Headlight problem
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by AlphaTeam, Jul 5, 2007.
  1. johnhnhn
    johnhnhn Junior Member
    17
    Albuquerque
    Toyota replaced both my headlight bulbs today. The dealer said that there was a service bulletin out on it (T-SB-0030-08). They used #90981-20015 bulbs. It must be a very common problem as even the courtesy van drivers were aware of it.
    Copy:
    T-SB-0030-08 Rev1 April 11, 2008
    HID Headlight System - Diagnostic Tips
    Service
    Category Vehicle Exterior
    Section Lighting (ext) Market USA
    Applicability
    YEAR(S) MODEL(S) ADDITIONAL INFORMATION
    2004 – 2008 Prius
    TSB REVISION NOTICE
    • May 12, 2008 Rev1: The part numbers referenced in the Note at the end of the Repair Procedure
    have been corrected.
    Any previous printed versions of this service bulletin should be discarded.
    Introduction
    The following bulletin is a supplement to the Repair Manual and provides diagnostics tips for
    troubleshooting “Low Beam Does Not Turn On (One Side)â€.
    Parts Information
    MODEL YEAR CURRENT PART NUMBER PART NAME QTY
    2004 – 2005 90981-20007 1
    2006 – 2008 90981-20015
    Bulb, Discharge Headlamp
    Warranty Information
    OP CODE DESCRIPTION TIME OFP T1 T2
    N/A Not Applicable to Warranty – – – –
    © 2008 Toyota Motor Sales, USA Page 1 of 2
    T-SB-0030-08 Rev1 April 11, 2008 Page 2 of 2
    Required Tools & Equipment
    SPECIAL SERVICE TOOLS (SST’S) PART NUMBER QTY
    Digital Multimeter
    (or Digital Volt Ohm Meter [DVOM] or Equivalent) 09082-00050 1
    Terminal Gauge Set* 00002-48937-01 1
    * Essential SST.
    NOTE
    Additional SSTs may be ordered by calling SPX/OTC at 1-800-933-8335.
    Repair Procedure
    NOTE
    If both low beam lights will NOT turn on, refer to the Repair Manual for diagnostics.
    1. Using the SST or DVOM or equivalent, perform a voltage drop across connector H5/H3 pins 1
    and 2.
    SST P/N 09082-00050 or equivalent
    • If reading is equal to source voltage, proceed to step 2.
    • If reading is NOT equal to source voltage, isolate and repair the trouble area in the headlight
    assembly power supply circuit.
    2. Using the SST, check the pin fit of the 12V connector at the HID ECU.
    SST P/N 00002-48937-01
    • If pin fit is good, proceed to step 3.
    • If pin fit is loose, repair or replace the connector and harness.
    3. Switch the HID bulb between the left and right side.
    • If the condition follows the HID bulb, replace the HID bulb.
    • If the condition does NOT follow the bulb, replace the HID ECU.
    NOTE
    • The HID bulb and HID ECU service parts for 2004 – 2005 model year are NOT compatible
    with 2006 and later model year vehicles. Installing a 2004 or 2005 model year HID
    Bulb or HID ECU on a 2006 or later model year vehicle may cause an intermittent
    operation/flickering of the HID bulb.
    • In most cases, when replacing the HID bulb, the HID ECU does NOT need to be replaced.
    In the event of HID ECU replacement, order the following part numbers: 81107-51050 (2004
    – 2005 model year) or 81107-47150 (2006 – 2008 model year).
  2. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    301
    Northwest VT
    2018 Prius Prime
    It has been said before, by me (possibly on this thread for all I know) and others:
    There is NO reason to pull the bumper off to replace the headlight bulbs.
    It isn't necessarily EASY due to the lack of room for your hands, but you can do it from inside the engine compartment in about 10 minutes after you do it slowly the first time to figure out what needs to be done. The most you have to disassemble is the air duct in front of the washer fluid reservoir and all that entails popping 2 of the plastic push fasteners. On the driver's side you can get a little extra room by removing the fuse box cover.
  3. warrior
    warrior New Member
    141
    Paso Robles, CA USA
    Gremlins?:eek:
  4. barbaram
    barbaram Active Member
    912
    70
    Trenton, NJ
    I can't believe they are not having a recall. I'm joining the club at 49,800 miles. The right side was replaced due to a hit and run. the left side is failing intermittently.
    Thank you PRIUS CHAT for the info!!!
    I filed with NHTSA and will be calling the dealer tomorrow about my repair!
  5. gcurtis42
    gcurtis42 New Member
    Las Vegas
    I was having this headlight problem. Fortunately I was still under the original warranty. (33,000 miles.) The dealership I purchased the car at just ordered me new HID's and everything seems to be fine.
  6. vettold
    vettold New Member
    I've been reading this topic for 18 months since I got pissed off at the toyota dealer. They wanted over 700 bucks for the two lights. So being pissed off for 18 months I drove around with one hand on the light switch while drive at night. I went to ebay as instructed on this site and purchased 2 lights from XEquipped@EBAY..
    Stan Didenko
    The price a whopping 88 bucks delivered to my door! I put them in and both worked. However after 3 hours the drivers side went out and I emailed stan and he said send the bad one back and I will send a new one. 10 days later the replacement came and has been working for 1 week. Toyota really dropped the ball on this one.
    Thanks to this forum I saved over 600 bucks!!!
  7. suebeegrl
    suebeegrl New Member
    I've been reading this topic for the past 7 months which is when I noticed the same problem with my 2006 Prius - driver's side headlight failing intermittently. I took my car to the Toyota dealer in May '08 and they said the sensor was defective and for $500 they could replace it. My car had 36k (past warranty), so I decided to wait. A month later I was in a car accident by an uninsured driver (side swiped) in the night time. The insurance company determined it was not my fault and paid over $5,000 for the repairs - which included replacing the leveler sensor attached to the rear axle. Unfortunately, this did not correct the headlight problem - which continues to fail; I was stopped by the police two days ago who issued me a warning about my headlight. I've reported this incident to the Toyota '800 number' and filed a complaint with the NHTSA. I'm hoping that the accident (which may have been caused by the defective headlight), will prompt a formal investigation and instigate a recall for the headlight controllers. I'll keep everyone posted if anything becomes of this.
  8. Ct. Ken V
    Ct. Ken V Active Member
    535
    57
    Bolton,CT
    suebeegrl,
    Your dealer is either clueless or a greedy BS'er. The sensor he claimed was defective has nothing to do with your HID headlights failing (turning off) intermittently. What a bad sensor usually does is tip the headlight aim way to low so you can only see about 20 feet ahead of you (but sometimes way too high) & either condition can happen without seeing any warning lights on the dash.
    Ken (in Bolton,Ct)
  9. twhittak
    twhittak New Member
    Central Pennsylvania
    I have the same intermittent problem with the HID headlight on the drivers side. The dealer thinks replacing the bulb might help but......It does not appear to be connection related but a problem in the bulb or control circuits? I will contact Toyota and the national safety board.
    Twhittak
  10. jimlyons
    jimlyons Junior Member
    36
    East Stroudsburg
    My dealer in Easton PA just replaced both bulbs - no charge! This is Dick Milham Toyota. Maybe give them a buzz and inquire as to their reasons for the free replacement - then tell your dealer.
  11. tmw
    tmw New Member
    CT
    Dealer replaced the driver's side headlight bulb and told me that they had called Toyota and found that Toyota was aware of the problem. Dealer hinted to me that I should contact Toyota and ask for a reimbursement of the nearly $400 cost to replace the bulb.
    I called Toyota and expressed by disappointment in their lack of quality and the danger created by the defective bulb. Wrote them too.
    They agreed to reimburse me.
    Suggest others do the same.
  12. ThePackage
    ThePackage New Member
    74
    I had the same issue with my HID and yes I have an '06 pkg.6. There is a lot posted on this and for me the dealer replaced, under warranty, the HID bulb. After over 1 year, the problem has not come back.
  13. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    Another tid bit for the drivers side bulb:
    Trick! After popping the fuse cover, you may want to remove the blue and green relays.. it will give your hand more room and thus more power! Steady pressure once it starts moving, when it stops.. wiggle it so it will pop loose.
  14. mataboombata
    mataboombata New Member
    I have joined the headlight club as well. 2006 Prius, 42k miles. Passenger side light going out, can turn it back on, but will go out again. Took it to the dealership, was told "it's not out now, costs $1200 to replace, wait 'til it's a real problem'. I got pulled over for a headlight out a few days later, that's what I call a real problem!
    I took it back to the dealership, the woman booking me in said "oh, yeah, we see that problem with the Prius". When I asked what "that problem" is, she said just what you report, intermittent headlight outages. I asked if it would be covered & she said "I'll see what I can do for you". Ultimately, both headlights and both computers were changed at no cost to me. Written on the invoice was "Goodwill for owner loyalty". I think it should have read "we better cover this one 'cause this lady is gonna make a big noise if we don't."
    I reported to NHTSA as well, maybe we can all get together & force a recall...
  15. windstrings
    6,280
    378
    Central Texas
    Goodwill... aren't they so nice!..... I can just bet you that if Toyota didn't pay for it.. there would be "no" goodwill!
    Maybe it would behoove someone to print off all 295 posts on the subject to bring in.
  16. jamiebball
    jamiebball New Member
    Reading, PA
    Just wanted to join the drivers side "possessed headlight" club. I've been reading this thread for quite some time since a few months ago somebody told me my left front headlight was out, but of course when I went to look myself or show others - tada! Both lights stay on. I have an appointment with a yota dealership this week (not where I purchased it though) and was told I was "lucky" because my car is still under warranty (it will expire later this month when I hit 36,000)
    Is there anything I should be telling the dealer specifically? Or should I just assume that he knows what this problem is? He told me they will replace both front headlights which should correct the problem. I've already reported it to the NHTSA and plan to call Toyota as well...It is unbelievable to me that a recall has yet to happen since there are hundreds of us with this problem! Guh!!
  17. studio253
    studio253 New Member
    Add me to the group as well. My wife noticed the driver side was out when we were in traffic the other day. I've got an 06 with 60k on it. It goes out from time to time and I just turn them off and back on and then they're both all set. I've now read through a bunch of threads here seeing that this is a common problem. I've got an oil change coming up and I'll see how well I'm treated when I bring it to their attention.
  18. GreenEarth
    GreenEarth New Member
    Add me to the list. I have a 2007 and my driver side light is going out intermitently. Turn off and back on and the light works. Of course I have 37,000 miles but I do have the extended waranty.
    Dealer said they were unaware of any headlight problem.
    Guess I need to call Toyota also.
    Greg
  19. GrayWolf
    GrayWolf Junior Member
    Somewhere, NC
    Adding my 2007 Package 5 to the mix. I've had the problem with both of my headlights. I'm taking my car in to the local dealership tomorrow morning to have them deal with this issue.
    I'm definitely relieved to know that I am not the only person with this issue. Thank goodness for these forums! :rockon:
  20. djkrs2
    djkrs2 New Member
    17
    Snohomish, WA
    I don't think there are any Toyota dealers that haven't heard of this problem. That's incredible that they would even try to get you to believe that. I'd print out a bunch of the posts and toss them on his desk and tell him that he's heard about it now!
    Dave
