Rear Hatchback Handle Part
Discussion in 'Gen 2 Prius Main Forum' started by gondo, Jul 23, 2013.
  1. gondo
    gondo Junior Member
    28
    Omaha, NE
    When I open the hatchback on my 07 Prius, there is a horizontal black rubber (I think) piece anchored by 2 screws that's part of the handle you use to lift the hatch. That piece is wearing out and leaves black residue on my fingers every time I open the hatch.
    Wondering where I can find a replacement - a part number or online links to purchase the part would be great. Wouldn't have to be Toyota/OEM, unless that's the only one available. Thanks.
  2. Patrick Wong
    18,212
    6,529
  3. desmondlee
    desmondlee Member
    204
    27
    2013 Prius v wagon
    mine rotted and Toyota replaced it under warranty. I think some of the Prius's had better ones than the one I had originally.
    I touched some of the 07's and they were not the same one I had.
    When I took it in, the service person was surprised it had dried out like it did.
    The new one did not feel like the old one - I am wondering if there was a problem with this too (that they did not tell anybody).
  4. desmondlee
    desmondlee Member
    204
    27
    2013 Prius v wagon
    the cost was $242 on the bill which I did not have to pay.
    On cold days, the rubber would get hard and it would be hard to open the trunk.
    The part was $97 and labor was $145
    part number 84905-47010 Switch Sub-Assy
  5. desmondlee
    desmondlee Member
    204
    27
    2013 Prius v wagon
    my car had 95k miles when I had it replaced 12/2012
    It has been a problem for some time before - then when I took the car in for service I remembered to ask them about it.
    Like I said before, the person taking the car in was surprised about it.
  6. willchu
    willchu Junior Member
    51
    Northern NJ
    I just put gorilla tape on it- cost = about $0.10 cents
  7. gondo
    gondo Junior Member
    28
    Omaha, NE
    Thanks for all the replies. I like the Gorilla tape solution - another entry in the "1001 Uses for Duct (Gorilla) Tape" book;). I covered a large hole in the front bumper of my 05 Suzuki Aerio with Gorilla tape as a temporary solution until I could replace the bumper, and sold the car 2+ years later with the tape still intact and looking good!
    I doubt a dealer will have mercy on me at 161K miles, so probably time to check salvage yards or make a replacement piece as noted in the thread Patrick linked above. $70+ for the whole kit and $300+ for dealer replacement is typical wack.
  8. gondo
    gondo Junior Member
    28
    Omaha, NE
    Went with the Gorilla tape for now, to avoid the black sticky residue on my fingers.
    Was on a walk today and happened to do a little vehicle "dumpster diving" in the median of a busy city street - lots of scrap rubber pieces, found 3 that have potential with some resizing/cutting.
    Will update when I get a chance to perform the operation :rolleyes:.
  9. theshark
    theshark Member
    164
    Martinsburg, WV
    "dumpster diving" "sigh"(y)
  10. gondo
    gondo Junior Member
    28
    Omaha, NE
    I know, bad analogy...it's all I could come up with :oops:
  11. kdewester
    kdewester Junior Member
    I just followed Patrick's how to and we did it in less than 30 minutes. Really not hard at all.
  12. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    Well, mine has split and is on the way to total disintegration, so until the replacement from amazon arrives, good old GafferTape to the rescue:
  13. WilDavis
    2,493
    2,155
    49
    Well, the new one arrived, and here it is installed:
    A bit of a pain in the bum to get the old one off (some wisearse had used what seemed like roofing cement to seal the old one in place), but after I cleaned it off (and you will see from the pic, that the job becomes far easier if you remove the rear number plate for better access). I used "O-ring" rubber lubricant to seal everything before I put it back together all is now good: Here's a pic of the old gloppy one I replaced: bad_handle.jpg
    So, all in all, a good fix, and many thanks to whoever posted the original link from amazon:
    Raytheeagle likes this.
  14. Michael Crestohl
    Michael Crestohl Junior Member
    63
    Marblehead Massachusetts
    Mine had gotten to the point where the rubber was now a sticky mess. I ordered a replacement through ePay for $7.50. First caveat: get a kit that has the offset screwdriver, I managed to get the screws out and had to use my trusty Swiss Army knife to scrape the remains and sticky residue of the old rubber cover off;it had gotten into the switch and was interfering with its’ operation. It was a chilly early spring New England day which made the job even more tedious. Finally I got most of it off, installed the new rubber and installed the new screws. Works fine.
    I tried to use 91% isopropyl alcohol as a solvent to clean up the residue but it didn’t dissolve shit. Would like to finish cleaning it up in warmer weather,
    Can anyone suggest a solvent?
    TIA!
    Michael
