Prius economy sucks
Discussion in 'Gen 2 Prius Fuel Economy' started by V8KILLER, Mar 10, 2009.
  1. V8KILLER
    V8KILLER New Member
    Port Townsend
    I have lately been averaging about 22 mpg, (far worse than my Camaro) and recently I have considering swapping the v8 from my Camaro into my Prius, also for obvious performance gains also. Is there another way I can increase the economy of my Prius, like a supercharger or a turbo?
  2. jdenenberg
    jdenenberg EE Professor
    3,910
    1,910
    Trumbull, CT
    2020 Prius
    LE AWD-e
    TROLL ALERT!!!
    It is virtually impossible for a Prius to get less than 35 MPG, even for a single tank.
    JeffD
  3. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    I'd love to see a Prius done over Big Daddy Roth, "Rat Fink" style:
    http://priuschat.com/forums/attachment.php?attachmentid=13546&d=1236686620
    It would play hell with your FE. But what the hey, at 22 MPG you
    seem to have discovered a way to totally negate any benefit from
    the HSD.
    Get rid of that stupid HV battery too. The way you're driving the
    car, it's nothing but dead weight.
    Hope you can post pictures soon.
  4. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    Just to keep things interesting, I'm not going to clean up this thread.
    V8Killer, I would like to hear how it is that you managed to average such dismal mileage. Additionally, I would be interested in seeing your schematics on how you will:
    1) fit a V8 into the hood space of a Prius
    2) couple the V8 to the Hybrid Synergy Drive
    3) prove that you're not just a troll
  5. EZW1
    EZW1 Active Member
    722
    81
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    My first guess would be a lead-foot driver. If you constantly push the accelerator pedal the electronics thinks you need lots of power and gives it via the ICE.
    Try backing off the pedal and watch your instataneous fuel economy go nowhere but up!
    If that doesn't work for you, dump the Pri and go drive that Camaro.
  6. Genoz World
    Genoz World ZEN-style living
    797
    La Canada
    V8 - put a turbo, supercharger and a FOGGER system in. NOS that is. :p
  7. danl
    danl New Member
    231
    Boston, MA
    Yup troll... He posted the same question in another form in the newbie forum.
    Maybe he's driving with the handbrake on. :-D
  8. pickjs
    pickjs New Member
    Calgary
    my related question is that after my first 3 weeks i am averaging 33 mpg. i have a 6 mile commuter each way so there is a lot of stop and go but i would have thought it would be higher? any ideas? the weather is cold (calgary, alberta) at the moment but it has me worried as my old 98 civic was getting about the same. thanks
  9. hyo silver
    hyo silver Awaaaaay
    15,260
    1,598
    off into the sunset
    Cold weather and short trips tend to reduce the mileage. You could try blocking off part of the grille to keep the car warmer. There are several threads here about it.
  10. magruder
    magruder Average Member
    145
    Colorado
    22 Miles per Gallon of What?
  11. danl
    danl New Member
    231
    Boston, MA
    Pickjs, is it a brand new Prius? Where are you reading the 33mpg from? I can think of a few reasons for the subnormal mpg:
    1/ New prius, not broken in yet. Still getting alot of friction from wheels, joints and tires.
    2/ If you're reading 33mpg from the efficiency screen, that figure depends on when the counter was last reset. If you picked it up from the dealer and never hit the reset button, the number is going to probably start off very low but gradually increase to the true value over time
    3/ 6 mile one way commute might be too short for optimal mpg. Considering the frigit climate in calgary, it might be that the engine doesn't fully warm up until you're practically at work. Do you typically let the car warm up?
    4/ Check your tire pressure
  12. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    http://priuschat.com/forums/fuel-economy/14701-new-owner-want-mpg-help-read-first.html
    and
    http://priuschat.com/forums/knowled...f-you-can-do-improve-your-winter-mileage.html
  13. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Six miles is too short for good economy for anything other than an EV or a bicycle.
    Tom
  14. The Tramp
    The Tramp Italian Prius Expert
    368
    45
    Turin, Italy
    2020 Prius PHV
    Nobody saw the clip where those AHs of Top Gear got 17.2 miles per UK gallon?
  15. dogfriend
    7,512
    1,188
    Carmichael, CA
    Didn't the jerk from Top Gear average 17 mpg in a Prius by driving it at top speed (105 mph)? You would have to drive at least 85 or 90 mph to average 22 mpg.
    Edit: Doh! The Tramp beats me to it.
    My lowest tank ever was 40.8 mpg (per the MFD) and that was the original tank off the dealer lot.
  16. bestmapman
    bestmapman 04, 07 ,08, 09, 10, 16, 21 Prime
    1,289
    242
    Kentucky near Cincinnati, OH
    Hi pickjs,
    A 6 mile communte is not good, so you will have to work a little harder to get into the high 50's or 60's. Here are some suggestions.
    1) Learn about the warm up stages and how they operate. Then you will be able to work aroung them, as the first and second 5 minutes that the car is on are the worst for fuel economy. Here is a link to learn about the stages
    2) Learn how to P&G (Pulse and Glide). This technique is the most effective in maximizing fuel economy. Here is a link on P&G
    3) Install an EBH (Engine Block Heater). This will allow you to start the Prius significantly ahead in the warm up procedures and timed/temperature cycles.
    4) Install an EV Switch. This will allow you to P&G gefore you get to Stage 4. I have found that on short trips, using the EV switch as an engine off switch allows me to P&G in stage 2 and 3 as if I was in stage 4. Note, do not use the EV switch to drive in EV mode, as this will deplete the SOC (battery) and cause you less fuel economy as you will have to recharge the SOC at some point.
    5) Install a grille block for the cold and cooler temperatures. Because the Prius engine is off a significant amount of time, it is hard to warm up. Also, after it is warmed up, the engine will quickly get cool again if a prolonged downhill or stop is encountered. The grille block helps this tremendously.
    6) Buy and install a scanguage. This allows you to monitor several different items, but most importantly, water temp., RPM, IGN, and TPS.
    If you can master these items, you should be able to put up high 50's or low 60's MPG. To get higher than that will require a bit more knowlegde, skill, and dedication.
  17. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    22 miles per Gallon of hair spray for his mullet, of course...
  18. darelldd
    6,057
    389
    Northern CA
    My best idea is to try the same commute in any other gas car and report back with the mileage you get. NO car will get good mileage on short, cold trips.... except an EV, as has already been pointed out. ;)
  19. The Tramp
    368
    45
    Turin, Italy
    2020 Prius PHV
    They did not drive it at top speed, that track is slow therefore the engine was always ovverrevving but the speed was low.
    I drove the car at full speed on german motorways for 400 miles, did not finish the tank (2 bars left) and recorded a pleasing 7,0 l/100 km (34 MPG)
    Wonder what the BMW M3 would have done under the same condition? :p
  20. efusco
    19,891
    1,194
    Nixa, MO
    I can average 60mpg on the 5 mile run to my kids' daycare easily...even in winter if I use my EBH. And there are no less than 4 stops and up to 7 depending upon the time and traffic.
