Headlight out
Discussion in 'Gen 2 Prius Main Forum' started by Homermex, Nov 29, 2011.
  1. Homermex
    Homermex Junior Member
    High desert
    My 2006 Prius drivers headlight went out. But my main problem is that the headlight always has moisture in it. Even water when it rains. Is this a problem with this generation Prius? Other than replacing the entire headlight can anything else be done to keep moisture out? Thanks
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    Do you have HID headlights or standard? I've never had this trouble with my 2006 which has HID.
    Tom
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    You posted in GenII section but your profile said you have GenIII.
    GenIII doesn't have HID (LED instead) option. Your profile said you have a base model so most likely you have Halogen bulbs. Headlight supposed to be sealed so water cannot get in.
    Visually check if there is any crack.
  4. qbee42
    18,058
    3,081
    Northern Michigan
    But the OP's post clearly states 2006. This is a Gen II.
    Tom
  5. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    38
    Santa Fe, NM
    Sounds like it is either an aftermarket headlight already, or it is cracked. You might as well follow the procedure that has you unfastening the top part of the bumper and pull the entire headlight assembly out.
  6. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    If it is the OEM Halogen housing, make sure the rubber boot in the back is tightened (CW screwed) right.
  7. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Moisture in the headlight will often destroy your headlight. Thankfully the halogen bulbs are cheap. Unfortunately a new headlight assembly is not cheap so hopefully the back cover is loose.
  8. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    If you are going to remove it to investigate, might as well retrofit it with projectors. =D
  9. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Agreed! I almost pity those with stock headlights. Even the HID equipped Prii have terrible lighting compared to projectors.
  10. Homermex
    High desert
    Sorry didn't mean to be confusing. This is my wife's Prius. It has all the bells and whistles except navigation. How do I tell what kind of bulb it is? It is the original housing. The previous owner ( my brother ) took very good care of it. Is there somewhere I can get a head light that I don't have to take a loan out for
  11. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Check with Steve at Plug In Hybrid Electric Vehicle PHEV to see if he can supply a salvaged headlight assembly.
    JeffD
  12. seilerts
    3,326
    1,520
    38
    Santa Fe, NM
    Used headlights are very hard to find and usually not worth it. Most total-loss collisions are front-end, which takes out one or both headlights. So most wrecks in the salvage yard will not have them intact. The other problem is that they will be sold with leveling motor, bulb and ballast, making the asking price in the few hundreds, while you only need the housing/lens, which is about $260 online, and a bulb (Amazon, $48).
  13. qbee42
    18,058
    3,081
    Northern Michigan
    Gen II Prius with HID have factory fog lamps.
    Tom
  14. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Well, the good news is as stated before, Halogen bulbs are cheap. The bad news is until you replace the cracked housing, your gonna keep blowing bulbs. Halogens run HOT and you know what happens when you throw water on hot glass, it shatters!
    It might be expensive to replace, but your going to have to do it eventually. You might as well do it now, and save yourself the P.I.A. of replacing Halogen bulbs as well as knuckless !
  15. seilerts
    3,326
    1,520
    38
    Santa Fe, NM
  16. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    Maybe there was a subtle change to the assemblies starting w/07 and/or change in suppliers?
