New Owner: Squeal and Alignment issues
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tucka20, Feb 16, 2012.
  1. tucka20
    tucka20 Junior Member
    UK
    new to the forum so, a bit of background in order.
    I'm from the UK and have just bought a 58 plate (late 2008) Prius T-Spirit, 32k miles and with a 12 month used car warranty from Toyota Dealer in Leeds, England. These are a couple of issues I am having (car was bought 7 days ago, issues appeared after a couple hours of driving home from dealer)
    • Engine Warning Light on. Diagnosis says P0138 and P2195 relating to fuel mixture and 02 sensor. If codes are cleared, they reappear when accelerating quickly uphill etc
    • Wheel alignment issues. I have to have the wheel around 15 degrees to the left when driving to go in a straight line, getting worse at higher speeds.
    • Squeak/ Squeal when driving. This happens very intermittently below 35mph. Sometimes when braking, but mostly through normal driving.
    I bought the car 200 mile away and took it to my local dealer 3 miles away. They told me that the car should have been fully checked and not sold with these issues and the dealer contacted the other one 200 mile away and they categorically refused to pay for any repairs but I have been told the warranty will not cover it.
    I am paying for the wheel alignment as it is driving me crazy as it is only £33 ($50) but where do you think I stand with the other issues? Is there anything to do to prevent the squeal for example? It is cold here at the moment and there is grit on the roads so that could be an issue.
    Sorry for the long post but I really could do with some help as I have just spend £9000 on this car and am left with a car in worse condition than my old one.
    Thanks a lot for reading.
    Jordan
  2. cnschult
    cnschult Active Member
    772
    97
    Michigan
    First go to a brake shop for a free brake inspection. In a traditional car the rotors can last a long time and you change the brake pads frequently. The Prius is not a traditional car, many people here can drive over 150K on the original pads, however because we use our traditional brakes very little our rotors get rusted to hell, the brake shops will tell you how many mm is on the front pads and rear shoes and if the rotors are rusted though or not, and pay them for the following 2 services: lubricate the front caliper slides and clean&adjust the rear drums.
    Cleaning the brake dust and adjusting the rear drums always gets rid of the low speed choo choo sound I get at low speed, I do this every 40-50K miles. I find priuschat users always jump to replace the wheel bearings too quickly. Why spend hundreds of dollars if $30 can fix it. The caliper slides will dry out over time, especially in dry winter air, and you're going to want them to work in an emergency stop so its worth the small pocket change to have them lubed.
    This will probably translate to twenty pounds (is it spelled quid), money well spent in my opinion. You will need the front end alignment as it sounds like the previous owner probably slid on ice and hit a curb pretty hard which isn't covered under warranty. If it doesn't get rid of the noise than you can always than have the wheel bearings replaced. Do it yourself, after all, Jeremy Clarkson says, "How hard can it be?"
  3. trev.dowle
    trev.dowle New Member
    UK
    These defects may or may not be covered by the warranty, only you can judge that by reading it. HOWEVER, the car should absolutely NOT have been sold in this condition. If these faults appeared on your drive home from the dealers, I would have turned around and taken the car back!
  4. cnschult
    772
    97
    Michigan
    I think he bought it from a person, not a dealer, in America we call this a private party sale. The seller gets more for the car than he would trading it in (more work though) and the buyer saves money over buying from a dealership at retail price (more risky though, as this guy is finding out)
  5. Britprius
    Britprius Senior Member
    5,194
    1,924
    Herefordshire England
    The OP clearly states he bought it from a Toyota dealer. In the UK we have trading standards law covering guaranties and that is the rout I would be taking,also if there are braking problems it is against UK law to sell an non road worthy vehicle and with emissions problems it should not have passed an MOT. It is not reasonable to expect the guaranty to only work at the place of purchase
    The UK Prius does not have drum brakes. Tracking is strait forward as with most other cars, but a zero point calibration needs to be carried out on the steering as well. In the UK this can only be carried out generally by a dealer. The warning lights issue will be under Toyota's 100,000 mile 8year highbrid cover any dealer should sort this out FOC.
  6. Britprius
    5,194
    1,924
    What area do you live in and witch dealer have you taken it to for the diagnostics.
    Check the air filter "very easy to do" as it could possibly be blocked.
    I have the same model and year as you.
    Ask the dealer near your home how long since the last trouble code was cleared "this information is stored by one of the ECU's in the car". If a code was cleared recently this shows that the selling garage knew of a problem, and just cleared the code. The ECU stores this as distance travelled since code cleared.
  7. Britprius
    5,194
    1,924
    Tucka I should have welcomed you to Priuschat.
    Do not blame your problems on the car, they are great cars. I would get in touch with Toyota UK and explain the problems you are having with the selling dealer, after all you are only just out of the three year bumper to bumper guarantee, also buying from a main agent the car should come with a 12 month Toyota guarantee, and have been inspected to Toyota standards. Good luck and let us all know how things work out.
    John
