Prius shifting problem
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Harrywalpole, Jun 10, 2015.
  1. Harrywalpole
    Harrywalpole Junior Member
    2008 Prius(130K) miles sometimes will not shift from Park to either D or R but will only go to N. The emergency brake light is on when this happens (brake not on). Usually after shutting down and restarting it clears and works correctly. any history of this
  2. JC91006
    16,923
    8,634
    check to make sure your 12v battery is in good health. Meaning the voltage reading should be above 12.5volts
    52,683
    does it normally shift to d without foot on brake?
  4. Harrywalpole
    No
  5. bisco
    52,683
    then it might be your 12 volt. put a volt meter on the jump point under the hood in the morning before turning on the car.
  6. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    I'd measure the battery right away cause if its dying, you want to hit the parts store (if they even stock a prius battery) before it closes. but don't assume the battery is ok if your initial measurement seems ok. you need to load test the battery to be sure. but if it reading like 10 volts, replace it asap.
