Nighttime Map View
Discussion in 'Gen 2 Prius Audio and Electronics' started by xian, Oct 25, 2006.
  1. xian
    xian New Member
    Hello All,
    I did some searches and looked in the manual but have not found the answer to my question.
    The first time I drove my 2006 at night, the navigation screen turned black and the roads were shown in white. I thought it was pretty cool because it minimized screen glow in the darkness.
    Since that time, 4 months ago, I have not seen it again.
    How do I change the map from one view mode to the other?
  2. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    There are a few things to consider.
    1) it only happens when you turn your lights on.
    2) if the interior lighting rheostat wheel (left of the steering wheel) is cranked and clicked all the way up, the MFD will not switch into night mode.
    3) the MFD has an internal setting that allows you to define that it never switches into night mode regardless of the headlights and the rheostat.
    It's most likely one of those three.
    If it's not, you need to stop driving your car immediately because it's very likely that a pack of ravaging trolls have tripped the light fantastic in your car rendering the MFD unfathomable.
    Good luck with that. :D
    ...and by the way, welcome to Priuschat!!
  3. xian
    xian New Member
    #2 is the winner.
    Thought maybe the trolls had done their thing and was ready to pull out the didgeridoo and move to the Seventh House.
  4. TonyPSchaefer
    14,816
    2,499
    66
    <div class='quotetop'>QUOTE(xian @ Oct 25 2006, 11:17 PM) [snapback]338418[/snapback]</div>
    I'm really glad it didn't have to come to that.
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    <div class='quotetop'>QUOTE(xian @ Oct 26 2006, 12:17 AM) [snapback]338418[/snapback]</div>
    Maybe the trolls turned the interior lighting rheostat wheel. I hate it when they do things like that, although their fingers are usually too big for little controls.
    Tom
  6. Cheap!
    Cheap! New Member
    1,157
    <div class='quotetop'>QUOTE(qbee42 @ Oct 26 2006, 08:22 AM) [snapback]338528[/snapback]</div>
    It could have been a gremlin. Sometimes they come with the car from the factory. A good way to tell if you have a gremlin is if your car suddenly dies at stoplights. Just keep listening for your engine and if it suddenly stops before the light turns green...You've got a gremlin.
  7. aaf709
    3,862
    2022 Prius Prime
    Another possibility would be if the "Day Mode" button was pushed when you bring up the Display screen.
