Planning to install a Pioneer Appradio 4 in my 2009 Prius...
Discussion in 'Gen 2 Prius Audio and Electronics' started by Dutchman2000, Apr 29, 2015.
  1. Dutchman2000
    Dutchman2000 Junior Member
    Glenview, IL
    Hello-
    I am planning to remove the factory radio and install an Appradio 4 in my 2009 Prius, here are the parts I am getting.
    Metra 70-8114
    Metra 95-8240B
    Metra 70-1761
    Metra ASWC-1
    Is there anything else I need or any tips before I start?
  2. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    751
    Delaware
    use solder and shrink tubing on your wiring connections for a permanent trouble free install is the only advice I have. good luck!
  3. SageBrush
    SageBrush Senior Member
    11,627
    2,532
    Southwest Colorado
    Seconded!
    I installed an alpine ILX-007 and rear camera into our Honda Fit recently. There was too much noise for the camera to work properly until I soldered the connection.
    I had to learn to solder for that project, and I consider it time very, very well spent.
  4. colmenedo01
    colmenedo01 Junior Member
    HSD
    hello, I have proposed the same thought, though my prius installed navi + IPA + bluetood and fear of losing the right to replace pad sound system controls steering wheel, someone might say if lost? greetings !!
    E
  5. caymandiver75
    caymandiver75 Member
    192
    97
    Northern VA
    2019 Prius Prime
    subscribed for updates.
