Rosen Nav, Ups and Downs
Discussion in 'Gen 3 Prius Audio and Electronics' started by Cloud, Dec 2, 2010.
  1. ravencr
    ravencr Member
    117
    NC
  2. taylorgso
    taylorgso taylorgso
    Greensboro, NC USA
    Ant power controls automatic antenna up/down... if it is enabled, the antenna will retract when power is turned off and extend when it is turned on. I guess part of firmware designed for multiple systems... of course it isn't compatible with the Prius.
  3. Cloud
    Cloud New Member
    New York
    I
    SCARY MOMENT :mad::mad::mad:
    I was driving on the highway, music blasting and using my GPS to get to my friends casa. Then I tried making a call from my IPhone 4 and since it was connected via bluetooth through the rosen system, rosen attempted to route it through their system but it crashed. It was frozen but it still kept playing music.
    So I had to pull over because I needed the GPS as I didn't want to miss my exit. I turned the car off completely. Now the real problem...
    The System would NOT turn off. It just kept blasting the music while my car was off. I started to scrounge around for a small pin to force reset my HU. I ended up using a pin from my watch to reset it.
    Overall I'm not to pleased with rosen after this lockout.
  4. Ragz
    Ragz Active Member
    210
    110
    New York
    Great, I ordered mine Friday and it is shipping today.
  5. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    Wow - that is really very scary! I would start with the NY Better Business Bureau {http://www.newyork.bbb.org/}, and follow up with the FTC {http://www.ftc.gov/} consumer protection division...
    Unbelievable!
  6. parityone
    parityone Junior Member
    Maryland
    Where is the reset hole?
  7. Cloud
    Cloud New Member
    New York
    I
    The reset hole is on the front face of the HU. Top right to be exact.
    I thought that when you turn off the car it kills the power to the HU completely.
    I guess it's up to the HU to realize the cars off and then shut off itself?
    If I didn't have something to reset my system with... I would have been screwed and incredibly pissed off as my system was on full volume.
  8. rrolff
    1,610
    246
    So Cal
    Please let us know the outcome - as you said - this is really scary!!!
  9. Jeremy Harris
    Jeremy Harris New Member
    221
    39
    Salisbury UK
    I've long suspected that the Rosen and Fly Audio units are just generic Chinese units with a Prius-specific face plate. This sort of of software glitch seems pretty typical of the Chinese units and tends to confirm my suspicions.
    What I find a bit odd is the high price differential between the Rosen and the generic Chinese units, especially when it seems that the internals are similar, if not identical, to the Rosen/Fly Audio units. The matching faceplate certainly adds value and looks great, but is it worth the pretty steep price premium over using the Toyota faceplate and a generic Chinese Toyota head unit with the same functionality as the Rosen?
    Maybe it is worth the extra; certainly I'd love to see a RHD version at a reasonable price, but preferably without the little niggles that make these Chinese units a bit irritating at times.
    Jeremy
  10. rrolff
    1,610
    246
    So Cal
    I think there's no question that they are re-packaged Chinese HUs... I had a similar thing happen to my old Chinese HU - ended up having to pull the fuse (hard reset) to get it to shut down and reset.
    From a cost standpoint, it seems good generic Chinese HUs are around $500.
    Building a plastics mold (engineering, tooling, engineering, retooling, engineering, retooling etc) of this size would run at minimum $40K. Add to that engineering hardware dev (connectors, JBL interface etc), and you probably sit around $75K all in.
    I'd doubt they've even sold 100 pieces - and that's FLY and Rosen/Coagent.
    Bottom line, I doubt anyone's getting rich on such a niche market item.
    Personally, I'd either get the cheaper 2DIN, or get a used factory HU...
  11. luchinis
    luchinis Junior Member
    46
    Michigan
    I love the Rosen Unit ,Chinese or not.... never had a problem with it.
    100 times better than the prius oem.
  12. luchinis
    46
    Michigan
    "I'd doubt they've even sold 100 pieces - and that's FLY and Rosen/Coagent. "
    maybe less than 100:rolleyes:
  13. Jeremy Harris
    221
    39
    Salisbury UK
    Being Chinese made isn't an issue at all, as over 90% of all car audio systems are made in either China or Korea, I believe. The OEM radio (JBL audio system, but actually made by Fujitsu Ten) is made in the Phillipines, I was surprised to find.
    I agree, the branded, model-specific Chinese units, like the Rosen and Fly Audio ones are unlikely to sell in high volume, so maybe it is just the fascia tooling cost that makes the price so much higher. My suspicion is that the dealer mark-up will be the biggest cost factor though. With the generic Chinese units being sold virtually direct, with long distance (if any) support, I guess it's reasonable for Western dealers to maybe double the price to cover support and still make a profit.
    It would be nice to know if the firmware in these units is getting updated, though, and if there was a way to re-flash the firmware with upgrades when bugs, like this latest one, are found. Just having access to much more information about these units (both the Rosen/Fly Audio and their generic no-name Chinese cousins) would allow us to understand how they might be improved.
    Based on my experience with a no-name Chinese unit,which fitted the Toyota fascia panel perfectly (unlike the 2 DIN Kenwood I'm currently running), I have to say that it was close to being a good system, let down mainly by firmware quirks and some odd RDS handling by the radio. If I could get another unit like this, but with better firmware, then it'd be my preferred choice, especially as neither Rosen or Fly Audio look set to make a RHD fascia version (given the tiny market for RHD I can understand that).
    Jeremy
  14. winstead22
    winstead22 Junior Member
    Maryland
    My wife has the Prius but this question is about my Toyota Highlander. I installed the Rosen Nav a few months ago and everything is working except the rear door speakers when playing a CD. All speakers work including the rear door when playing the radio. As everyone with a Rosen knows this is plug and play and the only two connectors I used was the main connector and the one for the steering wheel controls.
    Did I miss something during the install or is there something else that has to be done to get the rears to work? I checked the Rosen manual but found nothing.
    Those with the Rosen in their Prius, do your rear door speakers work while playing a CD?
    I'm posting here as this is a very active community with knowledgeable people on the Rosen Nav.
    I also posted this on a Highlander forum but it is not nearly as active.
  15. brnrice
    brnrice New Member
    New York
    So when I click the Navigation button, it takes me to the accept terms page. However, I can't click on the accept button. I touch the screen but the screen does not go away. I know the Navi is working in the background because it tells me when my speed limit is too excessive.
    I've tried calibrating the screen from the Menu option, but that didn't work.
    Anyone have a similar problem or a fix?
  16. prius2010II
    prius2010II Member
    269
    23
    us
    The China places that carry Coagent and Fly Audio all state something like:
    They are trying to protect their distributors. I'll speculate the intended market is car dealers who sell the unit as being "as good or better" then factory GPS at half the price. In other words sold for around 2K installed.
    Allowing the unit to be sold for around $500 would kill the distributors. The distributor is responsible for support and probably warranty repair. The dealer probably buys the unit for $500 (maybe less) and tries to sell it for something like $1000. A new car dealer might hope to sell it for $2000 installed.
    Problem: I don't think many new car dealers are interested in selling aftermarket units.
  17. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    FWIW, Rosen is made by Coagent. I found that out by looking up the FCC ID # on my Rosen unit.
  18. WinstonTheodore
    WinstonTheodore New Member
    OC, California
    Does the Rosen unit auto dim when you turn on the headlights?
  19. 1stPrius11
    1stPrius11 New Member
    VA
    Rosen navigation NO voice on street name
    USB and SD card player is only resume play at the last track, but NOT where is left off
    NO folder on USB or SD card
  20. Kanester
    Kanester New Member
    I installed the newest version Rosen in my Prius a couple weeks ago, and it DOES say the street name, just FYI.
