MP3 CD Player
Discussion in 'Gen 2 Prius Audio and Electronics' started by thegameispw, Jul 5, 2008.
  1. thegameispw
    thegameispw New Member
    I have a t3 prius (57 plate) and I just need a few answers from the wise forum.
    Does the T3 prius have MP3 support (I've made a Mp3 disc but it doesn't seem to work)
    If it does support Mp3 do I need to do anything special to the discs? Otherwise what is the best way to get MP3 support on the car?
    I would like to use the steering wheel controls and the touch screen - is the only way to pay for the 6 CD Option from the dealership?
    Also, I cannot find the AUX input - does it have one?
    Thanks.
  2. Bill Merchant
    Bill Merchant absit invidia
    4,096
    85
    :welcome: Welcome to PriusChat, thegameispw! You don't say where you are or what year your T3 is, so we're lacking some information (Suggestion: fill in your profile.)
    The 2006 model was the first year to support MP3 decoding. Base level models may not have the AUX port in the center console or CD players that support MP3s.
  3. thegameispw
    Its a 2007 car and Im in London, UK. I tried to use nero to make a data cd with mp3's on it and also tried to use nero jukebox to make an audio mp3 cd but they didn't work.
    any help??
  4. Bill Merchant
    4,096
    85
    Looking at Toyota's UK web site, it looks like the T3 has the single-disc CD player, 6 speakers, and no Auxiliary input. I don't think the T3 Prius can play MP3 CDs. For that you need a T4 or T-Spirit.
  5. pdhenry
    pdhenry It's HEEERE!
    406
    PA
    You shouldn't need to use Nero to make an MP3 CD. All you need is to make a data CD containing the MP3 files (and make sure the CD is finalized).
    If you're using Windows, the option to choose after you insert a blank CD is "create a data disk" rather than anything specifically to do with music files.
  6. thegameispw
    Tried it, does not work. Shall now assume that the T3 has no MP3 playback. Now my question shall be - how easy is it to fit an aftermarket stereo in the prius - in the space underneath the current radio. I would like to still use the touch screen too but that's not essential but the steering wheel controls to work would be nice.
  7. Bill Merchant
    4,096
    85
    This is the right forum to read. You're not alone in wanting something different. The model like yours is the base or package 2 in the US. There are a few options.
  8. thegameispw
    Right, assume I buy an aftermarket cd mp3 player. Does the volume controls on the wheel still work?
  9. ehsanvar
    ehsanvar New Member
    London
    i was looking to see i can do anything about aux port and i came across this page and saw that you had the same problem, can I ask what you did finally?
    I have a T3 prius 2006.... is there anyway to get the problem sorted? is that possible to add the aux port?
  10. Tornike Toloraia
    Tornike Toloraia New Member
    Batumi, Georgia
    I have a Toyota Prius 2007, on the screen it's always written: DVD cover is open. how can i solve this problem and where is DVD cover?
  11. dolj
    dolj Senior Member
    8,111
    4,127
    Wellington, New Zealand
    If you open the LH rear door and look under the front LH seat, you will find a black box. The box is the DVD player for the Sat/Nav. This has a slot opening that you should see. There is a little slider on the left of the slot which, when you slide it across, will close the DVD cover.
    Hope that helps.
