New Metra surround install...
Discussion in 'Gen 3 Prius Audio and Electronics' started by rrolff, Apr 22, 2010.
  1. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    Just finished my install with the Metra 95-8226B surround kit. I went with Metra to check it out (more on a whim)...
    The kit comes with a few pieces, and looks like it may work for both a standard 1800mm x 100mm 2 DIN head unit, and would work for 200mm x 100mm Head units (for Europe, and for some Chinese brands).
    Simple to install, I like the looks where the '20 mm' fill is (less flat plastic).
    The kit is not textured like the Prius dash, and comes flat black (like the Scosche).
    From a fit standpoint, it is all plastic - and has some give in it - which may help to minimize vibration (???). Once installed, the radio is very secure.
    Cost was very reasonable ~ $22 delivered (it came in one day).
    A pic...
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Looks good. How is the FM reception? :)
  3. MJ225
    MJ225 New Member
    39
    Looks great. I'm guessing you're using the Toyota bezel part #55405-47080 and the side mounts from the Metra kit?
  4. rrolff
    1,610
    246
    So Cal
    My wonderful Toyota stock bezel from Europe (UK) went away with my car.
    This is the Metra equivalent of the Scosche...
  5. PaJa
    PaJa Senior member
    678
    114
    92
    Czech republic
    No, you can see the flat surface, the OEM part is textured.
  6. PaJa
    PaJa Senior member
    678
    114
    92
    Czech republic
    Congratulation for your new car and install. IMHO, the chinese HU design with buttons and volume knob was nicer.
  7. xxxx ne0 xxxx
    xxxx ne0 xxxx Junior Member
    Las Vegas
    How long did it take you to do the install and if I bought the same set of stuff you bought online, like the stereo, cables, housing kit, can best buy installers, or ultimate electronics do this exact mod you have in my car? - Prius 2010 II
  8. rrolff
    1,610
    246
    So Cal
    I do like the OEM look of the Chinese things - but functionally, this is so much better. Also from a sound standpoint...
  9. rrolff
    1,610
    246
    So Cal
    Any installer could do this - it's very basic. I'll write up my observations later.
    Some important points: While the GPS antenna worked fine on top of the HU, the XM got spotty coverage. Last night, I replaced the door speakers with Infinity reference components (6.5 and 1" tweeter). Amazing sound...
  10. bottomfeeder
    bottomfeeder New Member
    Chicagoland
    Got a part/model # for those speakers?
  11. rrolff
    1,610
    246
    So Cal
    Infinity Reference 6030CS - from memory, I got them for like $125
  12. banshee08
    banshee08 Member
    284
    72
    El Monte, CA USA
    Rolff,
    Did you get another Prius?? I had remember you install a pretty nice head unit from China that worked with back sensors??
    Anyhow, how do you like the metra kit. I am thinking about changing my Toyota Stock bezel to a scosche or metra soon since it is a pain to pull the head unit in and out with the UK bezel.
    -Chan
  13. rrolff
    1,610
    246
    So Cal
    I think the UK bezel looks by far the best. They are all the same in swapping HUs. In fact, I now hand torque the (4) 10mm bolts (with an extension) - it's so easy, and why torque it tight ???
    I think the Metra may look better - but that's a very subjective thing... Metra has a 200 x 100 opening - and the opening has a beveled look - so there's less 'dead space.
    Looks like Metra and Scoshce have similar dash look - so it is not exact.
    I do notice mine does not line up perfectly around the outside - haven't really played with it yet...
  14. jukeboy
    jukeboy New Member
    132
    SGV, SoCal
    where from?
  15. rrolff
    1,610
    246
    So Cal
    Not meaning to be a complete jerk (though really being one) - but please post your findings for a Google search (go to Google - enter the following - Metra 95-8226B - from the previous post you quoted). Please then post what you found here ;)
    It's always better to teach someone how to fish - then they can provide and prosper :cool:
  16. banshee08
    banshee08 Member
    284
    72
    El Monte, CA USA
    Give a man a fish, he can eat for a day...
    Teach a man to fish, he can eat for a lifetime...
    Now I just want to eat for one day.. J/K. I think I will go with the scosche just to see the difference. They don't look like each other from what I see in the pictures at each respective websites. I usually go with the scosche kits from experience. Your install looks nice.
    Another thing I like to turn people onto that want to keep the 6x9 size in the front door. I found the Eclipse SC6900 a very good component set that retail for $299 but since Eclipse is being close down you can find them for like $99 or less on ebay at times. I got a set cause I prefer silk tweeters over metal.. For the rear doors I am using the same Eclipse speakers but a 6.5" SC6500 also a component set.
    Just a FYI. Long time since I look in this part of the forums.
  17. Rebound
    Rebound Senior Member
    3,970
    2,623
    Portland, OR
    I asked my Toyota dealer to order the European faceplate kit. It arrived today (from Europe). Cost was about $68.
  18. rrolff
    1,610
    246
    So Cal
    Hrmmmmmmmm (Scooby Doo sound)...
    That's a good price if you got the UK surround. But you also need the 5mm filler on each side....
  19. banshee08
    banshee08 Member
    284
    72
    El Monte, CA USA
    Nice. I paid some $20 more after shipping from the UK. Should of done that instead. Note for anyone using the OEM face kit from UK, the mount for the headunit will have to modified to fit aftermark units. The angle of the factory radio does not work with the standard double DIN config. I want to change my out for that exact reason.
    -Chan
  20. GoldPianoGarden
    GoldPianoGarden Bling Meister
    841
    74
    98
    Brunswick, GA
    I am waiting for the FLYAUDIO headunit to get back in stock this week to buy one.... So, I just ran across your post and was wondering WHY you say that the functionality and the sound is better than a Chinese headunit like the FLYAUDIO.... Thanks, Barry
