Is Prius suitable for Pakistan?
Discussion in 'Gen 2 Prius Main Forum' started by Hamza Khalid, Jan 25, 2013.
  1. Hamza Khalid
    Hamza Khalid New Member
    Thanks all for the info. I have been doing research on the prius for quite some time and taking all the questions i had in account i think prius would be a good option for me to drive. The prius 2 Gen is available here for $16000 with all sorts of features while the cheapest local car is $18500 Honda City, it has 1300cc engine, only driver airbag and literally no body/chassis quality. The priuses available in Pakistan are used not reconditioned. And I guess I'll have to avoid driving in areas where there are large puddles of water. As for ground clearance, i just learned that the prius is a few centimetres lower than my own car Honda City so i shouldnt have much problem in driving on rough roads.
    Thanks Everyone!
  2. Hamza Khalid
    I want to know how much do the hybrid batteries cost? brand new? for a 2nd gen prius?
  3. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    Did a search at toyotapartsexpress.com (online discounter) on 2009 Prius and found this for a new battery (here, it's also possible to buy used, from salvage yards):
    HYBRID COMPONENTS / HYBRID COMPONENTS / BATTERY / BATTERY
    BATTERY Prius MSRP Core ? Online Price
    $2,588.67 1,350.00 $2,265.09
  4. Hamza Khalid
    Ok thanks a lot! I'll check the market here as well
  5. Hamza Khalid
  6. Hamza Khalid
  7. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    The length of the warranty varies by jurisdiction. In the US it isn't even the same in all states.
    You need to find out from someone who knows what the Toyota warranty covers in Pakistan. It may also matter whether the car was originally sold be Toyota of Pakistan or not. If you get a copy of the warranty it should say where it's valid.
    The 10 year 240,000 km hybrid system warranty is about the same as the warranty on new Priuses in California and some other states, so it's something Toyota has done in other places.
    You might start here.
  8. hsnmz
    hsnmz Junior Member
    74
    Pakistan
    Toyota Pakistan does not cover Prius as this car is not available in Pakistan. The only way to get a Prius in pakistan is by importing from Japan or UK etc. The car may be under warranty in the parrent country but once imported to Pakistan it won't be covered.
  9. Fubar1764
    Fubar1764 Member
    127
    Houston, TX
    Unless the car is only going to drive on paved areas. I'd get a Toyota HiLux diesel. Parts are plentiful.
  10. Hamza Khalid
    A friend of mine bought a prius. He had the shocks changed. He added shocks that increased the height 1" from the front and 1.5" from the back. Would that affect the running and performance of the car? Other than increase its ground clearance.
  11. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    Hopefully, someone who is more of a car guy than me will chime in, but you can find lots of posts here about people doing that to lower the car, just because they like that look. Don't know any reason you can't do the same thing in reverse. People raise trucks all the time. If done badly, I suppose it could have some effect on stability. Could also increase drag or wind turbulence when running on a highway, but probably not enough to worry about. I thought it was a bit more complicated than just changing shocks. There are also the springs and maybe the struts, but don't take my word on the mechanical aspects.
  12. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    Higher ground clearance makes aerodynamics worse. So expect a drop in fuel economy at higher speeds, but no significant difference at lower speeds.
  13. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I don't know about a Gen II but the GEN III comes from the factory with about 3/4 inch more ground clearance in some countries, usually countries with a lot of bad roads. You would also need a wheel alignment (primarily front toe and camber). My semi educated guess is that 1 inch would be OK with some acceptable reduction in stability and some small reduction in fuel economy that you would never actually notice while driving on rough roads.
    The suspension design is very similar to a Corolla, so you may be able to find out how well locally done suspension mods work on Corollas.
  14. Fubar1764
    Fubar1764 Member
    127
    Houston, TX
    Shocks and springs need to be changed at the same time. Springs affect the travel, and shocks dampen the bounce. If you want to get as close to the original .cd, raise the front and the back the same height. Raising the rear more will increase your frontal area and increase your .cd.
    Raising your car will raise the center of gravity. A 1" raise is pretty significant, as will the increase in clearance.
  15. hsnmz
    hsnmz Junior Member
    74
    Pakistan
    I did not get the original shocks changed. I got 1" aluminium discs (called spacers here in local market) installed between the rear shocks and the body. these spacers are shaped like the top plate of the shocks and have the holes for the studs. but it required changing the studs because the stock studs were not long enough to accomodate the 1" spacers. initially I was not very sure how much difference would these 1" spacers do, but as I have experienced these have provided good enough ground clearnace almost as much as our local Corolla.
  16. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Nice solution. Something most people in advanced industrial countries don't realize is how capable good mechanics in developing countries are. They are often more capable than the typical parts swappers we get in US shops.
  17. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Let's see a picture of your new vehicle in situ (y)
    xs650 likes this.
  18. Naveed Riaz
    Naveed Riaz New Member
    Rawalpindi
    Just signed up for this forum. I ve owned a Prius 2007 10th anniversary edition since Nov 2012. It did have low clearance but in Pakistan u have a solution for all auto problems no matter what car u have. I got spacers in the hind wheel springs only and it has worked. No more bothered by the speed breakers, the odd ones though still need driver skills. Flooding is not really a concern. Local mechanics r very talented and u can find maintenance support in all major cities. A visit to sultan ki khu in Pindi or Bilal ganj in Lahore is an experience u must have and rest assured there s no issue with the spare support or with the availability of hybrid battery. I ve driven Prius in Pindi, Islamabad, Lahore, multan and Karachi and never experienced bumpy roads that could give u a scare. Roads r wonderful and Prius gives u a great driving experience with excellent fuel economy. People have claimed doing 30+ km/l in city and just as much on motorway/GT road but I think 18-20 in city is what I get on the average. I drove to multan last year in summers and drove 120+ on motorway, 100-110 kph on GT road from Lahore to Multan. Prius gave me 19.0 km/l for the 1500 km (Pindi-multan-Pindi) of drive. I m very happy with my Prius and looking to buy the new shape inshaa Allah.
  19. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    The UK 10th Anniversary model was released in 2011. I'd be curious to see a 2007 10th Anniversary model. Is it a JDM model as they were the only country to officially have a Prius from 1997.
    So you know what I'm going to ask now :) Pictures?
    Talking of the serenity of hybrid driving, you might like the latest UK hybrid advert;
  20. Naveed Riaz
    Rawalpindi
    Priu
    In Pakistan only used cars from Japan r available. These r the JDM ones and that is why mine is a 10th anniversary edition, 10 years from it's date of launch in Japan. The sad part is everything is in Japanese and I ve been looking for a UK model which r rare to find here. I m trying to figure out how to post multiple pics. Hopefully I ve uploaded one successfully. Pl let me know how to upload multiple pics with a reply. Thanx
