Life Time MPG Average
Discussion in 'Gen 2 Prius Fuel Economy' started by Walt999, Jan 4, 2010.
  1. Walt999
    Walt999 New Member
    23
    New Mexico
    I see many posts that have a reference to life time average. Does this have to be calculated or is it buried somewhere in the MFD screen?
    Walt
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    I have to calculate mine because I did not think to leave the Trip B setting alone when I first got my car. A lot of people on here have never reset their Trip B display so this is their real time lifetime averages.
  3. jdchappie
    jdchappie JD on RR2
    78
    Southeast Kansas
    I use an excel spreadsheet modified to show the information I want it to calculate. I add other notations like oil changes, tires, and parts to the side of the spreadsheet. The information is next to the closest fillup which tracks the date and mileage. I made a column for the cents per mile also.
    I believe it started as a sample spreadsheet in the program. There is no lifetime average in the MFD. If you don't reset the mileage each fillup, it will reach a point where the mpg will not change due to the amount of data.
    I know some of the members post their numbers and log them on another website. Check their posts and see if that might be what you need. Jerry
  4. Walt999
    Walt999 New Member
    23
    New Mexico
    Thanks, I never gave it a thought that the memory would eventually be filled. Any idea of when this would happen?
    Walt
  5. barisaxy2
    barisaxy2 Junior Member
    VA
    I just posted a gallery showing my lifetime MPG. Like the others have stated, I used a spreadsheet to collect my data to generate these plots. Every time I filled up I wrote down the date, time, temperature, odometer, miles and MPG shown the display, and the gallons and cost from the receipt.
    After 170000 miles when I sold my 2004 for a 2010, I had an average of 49.81.
    Attached is a plot of my MPG data. More plots can be found in my 2004 Prius gallery in my profile.
    Peter
  6. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    IMO, only two numbers count: the miles driven & the gallons pumped. The computers will continue to compute & hold the lifetime average until they are reset or lose power. If you rely on the car's numbers then record them elsewhere before your data is lost.
  7. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    i track mileage driven, amount of gas put in, amount of money taken out (of my pocket) and what the computer says i should have gotten.
    i also separate summer and winter #'s since there is a pretty drastic change.
  8. jdcollins5
    5,131
    1,342
    Wilmington, NC
    Each time I fill up I record the odometer reading, the mpg and average mph from the MID, and gallons and cost from pump receipt. I enter these in a spreadsheet that calculates actual mpg, compares to MID mpg, calculates mpg error and percent error. I keep a running average of all of these calculations. I also enter the average temperature during the time between fillups. I then trend the calculated mpg, the MID mpg and the average temp.
  9. Walt999
    Walt999 New Member
    23
    New Mexico
    Thanks everyone. I was doing fine until I disconnected the 12 volt battery to add a rear power outlet and charge port for extended storage using a battery minder. I didn't give it a thought that I would lose the memory for the accumulated mileage.
    My overall average tends to be in the 48 MPG rannge (MFD) since I live at 6000 ft. elevation, have lot's of hills, and travel a lot to Tucson AZ. For Instance, going from Silver City NM down to Lordsburg (6000ft. down to about 4200), I get about 54MPG.
    coming back up it runs about 46MPG. Add in the additional 150 miles at 75 MPH plus wind plus some pretty good elevation changes plus temperature and I get about 51MPG going and 47 coming back home. I'm sure I would do great if I lived on flat ground!
    Walt
  10. CharlesJ
    CharlesJ Member
    467
    29
    38
    Monterey
    I am sure what he means is that when you have say 3000 miles in memory, or much more;), it will kind of stay the same as that is what is averaged against your current performance, that is. The more miles the less real response you will get. Try to average say a 50mpg average on 10k miles and the next tank is 48 for 400 miles.
  11. geognerd
    geognerd Junior Member
    37
    Elgin, Illinois
    What kind of difference are you seeing between the MFD and the calculated mpg? My spreadsheet shows the MFD on average reports "high" by 1.4mpg per tank. Of course there are variables introduced into the gallons used amount since I use different gas pumps and gas stations.
  12. jdcollins5
    5,131
    1,342
    Wilmington, NC
    I am seeing the MID is about +3 mpg high on average. This appears to be about normal for the 2010 according to other posts on this subject.
  13. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    2010's have demonstrated a greater difference between computer and pump for mileage. i am trying to correlate the difference by when one took delivery. not many here exhibit as wide a difference as i do on my 2010 which i received mid-May.
    it does appear that latter builds have narrowed the gap considerably. now on my 2006 and 2004, the differences were both just over a mile per gallon (see sig) so relatively accurate
  14. tedjohnson
    tedjohnson Member
    347
    72
    Greenfield MA
    My old 2000 Insight (261K, lmpg=62) had a lifetime mpg along with trip A and B. I guess my 2010 Prius has no such thing, ay least I can't find it . I guess the idea of using trip B as a lmpg will have to do, unless I am missing something.
  15. tonyrenier
    tonyrenier I grew up, but it's still red!
    362
    44
    Green Bay, WI
    As opposed to logic, I somehow started using trip A as my Lifetime guage. I didn't start till about 2100 miles, I have about 10500 on it now. My MFD is consistantly 2.1 mpg generous. So, for about 8400 miles the display is showing 54.4 (coming up since winter finally ended) 54.4- 2.1=52.3 mpg for 8400 miles. I obviously use trip B as my trip meter. Hope this helps.
    Tony Renier
  16. redrockprius
    redrockprius redrockprius
    167
    30
    Murray, UT
    Over the lifetime 21,500 miles on my 2007 Prius, my spreadsheet calculated average is just over 48 mpg. The averaged mpg displayed by the MFD is about 2.5% better, which would calculate to about 1.2 mpg optimistic.
  17. john1701a
    john1701a Prius Guru
    12,793
    5,275
    57
    Which confirms the margin-of-error is greater than real-world variation. I've witnessed that same thing on all 3 generations.
    In other words, after enough distance, the display of lifetime doesn't actually indicate much anyway.
  18. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    511
    63
    Did you mean the trip A does not roll back to zero after 10K miles for the 2010 Prius?
  19. fuzzy1
    10,332
    If you are counting in this information, consider recording it before each service trip.
    Some techs don't know how to reset the service reminder without also resetting Trip A & B. :mad:
  20. sandia
    sandia New Member
    Colorado
    My running average is 44.
