Kensun HID Xenon Conversion Kit
Discussion in 'Gen 3 Prius Accessories and Modifications' started by torr310, Dec 20, 2012.
  1. Johnny C
    Johnny C Member
    162
    16
    Boston
    If one were to switch out the halogen projectors, does that involve baking the headlight?
  2. wotcher
    wotcher Member
    403
    97
    16
    LA
    yes, you need to bake or heat gun to soften up the rubber glue holding the casing together. its a enclosed unit. there are no holes big enough to fit the projectors through.
  3. Johnny C
    Johnny C Member
    162
    16
    Boston
    Thanks. That seems pretty involved. How different is a halogen projector from a HID projector?
  4. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    The main difference is in the bowl of the projector. The optics are different between a HID bulb & a halogen.
  5. Johnny C
    Johnny C Member
    162
    16
    Boston
    That makes sense. Thank you.
  6. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Here are a pic I took of a JDM headlight I was going to retro but decided to go another route
  7. Johnny C
    Johnny C Member
    162
    16
    Boston
    What's the difference between JDM and USM? I like the Buzz Lightyear. (y)
  8. ockevin
    ockevin Active Member
    493
    148
    Orange County
    JDm dont have the orange reflector on the side.
    sfv41901 likes this.
  9. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    That & the cutoff is the reverse of the US.
    JDM: --------\_______
    US: _______/--------
  10. mmccking
    mmccking Junior Member
    83
    San Jose
    Don't go MORIMOTO if you're just replacing the bulbs...they have the ground wire issue!
    I just did it on my new 2012 PiP based on a PC recommendation and assuming that I'm getting what I pay for, but without doing my own research. Bad me.
    The kit is great and the lights look absolutely fantastic, but the ground wire shadow is a BIG let down. The bulbs are of such high quality that trimming the tabs to get them to go in "upside down" would be difficult to do, at least beyond my craftsman skills. :(
    Xenonsupply seems to have the ground wire issue addressed.
  11. Johnny C
    Johnny C Member
    162
    16
    Boston
    Glad you said something. I was on the fence between the 2.
  12. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    Exactly what orientation should the ground wire be in to avoid 'ground wire shadow'?
  13. ny_rob
    1,968
    813
    L.I.- NY
  14. mmccking
    83
    San Jose
    The ground-return wire should NOT be at 12 o'clock when installed. The projector flips the image, causing the ground wire shadow to reflect onto the ground.
    Instead, the ground-return wire should be at 6 o'clock installed. Supposedly, this puts the ground wire shadow on top, above the light cut off.
  15. ny_rob
    1,968
    813
    L.I.- NY
    Sadly it looks like the Morimoto H11 bulbs (if this is an accurate photo of the product they're shipping currently) have the ground wire in the wrong position and need modification to prevent ground shadows:
  16. Johnny C
    Johnny C Member
    162
    16
    Boston
    Thanks for sharing. Now I just need to find some coupon codes for Xenon Supply :)
  17. ny_rob
    1,968
    813
    L.I.- NY
    Well, that's the pic from their website- I just got my Morimoto 4.3K bulbs yesterday, I installed them last night. I didn't note the position of the ground/return wire. If you can wait till tonight- I'll check tonight and report back on the current version they're shipping...
    FYI- this has nothing to do with the ground/return wire shadow issue- but I thought I'd mention the 4.3K Morimoto bulbs are really quite bright and a nice white color- not blue- like the cheap 4.3K ebay bulbs. For $40 for the pair if they last- I'd say they were a good value, especially if you don't like the blue tinge many (supposedly 4.3K) HID's have.
  18. Johnny C
    Johnny C Member
    162
    16
    Boston
    I can wait. Not in much of a hurry. I am not motivated to work on cars in the winter :rolleyes:
  19. mmccking
    83
    San Jose
    I got the 5K and they look great. A little purple on the fringes, but otherwise, they're very bright, except for the road immediately ahead of me :(.
    The photo above is correct. In fact, the orange gasket/washer was a bit too thick for the Prius, making the full-lock turn very difficult. I replaced it with the gasket/washer from my original stock bulb.
  20. Johnny C
    Johnny C Member
    162
    16
    Boston
    Any ground wire shadow issues?
