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    Only the passenger side? Have you tried swapping the bulbs to see if the problem stays on the passenger side?
    Installing new bulbs leads one to assume that it can't be a bulb problem, but yours would not be the first bad new bulb.
    Tom
  3. stevenspoint
    WI
    I first swapped the OEM bulbs left to right and the passenger side bulb still would turn off. Then I replaced both bulbs and still the passenger side bulb goes out.
  4. qbee42
    18,058
    3,081
    Northern Michigan
    In that case it does sound like a ballast problem. Your only option will be to replace the ballast.
    Tom
  5. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    You can always install an aftermarket HID for less than $60.
  6. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    Where'd you buy them from? Is it possible they're fakes?
