post pics of your prius w/ rims!!
Discussion in 'Gen 2 Prius Accessories & Modifications' started by mrplease, Sep 8, 2008.
  1. drew935
    drew935 Member
    168
    22
    Nor Cal
    /\/\ true but they are not hubcentric and are not light. They came with my car and I changed them to STI BBS forged wheels.
    I stuck the scion wheels on my wife's car for 100 miles. Onto the next set of wheels.
  2. MarvinHC
    MarvinHC Junior Member
    49
    Europe
    Toyota Rims taken from Celica T23 16&x 6.5 Tires: Michelin Energy Saver 195/55/16 91V [​IMG] [​IMG] Uploaded with ImageShack.us
    ryostyle likes this.
  3. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    It looks good, Marvin. :)
  4. sidecar
    sidecar Member
    342
    44
    Australia
    yeah the rear arches fill out nicely
  5. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    '08 Barcellona red with powder coated OEM Touring rims:
    Base color, metallic coat, and clear top coat. ~$650.
    Work done at EastCoast PowderCoat, North East, MD.
    What's not to like? :cheer2:
  6. MarvinHC
    49
    Europe
    Thanks, I actually like them so much that I have bought a second set for the winter tires. Luckily they go really cheap on Ebay :)
  7. MarvinHC
    49
    Europe
    Yeah, they have a slightly different offset (39 compared to 45 on the stock rims) and therefore bring the wheel slightly further to the outside which further improves the look IMHO :D
  8. drew935
    drew935 Member
    168
    22
    Nor Cal
    /\/\ Look good Marvin. What's the weight on the wheel and tire combo you have?
  9. MarvinHC
    49
    Europe
    Just took one of the summer wheels in the garage and put it on a scale
    (I used a bathroom scale with and without me so it will not be 100% accurate but should give a good idea)
    The total weight came to 16.6kg so around 36.6lb - a bit heavier than the stock 16" but not by much (probably also not helped by the fact that I have 91 weight index tires instead of the stock 87)
  10. drew935
    drew935 Member
    168
    22
    Nor Cal
    That's good to know Marvin. My next setup will be around 28lbs with tires. 16x7 et40
  11. MarvinHC
    49
    Europe
    Wow! Do you fill helium in the tires? :p
    Seriously, which rims and tires do you have that are so light?
  12. drew935
    drew935 Member
    168
    22
    Nor Cal
    lol. I don't have them yet. Planning on getting Rota Slipstreams in gunmetal 16x7 et40 which weigh 14.5lbs and I will probably mount Toyo's on them.
    The car is my wife's and we use it mostly on the weekend and once a week. So I don't want a stiff sidewall and the Toyo's are LRR's I believe.
  13. MarvinHC
    49
    Europe
    Very nice, but I had a check: Here in Europe they cost about 150 Euros a piece :eek:
    Same here, it's mainly my wife's car and I wanted to get a new better look on a budget (you can get a set of 4 of these Celica rims in good condition on ebay for around 100 Euros), so I am happy.
    What I am still curious about though is:
    If your rims will be 14.5 lbs, that only leaves 13.5 for the tires which sounds etremely light. Which Toyo's are these?
  14. sidecar
    sidecar Member
    342
    44
    Australia
    Slipstreams in 16x7 should come in at 13.9lbs ea
    16" Wheel weights - Mechanical Database
  15. MarvinHC
    49
    Europe
    Just checked and according to Rota's European webpage they come in at 5.95 kg which would make it 13.1 lbs only (!)
  16. PhazonPhobe
    PhazonPhobe His name is Sora
    221
    26
    28
    Fontana, CA
    I kinda like this. I wonder how they would look in white...
  17. MarvinHC
    49
    Europe
  18. PhazonPhobe
    221
    26
    28
    Fontana, CA
    That actually doesn't look too bad. Only thing really holding me back is the fact that they're only 16's. I'd really like to go with some 18s. =\
  19. MarvinHC
    49
    Europe
    You must have great roads where you live. If I could I would even go to 15†for more comfort, so many potholes...
  20. MarvinHC
    49
    Europe
    @drew:
    did a check on the net about Rota. They look good but type "rota quality" into google.... not so encouraging for me!
