new bike rack and hitch install thread
Discussion in 'Gen 3 Prius Accessories and Modifications' started by skey44, May 23, 2012.
  1. skey44
    skey44 New Member
    Clemson SC
    Ok I am a Prius NooB, but have done my research and after my first tank at 46.7 have the HSI reading 55. something on this tank after 400 miles. I have an Red 2010 and absolutely love it. I traded in a 2010 Ford F150 after feeling it in the wallet the last few months commuting about 40 miles a day. BEST DECISION ever . I am an avid cyclist and one of my main concerns was, "how am I going to carry these darn bikes?" Well my ticker got to tickin and I started a little research on bike racks for the Prius. My initial idea was to just stuff them in there, but so far I have one serious scratch on my 2012 Tarmac Expert from loading/unloading, and lots of dirt-debris-marring from loading my ginoourmous 2012 Epic Comp 29" (takes a lot of pilates moves and patience to get it in and out of there). And this is only a weeks worth!
    Obviously I needed a rack. Roof Rack... no. kills gas mileage and I am not trying to look cool like the wanna be frat boys and pretenders. Trunk rack... naw, they are just stoopid to take on and off and there aren't really any that fit the Prius perfectly anyways. Hitch rack... well... a hitch on a Prius? for real? This may void the warranty (i'm at 32, ish thousand) and decrease the fuel econonomy (weight and underbody aero)- and I don't want to do either. I guess you could remove the bolt on hitch when you took it in for warranty work, and maybe there is a light weight aerodynamic hitch alternative. The hitch mounted racks i have experienced before are heavy and not really what I wanted to use on my super efficient Prius, and at the same time all the hitches I started to research on the Prius were bulky, left little room for departure, and seemed a bit heavy to carry around everyday for the small hatchback.
    Products to the rescue. It seems some companies were listening as I thought and created products just for me and my new (to me) hybrid car. After lots of time, deliberation, deciding, and saving (top of the line doesn't come cheap). I have decided on an EcoHitch from TorkLift Central and the Kuat Sherpa from Kuatracks. These two products seem to fix all the problems I have seen with hitches on cars and hitch mounted racks over the years.
    I ordered today. They should be here Friday. I plan to take you on a trip from research to installation to use here on this forum. I'll let you know what's up when they get here. Maybe I can help you out and save you a little time when you decide to get a bike rack for your Prius and bikes (they'll thank you for not stuffing them in there)!
    Thanks,
    Scott
  2. BreitrthnU
    BreitrthnU Can you smell the premix?
    255
    50
    Tampa, FL
    congrats post some pics of the bikes, I see your a rodie and a mountain goat lol. My current ride is a Salsa Big Mama, Ill be getting a hitch rack soon cheers to less scratches!
  3. eseymour72
    eseymour72 Junior Member
    46
    Lincoln City, OR
    I just installed the Torklift EcoHitch 2" on my prius and am expecting the 1UP black 2 bike rack from UPS today.
    The Torklift hitch does require some cutting of some sheet metal on the rear of the car along with the plastic panel underneath. It'll take you about 3 hours or so to install.
    The end product is relatively hidden and very sturdy.
  4. d2mini
    d2mini Active Member
    519
    106
    Houston
    Sounds cool, looking forward to the pics!
    Why is the ecohitch called the ecohitch when the curt hitch only weighs 30lbs?
    And why does it cost nearly 3x as much?
    Those racks look nice. I looked at those but unfortunately the Sherpa doesn't fit a wide enough wheelbase for one of my bikes. And the NV is really cool especially with the integrated work stand, but I that sucker is too wide. So I went with the very compact Yakima Holdup instead. Same weight as the NV but much narrower when folded up. Too bad it's not as light as the Sherpa. ;) But it's definitely rock solid. No movement of the bikes when in use. Looking forward to your experience with the Sherpa.
  5. d2mini
    519
    106
    Houston
    Any updates? Was looking forward to pics.
  6. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
    I have the Curt Hitch with a Thule Helium. Really like that the Helium is light aluminum and can hold three bikes. Hatch opens without having to tilt the rack. Great combination.
    Kampy likes this.
  7. ImeanGreen
    ImeanGreen Prius v Five BP Brigade #236
    547
    73
    Somewhere out there
    Got my bike rack last week and tested it yesterday with 2 bikes. It hold the bikes really well. Got the Sportrack EZ2 premium bike rack. Not the best but does an excellent job. Comes equiped with locks for hitch and the bikes - no cables required.
  8. jac1
    jac1 New Member
    Hi.
    I am considering both the Torklife EcoHitch and a 1 up bike rack (single bike with an add-on) and was wondering how you would rate both products.
  9. eseymour72
    46
    Lincoln City, OR
    I think the Torklift hitch is probably the most stout available, it's the most concealed (only see the receiver) and I love the 1up rack simply for its all aluminum construction.
    The negatives:
    The Torklift requires some minimal cutting of the sheet metal
    I don't like the mechanism on the 1up for folding the rack up and down - it works but it's hard to engage.
  10. Blitzen
    Blitzen Junior Member
    30
    I have some questions about your (Pictured) Thule Helium Rack... 1.) I was wondering if you could give me a measurement from whatever point it attaches to the bike to the ground? (2) What part of the Bike frame does the rack attach to? The reason I ask is that I have a 36" (Not a typo-- its really 36") "Monster Cruiser" and I'm afraid the wheels may drag on the ground if the attachment point is not high enough? I've seen one other helium buyer griping about this issue. I have just purchased the 2" Torklift Eco hitch reciever. 4.) Is this compatible with the Thule helium? Looks like smaller than 2" on your rack? I like that you can still access the hatch so easily with the rack mounted. Thanks in advance...
  11. fuzzy1
    10,724
    Yes it is, that is my setup, those are items are compatible. I don't have the rack on right now to make the requested measurements, but am guessing that the bike's top tube will be around 42" a hair under 47" off the ground.
  12. Bye_G37
    Bye_G37 New Member
    Austin
    i also have the Thule helium - its pretty awesome in that it will fit both a class III and II hitches. I can wear it on my 4Runner or my Prius! Its also very light and easy to use. I do have problem when i haul my bike - the center tube on my bike is at an angle so when i mount it to the rack, the front tire hangs lower than back tire. i have a steep drive way and i discovered, real quick, that my bikes front tire hits when i drive up/down he drive way. Now i park in the street to mount/dismount my bike , i guess i could also remove my front tire in "hilly" conditions.
  13. peterjmc
    917
    189
    Clarksburg, MD
  14. fuzzy1
    10,724
    I put the rack on and pulled out the tape measure. The top tube cradles are a hair under 3' 11" off the ground.
  15. Blitzen
    30
    Thanks for doing that...My top tube is about 34" from the gound so, I guess I'll have one foot one inch of ground clearance available under my hanging wheels! Whew! Thanks man!
  16. Blitzen
    30
    Double post (deleted)
  17. Blitzen
    30
    I had accidentally posted this elsewhere but, since you guys are the ones who helped me out, here is the results of my research for your benefit....
    For you die-hard Hitch enthusiasts, I have some juicy information. I have been dilegently researching the
    2" class I "Stealth" Ecohitch (Ordered) and its compatibility with what I want to accomplish for my 2012 Prius IV. What I wanted to accomplish was to be able to rack a minimum of 2 bicycles and, trailer a miniumum of
    2 X 350lb (fueled)=700Lbs KTM 690 Enduro Motorcycles.
    As far as the bicycles, I ended up with the super light (26 pounds) Thule Helium 3 bike rack that is maximum load rated at 105 Lbs. (3 X 35 lb bikes) although the instructions state you should only load 2 bikes on a class I hitch. This appears to be as heavy as you should go on Tongue weight given that you have to factor in the leverage/ torque of the rack in addition to the weight. I got the Helium for the great discount price of 290.00 at autoanything (ends today 9/1/2012). The only derogatory comment I found online about the Helium was one guy claimed it was a lawsuit waiting to happen as he had the part that tightens into the reciever (the black piece?) fail on him (TWICE);However, he did not state how much weight he was trying to haul which may have played a role (after all, three of my beach cruisers would weigh in at 204 Lbs!). And in case you were wondering...the "Quality S" (NOT stealthy) hitch that seems to be unavailable right now, is in reality a class I hitch NOT class III as they claim ( see the bottom of instruction manual posted on-line where its says 200 tongue weight/ 2000 tow weight). For the motorcycle towing, I just talked to the guy who runs greentechnologiestransport.com. He travels all over the country pulling a three bike 400LB steel trailer (they sell) with two x 800 lb Harleys loaded (2000lbs) AND he get 60 MPG while towing it!
    He said a stock Prius only would get 30MPG doing this and, his easiest MPG fix was to change the transaxle fluid to "Royal Purple full synthetic". He said "I don't care what Toyota says", because it makes a world of difference.
    He also made some battery mods to get 60 MPG so, I didn't get how much difference the Tranny fluid by itself makes. He travels all over and said that he was comfortable trailering 2000-3000 lbs with a prius. He didn't seem to think I would have trouble doing any of the above with the class I "stealth" Ecohitch.
    Amen!
    [/quote]
  18. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
    My mnt bike is like that, so I have a holder that goes around the seat post and the handle bar stem to provide a straight mount point.
    Helium is a class iii, with a class 2 adapter that bolts onto it, so it will fit both.
  19. ToyotaSteve
    ToyotaSteve New Member
    Well the coolist and most asthetically pleasing solution for towing or for bike racks is with a comapny called Execuhitch which is now Invisihitch. They have a class 3 snap in hitch receiver which is completely concealed behind the bumper far exceeding the capacities of all of the Toyota sedans and small SUVs. It is inserted vertically when needed. When not used, you would have no idea the vehicle was equipped with a hitch receiver. I have seen it on a Lexus CT and there is no vsible signs of a receiver or bumper cutout. The owner of the CT just uses the hitch for a bike rack. They indicate they fit the Prius which is the same platform as the Lexus CT. You can see the modles they fit on their website. It is a little pricy when compared to a standard square tube receiver hitch but possibly worth it if you do not want a visible bar or cutout or if you have concerns about ground clearance. They have a square tube connector that also snaps into the receiver to accomodate bike racks and cargo carriers with square tube connections.
  20. mbtec1
    mbtec1 New Member
