Neutral
Discussion in 'Gen 2 Prius Fuel Economy' started by maggieddd, Jul 19, 2005.
  1. maggieddd
    maggieddd Senior Member
    2,090
    Boston
    I've been reading a bit in here about switching your Prius to neutral. What do you gain by doing that? I know some say that you shouldn't do it and some say it's OK. I just want to know what you gain that way? I got my Prius for about 5 days now and I've been learning how to cruise, glide. I'm averaging about 55mpg so far, city highway mix.
    Maybe this is a dumb question, you can laugh at me.
  2. tomdeimos
    tomdeimos New Member
    995
    Lexington, MA
    Neutral isn't really neutral, since the car is always in gear.
    All you're doing is switching off the regen braking you get from lifting your foot off the accelerator, so you can coast farther before needing to burn more gasoline.
    As to using it I've found it helps a lot once in a while, but usually the hills are too small to bother with, or too big and I need some extra regen braking. So depends on what your terrain is like. Rest of the time I'm in too much traffic to slow on slight grades and need a little battery power even though it would be better mpg to coast.
    And using the accelerator to set no arrows works pretty good at least when going slow.
  3. jtmhog
    jtmhog Member
    151
    By gliding, you mean no arrow coasting. Im sure the 55+ gas saving fantics are doing a lot of gliding.
    The more gilding the higher the gas mileage.
  4. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    As Tom said, switching off the Regen allows you to coast farther - and faster. Many people have complained that the Regen braking slows you down faster than a regular car. And that's true. That's where the "no arrows" feathering (aka gliding) comes in. There are times when I want to coast to a stoplight without speeding up or slowing down. Depending on the terrain, I might have to use battery power to maintain speed or worse: run the engine. If I can't feather a glide, I'll pop into [N] and coast.
    Chicagoland is not known for its mountains and hills. There are not too many downhill Regen opportunities. But this also facilitates the use of [N] coming to stoplights. Once I have momentum, I can coast to the light and none's the wiser.
    I have yet to forget to put it back into [D]. Give it time. :)
  5. maggieddd
    2,090
    Boston
    well by gliding I mean I take my foot off the accelerator and then I press it very slightly. Not sure if that's what gliding means. When you switch to neutral you get no arrows? I've noticed I can make that sometimes when I remove my foot from the accelerator, would that be the same as switching to neutral? So is it good when you have no arrows??
    Sorry, I don't know anything, just learning
  6. Marlin
    Marlin New Member
    1,407
    Bucks County, PA
    I've found that the "no arrows" coasting that can be achieved with a very light touch of the gas pedal is a bit too hard to accomplish. The zone seems to vary greatly with the speed of the car and whether you are going slightly downhill, level, or slightly uphill.
    I happily settle for the state where it is showing power supplied from the battery (orange arrows from battery to wheels). This is easy to achieve at all speeds and with a light touch, I don't think it really drawing very much power from the battery. I usually have to press the gas pedal quite a bit further (relatively speaking) after first seeing the orange battery arrows before I have enough power to actually keep speed at 40 mph.
    The amount of power drawn from the battery is variable; the more you press the gas pedal, the more you will use. I would think that the amount drawn from the battery when you just barely exceed the "glide zone" is probably not enough to care about.
    So, to sum it up, I press the pedal just hard enough to make the green regen arrows go away when I want to glide. If I get orange arrows instead of no arrows, so be it.
    This is also easier to do by feel instead of staring at the screen. I press the gas pedal until I can no longer sense that the car is decelerating. If I then look at the screen, sometimes I'll see no arrows, sometimes I'll see orange arrows.
  7. Tideland Prius
    16,403
    Well neutral gliding and light-foot-on-accelerator gliding is the same. They both have the "no arrow" feature. You use neutral if say you'll be gliding for a long time and you don't want to constant have your foot pressing on the accelerator. It's also useful if it won't let you go into "no arrow" mode even though you know it can on your particular route. Just slip it into neutral. Also, I've found that slipping it into neutral during the warmup stage rather than lettting it regen will improve fuel mileage. If you notice, when you regen while in the warmup stage, the engine will charge the battery. Shift to neutral and the fuel mileage improves to 1.5L/100km instead of the usual 6.xL/100km. That way, you can let the engine warm up but if it wants to charge the battery, let it charge while you're accelerating.
  8. maggieddd
    2,090
    Boston
    OK, I understand what you said. Now, how do I switch to neutral while driving? What are the best geological features for Neutral usage? Will everything else work the same while in neutral, breaks etc? How do I switch back from neautral?
  9. priusham
    priusham New Member
    525
    Michigan - land of everlasting snowflake icon!
    Hold the shift joystick to the neutral position for a couple seconds until the [N] illuminates on the dashboard display.
    Neutral works best on long gradual declines - too steep a hill causes you to pick up too much speed so you might as well stay in [D] and charge the HVB.
    Everything else works as normal. Use [D] if you need to slow down. Don't use the brakes unless you have to, let the traction motor charge the HVB.
    To put car in drive, just move the joystick to [D] and watch the display.
  10. maggieddd
    2,090
    Boston
    thanks, I'll try it tomorrow on my way to work. I'll let you know how I did
  11. Ray Moore
    Ray Moore Active Member
    857
    52
    Texas Hill Country
    In neutral, only the friction brakes are used. Always switch to D prior to braking. If something happens suddenly, the friction brakes will panic stop the car just fine so don't worry about what gear you are in if something radical happens. I would not use neutral if I was in a position for something like that to happen anyway though.
    Having said that, I use neutral for around 10-20% of my commute. I don't use it above 62 mph. I use it automatically as if I was just shifting gears in a standard. Did I say it....... I love this car!
  12. maggieddd
    2,090
    Boston
    well, I have a 50 mile commute with gradual hills and slopes on a highway, not too many cars on a road in the morning. I am going to give it a try. Will report back
    thanks
  13. vande23
    vande23 New Member
    St.Paul, MN
    I read this topic this morning and after wards tried to go in to neutral a few times, with good success... it did seem to make the engine "kick in" a little harder so I am not sure I agree with the concept that its completely safe to have the engine go through this process on a regular basis.
    Any dealer reps or senior people have any opinion on this??
  14. Ray Moore
    857
    52
    Texas Hill Country
    Did you try this after the warmup cycle was complete?
  15. mehrenst
    mehrenst Member
    439
    San Jose, CA
    <div class='quotetop'>QUOTE(maggieddd\";p=\"108715)</div>
    I would suggest rather than diddling arond with going in to and out of Neutral that you practice a bit of accelerator feathering. Its a lot more useful and productive to develop an educated rightfoot than just poking the control stick.
    BTW, in many states it is illegal to operate your car in neutral and is considered as being technically "out of control".
  16. vande23
    vande23 New Member
    St.Paul, MN
    mehrenst,
    Thanks for the reminder about the laws - I think MN is one of them with that law. I will continue to try to get that feather method down, its not an easy thing to figure out. I think having the a/c on a lot is not helping either though... these darned 90+ degree HUMID days are not fun!
  17. jamarimutt
    jamarimutt New Member
    985
    The feeling that the engine "kicks in" when shifting into N is due to removing the engine drag imposed while coasting in D. I shift into N several times a day to maintain or gain some speed in long, gradually descending hills. Works great.
  18. Ray Moore
    857
    52
    Texas Hill Country
    Oh, I actually didn't realize it but when I shift in and out of neutral I feather the pedal as I do it. It is so automatic that I didn't even notice it.
    Feathering the pedal for a mile or so is fairly tedious. That's why I use neutral. on short stretches I just feather the pedal. I have some really long stretches where I can glide with the engine off. One stretch is right at two miles long. That's why I "diddle in and out of neutral" and "poke the control stick". How silly of me.
    BTW- If the curve sign says to drive 20 mph and you drive 21 mph, that is a violation of the law. Geez, I hope I don't get caught coasting in neutral. I wonder how that would work. The cop is hiding behind a tree and has really good binoculars. He waits till you pass and then reads the indicator on your dash. hmmmmm
  19. kingofgix
    kingofgix New Member
    387
    Littleton, CO
    A point about Neutral that I beleive is true, but didn't see adequately explained here. If you switch to N, I believe the regen braking is deactivated. Example, if you are coasting down a hill in N and gain too much speed, then apply the brakes to slow down, you have actually wasted energy by failing to recapture any. So it is only advantageous to COAST in N, but you begin losing the advantage the second you touch the brakes.
  20. tomdeimos
    995
    Lexington, MA
    Since neutral doesn't really take the car out of gear, it's sole purpose is for coasting.
    I assume that is why Toyota almost put the gear shift on the stearing wheel, or at least within easy reach.
    If you pay attention to silly laws I guess driving a manual shift car is llegal. You are in neutral between every shift or when you push the clutch down.
