How does it do in the snow?
Discussion in 'Newbie Forum' started by nissanaltimacrazyhorse, May 27, 2008.
  1. qbee42
    qbee42 My other car is a boat
    18,058
    3,077
    Northern Michigan
    The FJ's traction control is a different animal than the one on the Prius. Don't expect the same miracles with the Prius. All it does is cut power to both wheels.
    Tom
  2. MagneticGrayIndy
    MagneticGrayIndy 06Prius;94M Miata;65Rambler770
    208
    Indianapolis
    a couple of winters ago we got about 6-7 inches of snow (rare in Indy) and I could not get out of my driveway!! This car is relatively light and sits low.. we were like stuck sled.. Overall, I don't like the traction control at all.. but winters are not usally too bad here and we live in the city, so it does ok. I had a CR-V which was fantastic in the snow, but I remind myself they are two entirely different animals. I wouldn't trade my Prius for anything on the market right now. I just remember to shovel first!
  3. rxcrider
    rxcrider Junior Member
    37
    North Ridgeville OH
    What steel wheels did you find in the correct offset / lug pattern? Are they 15"?
    Oh and the people saying that wide is wrong are right so long as you are talking about snowy roads - I used to run 155/80-13 snows on my VW Jetta. If you are trying to take your 4X4 off road in the snow, go wide with low PSI to stay afloat.
  4. qbee42
    18,058
    3,077
    Northern Michigan
    Wide tires are good for floating, but floating is exactly what you don't want to do for normal road driving. Off road is a different story, although I've never seen tires wide enough to float on the snow we get around here - people use tracks for that. We used to run wide tires on our Jeep for beach driving, but they were not as good for winter snow driving. On the road you want tires to cut through the snow and get to the road surface below.
    Tom
  5. nissanaltimacrazyhorse
    37
    SPRINGFIELD MA
    Have you driven a fj in the snow? Thats exactly what it does cuts power to the wheels. Sometimes annoying but very useful in the same time
  6. qbee42
    18,058
    3,077
    Northern Michigan
    The FJ does that, but it also applies individual brakes to control slippage. The Prius can't do that.
    Tom
  7. rkskeet
    rkskeet New Member
    91
    State College Pa
    I replaced the OEM Goodyear Integrity tires with Goodyear Comfort Tread all season tires shortly after purchasing my Prius this past March. Therefore, I haven't had the opportunity to test the car in pure winter (snow) conditions yet. I live in central PA and will encounter snow during the winter. Generally, the roads are well plowed and treated when snow hits. But where I live is in a home development that gets plowed on the later side of the plowing schedule and the roads can pile up some snow amounts..
    I am interested if anyone has had any or some experience with the GY Comfort Treads during the winter season while driving their Prius?? Interested to hear your comments, thanks..
  8. hiremichaelreid
    hiremichaelreid New Member
    451
    Ottawa/Aylmer, Canada
    I
    I had same problem w/ my Stealth even though it was all wheel drive. High centred on a bank I misjudged. Car wasn't too bad with all seasons even though they were 245/45ZR17. (Continental Something Contact; rated very high 3 years ago for all season winter performance.)
    I've yet to hear of a Prius on studs. Of course the mileage would plummet but has anyone tried studs or chains for really bad stuff ? I've heard of some new type of studs that retract or something...
  9. nissanaltimacrazyhorse
    37
    SPRINGFIELD MA
    so lets say you get plowed in can you give it gas enough to get the tires to spin or are you basically screwed.
  10. rxcrider
    37
    North Ridgeville OH
    gbee - check out the FJ60 in this article for wide tires in the snow:
    OffRoading Three Ice-Caps
    I wouldn't want them on roads, but in deep snow, gravel beaches, dry sand, etc. oh yeah!
  11. qbee42
    18,058
    3,077
    Northern Michigan
    They will spin slowly if you floor the gas. It's kind of a cyclical "woomph, woomph, woomph..." sort of thing, where power is applied and the wheels turn, then power is cut as they slip. While you can make the wheels turn, you can't burn your way down to dry pavement, if that's one of your techniques.
    Also, be aware that older Gen II Prius (2005 and earier) have much fussier traction control. With the earlier traction control, the Prius gives up completely at the first sign of wheel slippage.
    Tom
  12. PriusSport
    PriusSport senior member
    1,498
    88
    SE PA
    My suggestion would be to lower tire pressures down to the 35/33 Toyota spec in the winter, to improve traction. The dealer set mine to 37/35 on delivery last week, and I put 38/36 in this morning. I suspect there is a tradeoff of traction vs gas mileage/treadwear with tire pressure. I would not go too close to the 44 psi cold pressure limit--you are probably approaching the strain limit of the cord in the tires. and could affect the adhesion of the steel/polyester cord to the rubber. Anything under 44 should be OK for safety, but traction may suffer over 40.
  13. nissanaltimacrazyhorse
    37
    SPRINGFIELD MA
    good responses, just filled up my fj for 70 bucks :eek::eek::eek: and i only got 300 miles out of the tank:eek::eek::eek: Looks like ill be joining the prius chat next spring or summer. Depending on how much and how fast the gas prices go up.
  14. stacyh
    stacyh New Member
    Chicago
    Good, except that I could never get out of my parallel parking spots after the snow plows went by because it's so low. The skid warning was useful.
