I have a 2004 Prius (package B in Canada) with the upgraded JBL sound system with 6-CD changer, but no Nav. What is the most reliable method of introducing either an AUX input or an iPhone or iPod input into the car? I read success stories about DICE and Grom, but in the next thread there will be just as many stories about flakiness and other issues about these units. What is the most reliable method? I'm not really heavily concerned about iPod integration. I want the AUX support more than anything. I'm using a tape adapter right now and it sucks, even though though it is better than unwired FM. I read something about wired FM modulators but I don't understand how those work. P.S. If just an AUX, I can get it any time. However, if for an iPhone, I might wait, as I'll probably get a new iPhone within the year.
The GROM is a little newer than the DICE and doesn't appear to have all of the bugs worked out yet. I think most of the problems with the current DICE may be with the setup and/or firmware of the Ipod. You can get the DICE on Buy.com for $100. If you only want AUX, you can get them as low as $45 on e-bay. The most bulletproof Ipod/Iphone adapter appears to be the VAIS but it's also the most expensive.
Hmmm... $45 on eBay is something I'd risk. Any specific models? Does Priuschat allow links to eBay for someone kind enough to provide a link? I'll look into the VAIS. However, I did a brief search they seem expensive, as you said.
So, I found one unit on eBay. About $65 shipped (to Canada) and all they say is that it may or may not work, even if the plug fits. OK. I guess I'll have to look somewhere else. On eBay it seems most of the other units are Grom and Dice.
I have the GROM aux adapter in my 2004 with JBL 6 disk changer and no NAV. I have only had it for a few weeks but it works well. Sometimes the stereo doesn't recognize it and it won't show up as an option (CD changer 2). Usually it comes back the next time I power up the car. Other than this, it works well and the sound is good. Very easy to install.
if you have an Aux input jack somewhere, the least expensive, least intrusive, cleanest sound, cleanest install, most reliable way to get audio into the in-car audio system is this Belkin unit. You do not get any control of the music source with this unit. You control the volume with the in-car volume control. In addition to the Belkin unit, you will also need a short cable with mini-headphone jacks on both ends-- 12 inches is the shortest generally available -- to take the signal from the Belkin to the Aux-in jack. Radio Shack has one for a couple of bucks.
