LA Times: Toyota US Chief Defends Electronics
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Patrick Wong, Feb 23, 2010.
  1. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
  2. robbyr2
    robbyr2 New Member
    1,198
    149
    Commerce City, CO
    They say they've done the tests but Ralph Nader and the Center for Auto Safety doesn't believe them. Other than the testing protocol, how do you provide data showing there isn't a problem?
  3. vegasjetskier
    vegasjetskier New Member
    269
    29
    East Coast of Florida, USA
    It is impossible to prove a negative.
  4. PriusSport
    PriusSport senior member
    1,498
    88
    SE PA
    I don't know what Toyota has been apologizing about.
    The Prius floormat is a bogus issue, the brake "problem" seems to be a quirk of regenerative braking that is a perception more than anything else, and the sudden acceleration/no brakes can't be reproduced on the Camry in independent tests by Car and Driver (3/10 issue).
    I'll repeat. Toyota has built the best reliability record in the industry with decades of
    safe and reliable cars. What has changed? The American car industry needs to be saved. That's what has changed.
  5. PriusSport
    1,498
    88
    SE PA
    I wouldn't trust Nader. He has lost credibility with his radical left anti-corporation politics. He's a real socialist--unlike those manufactured by the wingnuts out there.
  6. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    Precisely. That's the only thing I disagree with within that article.
    Toyota has been attacked in the hearings and the media with a onslaught of accusation. To me the onus for proof should be on the accuser.
    Wozniaks "problem" using his cruise control and a very questionable test by an "expert" on ABC which I thought was simple theatrics with intent to cause more sensationalism and fear aside, all I hear is "Could", "Might" "Maybe" and "Probably".
    You can't defend against accusation.
    Show me proof that Toyota's testing is not adequate, they evidently have done inhouse and independent testing of their own systems.
    And show me proof of a the existence of the problem.
    Anything and everything else just becomes empty accusation.
    It's cliche, but it then becomes the automotive world equivalent to a witch hunt. Accusation to which proof of innocence is not accepted or the standards of innocence are not revealed or defined is primative in it's unfairness.
  7. a1a1a1
    a1a1a1 Member
    144
    So Cal
    Intermittent problems are hard to reproduce and quantify.
    Here's a great test, and one that Akio Toyoda should order immediately:
    Every Toyota North America executive must drive one of the Toyotas reported with the issue INDEFINITELY.
    Then we will see for real if a problem is found.
  8. vegasjetskier
    269
    29
    Maybe they already do.
  9. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    What do you think every executive in NA is probably already driving? What would you drive if you were an executive for Toyota?:rolleyes: I would expect that Toyota would make a vehicle available to all of its executives.
