If you've lowered your Prius, then this thread is for you...
Discussion in 'Gen 3 Prius Accessories and Modifications' started by JFrentzen-closed, Jun 29, 2012.
  1. zeoth
    zeoth Junior Member
    43
    Well like I said, I don't expect everyone to agree with me but if you want proof that Toyota sell accessories that knowinly messes up your car, think TRD supercharger without the proper gauges, monitoring devices, and ignition control.
    Depending on the car, I've used H&R, Tokiko illumina, Tien coilovers and Eibach. I've been lucky to piggyback off what other track racers has experienced to allow me to save $$ trying different combinations. I have yet to see an OEM shock survive or provide optimal performance being lowered more than .75 inches. If this does, maybe I'll eat my words but I'm just warning you guys.
  2. Jae-DM
    Jae-DM Junior Member
    If you do end up getting the TEIN SA coils, I suggest you get stiffer rate springs from Tein and have your shocks revalved to match the springs. I found this out the hard way and am having to take everything apart and sent back to Tein for the revalve. The stock SA coils are just too soft, only 4kg spring rates front and rear.
  3. VegasPrius2010
    VegasPrius2010 Junior Member
    82
    26
    Yokohama-shi, Kanagawa, Japan
    Hey Thanks! for the input. Isn't the stock setup alot softer than 4kg though? In context to your suggestion, do you mean that they're too soft for more aggressive driving or too soft in terms of comparing it to stock? I'm asking because in the end, I'm looking to keep ride feel close to stock. It's mostly my wife who will be driving it.
  4. Jae-DM
    I have always liked a very firm ride and enjoy the constant feedback from the road through the suspension while driving. The stock Tein SA's are really good if you want a ride quality that is similar to stock if not better. When they are adjusted on full soft, the ride is very comfortable and yet still compliant as well. If you are looking for ride comfort and adjustability, I highly recommend the Tein SA coils. You won't be disappointed.
    VegasPrius2010 and Tracksyde like this.
  5. Jay J
    Jay J Active Member
    469
    253
    Torrance, CA
    I'm reffering to trim level 5..not the Plus package...
    The trim 5 Prius has different valved struts and an OEM rear sway IIRC
  6. ockevin
    ockevin Active Member
    493
    148
    Orange County
    nope...Level 5 is the same as all the others..
  7. Jay J
    Jay J Active Member
    469
    253
    Torrance, CA
    2010 Toyota Prius Specifications
    Rear had an OEM Sway for MY2010...I'm fairly sure I read the strut PN was different too somewhere..anyone have a 2010 brochure...Toyota shows 2 different part numbers for the front struts (per side)
  8. VegasPrius2010
    82
    26
    Sweet. Just ordered them. Hopefully they'll be here soon. Only thing that sucks is I'm waiting on the Cusco FSB and front lower brace to come in from Japan. Backordered till mid Sept, so I won't be doing the install till I have all the parts. After the suspension is done, it'll either be the Chargespeed kit, the Fledermaus kit, or the Kenstyle. I haven't decided which one yet....
  9. Jae-DM
    There is another Cusco chassis bar for the rear as well. I accidently stumbled upon it on juicedhybrid website. It doesn't show it as an item you can install on the Gen3. It's the rear bar for the prius V. If you look at the instructions link under the prius V rear bar site, it will also show that the 2010-2012 prius (ZVW30) is compatible with this bar. I've confirmed this with juicedhybrid and they are updating their website to reflect this change. The only downside is when installing the bar, you have to trim some of the plastic underneath. Other than that, the car feels better in the rear with this bar on.
    sfv41901 and VegasPrius2010 like this.
  10. VegasPrius2010
    82
    26
    Awesome. I'm gonna get one. I'll have all the Cusco bars installed. We'll be twinsies. :LOL:
  11. JFrentzen-closed
    JFrentzen-closed Junior Member
    43
    As long as we've been talking camber... I thought I'd hijack things to show off a picture of my other baby. Wanna talk about self imposed camber? Dropped in all 4 corners and narrowed up front.
    F8L likes this.
  12. floppyedonkey
    floppyedonkey New Member
    25
  13. ockevin
    493
    148
    Orange County
    Thats a collector piece....very nice and ageless...
  14. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I was about to ask if it was a '76.........then I saw ur sig lmof
  15. billydon
    billydon TSS Limited Edition
    Gun Barrel City Tx
    I'm not happy with the trd springs, too much gap in the front, not quite as bad in the rear.
    It makes the rims look smaller than they are
    It seems like mine sits higher than the others with trd springs. BTW rims are 18" w/ 225/40's
    Contemplating the Tein's or the Tanabe DF.
    I want it to have the stance of Ragz' 2010.
    Any opinions?
  16. billydon
    Gun Barrel City Tx
    Looks good Kevin, not happy with mine looks like its 3/4 inch higher than yours I think my trd springs have an extra half a coil! lol
  17. ockevin
    493
    148
    Orange County
    I too would like to go a little lower in the front.
  18. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    Figured I'd add a pic of the TRD springs with a 205/50/17 tire. For some reason I don't have quite the gap that Billydon has despite us having the same size tire diameter ( 25.1"). Both our tires are larger than the 215/45/17 (24.7") so the gap should appear reduced slightly.
    Front
    Rear
  19. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    I'm going to have to update these pics when the rain stops. The car has settled and I can't insert a single finger between the tire and top of the wheel well without hitting tread or going at an angle (rear). The front is about 1.5 fingers high. EEK! :ROFLMAO:
  20. Adam Leibovitch
    498
    102
    Is there a set of springs that will drop the back only and keep the front bumper exactly as high as it is now? Just adjusting the angle of the liftback.
    The front bumper is plenty low to the ground for me already. I would even consider raising the front an inch or so to fix the angle if thats a thing.
