HOW TO DIY: JDM Folding Mirrors with Signals
Discussion in 'Gen 3 Prius Accessories and Modifications' started by sfv41901, Jul 1, 2012.
  1. Steve Robinson
    Steve Robinson Junior Member
    36
    44
    Mississauga, ON, Canada
    I know, it's embarrassing, but I spent all my money on the mirrors! No more pictures until spring.
  2. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Awesome work Steve.
    So I have some questions:
    1) Did u buy the complete kit? (Toyota Wish mirrors w/switch & controller or just the folding motors)
    2) Do u have any diagrams / pics of u wiring?
    I'm sure would like to see how u put together ur harness.
  3. Steve Robinson
    36
    44
    Sorry for the late reply. Too much going on....
    I bought the complete kit from MIT Accessories. Again, a HUGE thanks to sfv41901 and others for their directions and tips. If I could do it again, and could find them, I would try just the motors, but until you see what you have to do and see an actual motor, I don't think I would have known what to do with them. However, if you know a patient wrecking yard, I am sure you could find a late-model Sienna, Tacoma, Lexus Rx350 or LS450 that uses the same motor mount. Might be costly to experiment, though.
    I clamped my Wish mirrors to the bench, and wired everything up to see how the module worked - and it didn't - it would not fold or unfold with correct, double checked wiring with the supplied Wish mirror switch. I then noticed the different connector on the Wish OEM switch and that it did not have any night lighting. So thinking about the night lighting, re-wiring a connector and negotiating with MIT (who are very nice people, but in Taiwan), I decided to build my own.
    I didn't include the module design because it is flawed and in fact it has stopped working correctly. In haste I used a simple relay on the Dome circuit and that is not workable. The Dome circuit uses a variable current drain to brighten and dim the lights slowly. This causes the relay to chatter, greatly shortening it's life (mine has frozen). I am back to mirrors controlled by the ignition only!
    I have 2 new designs on the way. Both will require some soldering skills. I just finished a micro-controller module. Parts probably under $20. I did this because I was amazed that you could buy a micro-controller for $3.50! It works perfectly on the bench but it is cold here and I won't be able to try it on the car until the holidays. The 3rd design is done but untested. It uses a few transistors to replace one relay and to time-delay the second one. This might be a bigger module because of the discrete components.
    I should be able to post parts, circuit design, a code file and pictures before the New Year.
    eunique and Dylan Doxey like this.
  4. ucsmfu
    ucsmfu Senior Member
    1,498
    420
    canada
    will the module allow for easy install ?
    Will you be heading down the west anytime soon ?
    haha, I wanna get this folding mirror installed too :p
  5. Steve Robinson
    36
    44
    The module would not be any more difficult to install than the standard module - just one more pin for the Dome lights. If you've done the signal mirrors, the folding motor is do-able. I don't get to the wet coast much any more but I've got some air points if you need a hand! I will try and get close to pin-compatible with the JDM unit. I want to add a secondary relay that reacts to the Dome signal. I have more goodies I want to try that need a good dome current source.
    By the way, the standard module works fine (at least I am the only one complaining about an inop module). I think the 2012 uses the same unlit switch and connector as the Wish set, so your installation is more plug-and-play than mine would have been.
  6. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    My 2012 had a lit mirror switch.......still looking into getting the new 1 lit.
  7. ucsmfu
    1,498
    420
    canada
    that would we awesome :)
  8. Steve Robinson
    36
    44
    Sorry, I meant the 2010 that ucsmfu has. Yes, my 2012 also has a lit switch and one reason I did not want to retro it to the Wish switch. I tried to put some very small LEDs behind the Wish switch in the housing to at least light the perimeter of the 4-way switch but it was not pretty!
  9. Johnny C
    Johnny C Member
    162
    16
    Boston
    That video says it all. Amazing job. Looks better than some of the luxury cars.
    sfv41901 likes this.
  10. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    i put an important update in the 1st post
  11. bzyrice
    bzyrice Active Member
    805
    324
    West Palm
    Just had to say that I installed these today and these instructions helped ALOT!!
  12. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    The signals or the folding mirrors?
  13. bzyrice
    805
    324
    West Palm
    Just the mirrors.. Wish I purchased the folding mirrors.. Saving money for other mods though
  14. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Got ya........the folding mirrors ate coming up ;)
  15. bzyrice
    805
    324
    West Palm
    But without these tutorials it would have been a nightmare to find the wires!!
    I used almost every location you used for your wires.. Only ones I didn't use were the puddle light locations.. I used the blue wire in the a pillar and the red wire for the foot well lighting on the driver side.. I also didnt have the ground on the driver side so I just found a bolt that looked good and grounded my wires.
    But instructions to take everything apart helped too! Thanks again!!
  16. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    No problem. I'm glad they helped.
    Yeah. I found out afterwards that the red wire on the Blk plug at the footwell is a constant 12v.
    I tapped the blue wire in the A pillar as well.
  17. laola3
    laola3 Junior Member
    I just purchased new Prius III(CHEVAE4), added two seat heating and indoor LED light. Quite interesting with JDM or other folding mirrors(it's said prius use same mirror as reiz or mark-x). Any new KIT can DIY without break Toyota warranty(3Y/100KM)?
    Thanks again, ready for seat heating Q&A
  18. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    The only way this can void any part of the warranty is if it cause an electrical problem that the dealer must prove. They CANNOT void ur warranty just cause u added something to the car.
    Bullet Salvador likes this.
  19. ucsmfu
    1,498
    420
    canada
    Hey Sean, so with the 2010 models, is there something we have to do differently ? or are the steps all the same. I'm thinking of getting a friend install it for me or attempt it myself. Also what are the differences with using the extra accessories you bought as to not using those accessories ?
  20. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    For the 10-11 gen3 Prius, the mirror connector on the car plugs right into the mirror controller harness.
    For the 12-current gen3 Prius, the connector is different so it needs to be changed with the new connector & terminal repair kit. This change was due to the OEM mirror switch being illuminated.
    The other way u can avoid this would be to remove the connectors from the car & the controller harness & hard wire it.
    As for the other accessories......they are optional & not needed to complete the install.
