rust under the bonnet
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ekkert, May 30, 2010.
  1. mainerinexile
    mainerinexile No longer in exile!
    403
    73
    Maine
    Trouble is, the UK bonnet flaps in the wind and reduces gas mileage unless it is tied on really tight.:)
  2. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    I bought a can of that stuff, am anxious to try it out, ty
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,830
    Clearwater, Florida
    Its pretty good stuff. A little goes a long way. Good around the house too. Door hinges and stuff.
    I like it 'cause its stays on engine and suspension parts without evaporating to bad.
    Home Depot sells it it but Lowes does not for some reason although Lowes sells other PB Blaster products.
  4. Ogo
    Ogo Prius Owner since 2008
    220
    44
    Ilirska Bistrica, Slovenia
    This amount of rust is normal on every Toyota which was driven in countries where road salt is used. Toyota never cared much about details like rust on unimportant nuts and bolts under a bonnet. They never expected car will last for 50 years anyway. So before those nuts and bolts rust away completely, other parts of the car will disintegrate anyway.
    I usually spray those parts with a bit of WD40. 5 years later they look as rusty as at the time they were sprayed.
    Do not worry, be happy. :)
    P.S. My 2008 Prius is as rusty under the bonnet as the one pictured above. We use road salt extensively here, and mixed with rain and higher speed driving gets mixed into fine mist which finds its path to many hidden parts of the car, for example under the bonnet.
  5. edthefox5
    10,096
    4,830
    Clearwater, Florida
    Yes this is a completely different vicosity than WD40. I used to use WD also and 2 weeks later its evaporated and gone. This stuff I posted is designed to stay on the metal and protect it. Its designed to do what I am using it for. To stop rust on nuts and bolts. And it lasts a very long time and works very well.
    It does exactly what it advertises.
  6. andyprius
    2,212
    188
    An older thread now, but what the hell. Ed that stuff is incredible. I put it on an old combination lock that was exposed to salt water, was on my boat locker box. And, it cleaned it up like new, and works better too! ty
  7. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    511
    63
    I think on the can it even says something like exhaust manifold! Has anyone tried that (spray on high temperature exhaust parts)?
  8. edthefox5
    10,096
    4,830
    Clearwater, Florida
    Your very welcome!
  9. edthefox5
    10,096
    4,830
    Clearwater, Florida
    Yes I think there implying the worst of the worst the rusted stuck exhaust manifold bolt on a non running motor. There falling back on there PB Blaster roots there I think. PB Blaster is still the best for that stuff. That and cryo-genics.
    Except PB Blaster stinks so bad. Spray it on something on your car and your garage will stink for quite a while. Works good but makes me gag.
    This CSP does not smell.
  10. 2009Prius
    2,705
    511
    63
    I am not understanding completely your post but I was talking about the 16CSP:
    It says "Exhaust Head" and "Exhaust Manifold" on the bottle:
  11. edthefox5
    10,096
    4,830
    Clearwater, Florida
    Yes I know exactly what your talking about I read it on my can too but I'm thinking thats a boo boo and they meant the bolts holding the exhaust manifolds on as they are a bitch to get off....at least I hope its a boo boo.
    Cause as your implying don't spray this stuff on your exhaust manaifold!!!!
    Smoky!
  12. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    All the salt you guys us on the road there? And you have less rust? i don't buy it.
    To the OP i see nothing wrong with the pictures.
  13. 2009Prius
    2,705
    511
    63
    That makes a lot more sense. Thanks! :)
  14. edthefox5
    10,096
    4,830
    Clearwater, Florida
    No problem buddy. I think they got a little carried away with there advertising!
