Proper Charge By Dealer?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by carlbarry, Dec 28, 2011.
  1. carlbarry
    carlbarry Member
    63
    26
    Nassau County
    I previously posted that I was apparently having some trouble with my car's entry system.
    I brought the car into the dealer today. I described the problem, and that the car had been dead Monday morning and needed a boost.
    I was told that a scan would be done, and the cost is $110; if it's covered by the warantee, there would be no charge. (My car is under warrantee untill 2013.)
    When I picked up the car, I was told that they found nothing with the scan, but I would be charged half price.
    The bill I was given lists 2 "LABOR"s of $27.50 each. One was for checking the keyless entry system ("tech checked keyless operation and found it to be working normally"), and the second for checking the battery ("tech charging system. battery-OK.").
    Was the dealer correct in charging me for this? A friend with a Toyota has brought his car in with a complaint to another dealer, and although they found nothing, did not charge him.
    I suspect they charged me $55 for "labor" because I got a free oil change via a contest they ran, the value of which is listed on the bill as $54.61. Which to me seems to be steep for an oil change.
    Thanks.
  2. txl146
    txl146 Member
    301
    NY
    Shouldn't Toyota cover EVERYTHING until your warranty expires?
    My Subaru dealer would never charge me anything for diagnosing the issue.
  3. carlbarry
    carlbarry Member
    63
    26
    Nassau County
    Yes. That's why I'm asking the experts! On the bill it says the customer relations manager "wants your feedback." So I want to know if I am correct in making a stink about it.
  4. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    I would say "Hell NO" they conned you, go back , complain, if they get stupid , mention that you are going to take this up with Toyota Headquarters. They will give you the 800 #. If they said free before the job, they cannot turn around and charge you because THEY did not find anything. I hope you refused on the spot and did not pay them. Be polite, and diplomatic. The people you talk to are mostly Robots obeying orders from somebody higher. Always go higher if unsure. On your problem with the 12V (?) battery, go to a place like batteries are us, and let them look at the battery. The dealers are incredibly inefficient when it comes to condition, charging and straight talk. :rockon:
  5. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    It's a tough call, I'm a bit torn on that one. If the tech really did make a legitimate effort to find the problem but could not duplicate it, they should get paid IMO.
    I'm guessing that the techs at your dealer must get paid even if they could not find anything wrong. So, I guess you as the customer gets to pay that.
    On the other hand, I know a lot of dealers don't pay their techs if the car is under warranty and the problem can't be duplicated.
  6. carlbarry
    carlbarry Member
    63
    26
    Nassau County
    Aren't the techs on salary, paid for 8 hours of work per day? I would think that as employees of the car dealership they are not paid on the basis of how many problems they find and repaor.
    That being said, they did not address my problem. The tech touched the handle, and found that it worked then. They then checked the battery, and supposedly the charging system. All worked.
    My complaint was that after several hours of being "off," the entry system would not respond properly. Did they address that? No. Let's say there is a problem with the remote start they installed, and that is causing the problem. Did they address that? No.
    They merely checked if the car was working properly then and there. So in my opinion, they resolved nothing.
  7. The Critic
    3,193
    2,333
    CA
    Then complain. They obviously did not try to reproduce the problem under the circumstances that you described.
    However, techs are almost always paid on a flat rate system. They are essentially paid by the job. An oil change may pay 0.3 hours or 0.5 hours, a set of brakes may pay 2 hours, etc.
  8. fuzzy1
    10,690
    Are you going to have to replicate the failure yourself by leaving it parked overnight on their lot, where you can personally demonstrate the failures in the morning?
  9. Mickduc
    Mickduc Junior Member
    47
    Oak Park, IL
    No such thing as a salary auto tech, hourly maybe if it is a union shop but for the majority it is all flat rate. This means you have to take a different tactic to get an intermittent fault reproduced and repaired. Basically you have to tell them you have an intermittent issue and that they need to duplicate your circumstances exactly. Pulling codes might give a clue on where to go but as in your case there weren't any so they should have kept it overnight at least to see if they could duplicate the issue. Your car is under warranty, there is NO charge for warranty work and that includes finding the problem. I don't know about Toyota but many other companies pay techs to use the diagnostic equipment if the car is under warranty, I'm just not buying the "diagnostic charge" and you should take it up with the service manager.
  10. carlbarry
    carlbarry Member
    63
    26
    Nassau County
    First I have to replicate it in my garage LOL.
    I am going to be more observant, and make sure I am not causing the problem (by perhaps forgetting to touch the handle to lock the car).
    When the car died, it was parked from about 2 pm Friday to 7:30 am Monday.
  11. andyprius
    2,212
    188
    IF: this is only a 12V battery problem, you can deliberately duplicate the problem by putting the car in accesory mode and turning on everything that will turn on. If the battery is really bad, it will fail quickly, the tech will be able to duplicate the problem, they will have to charge the battery ( if they can ) to move it. You can do this by waiting in line or park at some slightly remote area at the dealership. As far as the dealership is concerned, if it can't be duplicated, the problem is not there. So help them!
    :cheer2: PS It makes no sense to duplicate at home.
  12. carlbarry
    carlbarry Member
    63
    26
    Nassau County
    I don't feel I have a battery problem. The problem is: after returning to the car when it has been "off" for an extended period (such as overnight), when the driver's side door handle is touched, there is no beep, but the door is already unlocked.
    That seems to me to be a computer or electrical problem.
  13. fuzzy1
    10,690
    This won't replicate his problem. It will simply, and intentionally, run the battery flat, which the dealer should properly diagnose as a problem with the operator, not the car.
  14. carlbarry
    carlbarry Member
    63
    26
    Nassau County
    I wasn't planning on trying that test LOL
    Kind of like thinking it was the milk that made you sick, so I'll try another glass just to be sure.
    Meanwhile, the battery seems to be holding a charge. When I turn it off Friday afternoon and leave it for a couple of days, I'll see what happens.
  15. jim256
    jim256 Member
    317
    69
    Eastern NC
    I saw in your prior posts that this was a "Certified" used car warranty, prior fleet car. When you say it's under warranty, is it still within the factory 3 yr/36k warranty, or is it under a Certified used warranty? If it's the latter, what does it say about electrical and other non-powertrain claims? There can be a big difference depending on the particulars.
  16. carlbarry
    carlbarry Member
    63
    26
    Nassau County
    It is considered a "used"/"pre-owned" vehicle. It comes with a 12 month "comprehensive" warranty: Whichever comes first from date of Toyota Certified Used Vehicle purchase. The Comprehensive Warranty covers any repair or replacement of components which fail under normal use due to defect in materials or workmanship.
    Since I'm just within the 1 year, I would think I'd be covered.
  17. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    The car does NOT beep when you unlock it. It also does not beep when you lock it. It DOES beep if you try to lock it, but the door or boot is open. In that case it doesn't lock, and if the interior light is on, will drain the 12V battery overnight.
    The dealer is probably justified in charging, because at this point it sounds like operator error.
  18. Mickduc
    47
    Oak Park, IL
    This didn't sound right to me so I just went out to my car to check it. Touching the door handle sensor area to lock it causes a single beep and the hazards flash. I waited a minute and grabbed the handle to unlock it and I got a double beep and hazard light flash. All doors are closed securely. This is normal operation for me, so what gives with your assertion, are the cars all programmed differently? Mine is a 2010 II.
    Mick
  19. carlbarry
    carlbarry Member
    63
    26
    Nassau County
    Yes, you are correct. Also, when I approach my car the inside courtesy lights go on, even before I touch the door handle.
  20. fuzzy1
    10,690
    Mine does, on both events.
    Is this a functional difference between UK and US markets?
