Lever Edge electrical switches & outlets
Discussion in 'Fred's House of Pancakes' started by Stevewoods, Jul 18, 2026 at 3:47 PM.
  1. Mr.Vanvandenburg
    1,359
    651
    2020 Prius Prime
    Everyone knows there can be many sockets on either 15 or 20 amp duplex circuits. Two 10 amp loads can be plugged into a single 15 amp duplex outlet. The circuit breaker sees no difference. The invitation is the same to do so. Then add an extension cord with three plugs on it and get three more invitations. Makes no sense to me, that having a 20 amp outlet on a 15 amp circuit poses any issue. But does make sense to me a 15 outlet on a 20 could.
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,033
    6,920
    Texas Hill Country
    As suggested conventional wisdom, "common sense" or whatever is sometimes wrong. Typical 20 amp appliance or garage loads are not series connected to other outlets. Multiple continuous loads will trip a 15 amp breaker if they reach 19-20 amps. Just not right away.
    Making an argument the electrical code and design engineering "does not make sense" is unlikely to hold up in court.
  3. Stevewoods
    Stevewoods Senior Member
    664
    1,259
    where I am
    Gosh. I solved my 20 amp issue, where I installed the 20 amp black outlets in the kitchen on what I thought was a 15 amp setup.
    As I noted earlier, I looked and one 20 amp circuit breaker was labeled kitchen. Just checked and my black 20 amp outlets are on the 20 amp circuit. Yeh!
    I do remember, when I had the kitchen remodeled some 18 years ago, the electrican was all flopdoddle over installing an induction cooktop. Induction appliances were sort of new to the home cooking scene and he was bathering around about how induction drew so much power, so I guess as long as the walls were torn to pieces, he ran 12 AWG to everything.
    You would think, just for safety, that nowadays, the code would call for 20 amp all through a house.
    Anyway, my black outlets are safe.
