Keyless Entry Messed Up?
Discussion in 'Gen 2 Prius Main Forum' started by techogurl, Jan 4, 2005.
  1. techogurl
    techogurl New Member
    226
    Fayetteville, AR
    I'll give that a try tomorrow Frank.
  2. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    This may seem silly, but be sure you actually have locked the car, preferably with the black button. If it's not locked, SKS won't respond to open the door for you, nor will it light the dome light when you approach.
    Then again, you said you had problems even starting the car. Doesn't matter if door is locked or unlocked for that.
  3. techogurl
    226
    Fayetteville, AR
    I always lock my car as it's always parked outside...well excluding for when I happen to be inside.
  4. DRogall
    DRogall New Member
    maryland
    Thanks Frank! My keyless entry wasn't working suddenly either and your instructions worked for me.... except for one thing: button out = SKS on.
  5. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    The SKS button under the dash needs to be in the OUT position to work.
  6. PatTrim
    PatTrim New Member
    East Meadow, NY
    I was having a similar problem (it wouldn't open the doors but it would start the car without using the key) and I took it to the dealer about 2 months ago, whatever he did fixed the problem.
    Now I'm having the problem again. Neilther of my remotes work to open the car doors and many times, when I go to start the vehlcle, it won't start (I get the "key" symbol). It seems if I press the park button & then try the power button again, it will start. I checked the button under the steering wheel and it is out. My remote doesn't light when I press it.
    Does anyone know what this problem is caused by? I have a 2007 Prius with 80,000 miles on the clock.
    Appreciate any help.
  7. PaulHS
    PaulHS Member
    200
    SE PA
    If the light on the remote fob doesn't light, replace the battery in the remote. There are instructions around here for opening the remote.
