How much do backup cameras usually cost?
Discussion in 'Gen 2 Prius Audio and Electronics' started by Eug, Jul 21, 2005.
  1. Eug
    Eug Swollen Member
    970
    222
    Earth (for now)
    Technology
    How much do the backup cameras cost? $375 seems like quite a high price, considering that one would still need to get the ViewTech AV input.
    Has anyone installed this unit? If so, how is it, compared to the competition?
  2. Areometer
    Areometer Silver Business Sponsor
    578
    Tyngsboro, MA
  3. Eug
    Eug Swollen Member
    970
    222
    Earth (for now)
    Technology
    So not too many people have installed the Coastal camera yet?
    <div class='quotetop'>QUOTE(Areometer\";p=\"109191)</div>
    Thx. I'll check it out.
  4. Terry Dactil
    Terry Dactil New Member
    Melbourne, Australia
    Did mine about a week ago.
    NTSC - RGB Converter AUD 200
    Cable (from wrecker) AUD 5
    Camera AUD 70
    1/2 day wiring and installation
    Total AUD 275 or about USD 210
    Works great!
    Thanks to frenchie and brosnan for the info on how to do it.
  5. Eug
    Eug Swollen Member
    970
    222
    Earth (for now)
    Technology
    Thx. I'll check it out.[/b][/quote]
    Does the Toyota one require permanently removing that piece from the Prius, or can the cutout be replaced later? Has anyone matched it to the Coastaletech A/V input device yet? I didn't see any confirmation of this in that thread (although I can't see why it wouldn't work).
    Which parts did you use? That's a pretty good price for the camera (depending on the quality and how well it meshes with the Prius). Do you have any pix?
  6. c4
    c4 Active Member
    607
    51
    I really don't know why backup cameras (the CCD module itself) are so expensive.. You really don't need a super high res, power zoom camera to ensure you don't hit the car behind you or run over someone, so a cheap low-res CCD is more the sufficient for the purpose.. If you look on Ebay, you can find these modules listing for $20 and up, and the majority of them are quite satisfactory (many work quite well at night with just the tail light illumination, but some may required additional IR illumination for best results)..
    I got one as part of the package when I bought the rearview mirror/LCD monitor that I was initially using for my aftermarket NAV display (I'm currently using the Estima back up camera ECU to display monochrome on my MFD, but I'll be switching over to the Canview (for color and touch-screen access!) as soon as I build the cable). But anyways, back to the topic at hand: I paid around $100 for the whole kit: mirror/monitor and the nifty little CCD camera with all cables and hardware. The camera is a reversed-view type (ie, meant for use as a rear view cam) in a "bullet" type enclosure- cylindrical outdoor-rated aluminum enclosure with rubber O-ring gaskets, reasonable low-light capability that fits in a 1" hole.. I didn't want to drill a hole in my car, but I've tried the camera installed on a bracket in my back window, and it works fine.. If I had gotten the camera when I first got the car, I would definitely have installed it, as rear visibility in the Classic is much worse than my old Corolla, but I had installed an ultrasonic sonar backup assist, and between the backing-up experience I've gained since I've owned the Prius and the sonar assist, I found that in most situations, I didn't gain anything from the camera display, so I took it down and it's been sitting in the box ever since..
  7. Terry Dactil
    [snapback]155832[/snapback]​
    [/quote]
    I have now posted some photos and installation details in the File Library.
    There are plenty of suitable cameras available on eBay for less than $50.
    The hardest part was getting the bits to make the connecting cable.
