Slow wireless charging
Discussion in 'Gen 4 Prius Audio and Electronics' started by raspy, Aug 21, 2016.
  1. raspy
    raspy Senior Member
    438
    699
    London, UK
    It's seriously slow with my S7 Edge. It appears Toyota have not installed a fast charger. 1471781468242.jpg
    ETP likes this.
  2. booke02
    booke02 Active Member
    391
    415
    Israel
    I don't know where the charging coils are located, but phones can be be quite sensitive to their location. Have you tried turning the phone around 180 degrees?
    ETP likes this.
  3. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    If you're out of Wi-Fi range and not using GPS, you can turn them off, which may improve charging time. Also, when the screen goes to sleep, it may use less power and charge quicker than that screen indication shows. But I'm just guessing - it may not help.
    ETP and WilDavis like this.
  4. Gen 2 Tom
    Gen 2 Tom Active Member
    333
    286
    Lincoln Park NJ
    Is that poor charge rate typical of the system? If it's not as good or better than plugging in a cable I wouldn't use it. I charge going to and from work, and most of the time I'm good for the day.
    A bit off the subject. What I understand , to add this feature to my IPhone you need to add the charger on the back of the phone and plug a cable in to the lightning jack. That won't work for me, the jack would be broken real soon. Is there an IPhone option with this built in?
    ETP likes this.
  5. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    It has been my experience with both my SmartPhone (Droid) and tablet (Ellipsis 10) that they're quite sensitive to which charger they're charged with, the branded good-quality chargers seem to do a much better (faster) job than the dime-a-dozen knock-off Chinese garbage chargers found at many convenience stores, gas-stations, pharmacies and kiosks! (IMNSHO & (…as always) YMMV!)
    ETP likes this.
  6. WilDavis
    2,493
    2,155
    49
    Yup! …setting the device to "Airplane Mode" and disabling unnecessary features (BlueTooth, WiFi, location etc.) can make a big difference, active-wallpaper is another …
    ETP and alanclarkeau like this.
  7. booke02
    391
    415
    Israel
    Wireless charging is slower than charging via a cable. After trying a couple of cheapies, I now have a god quality charger. My LG G3 charges about 15%-20% in an hour. So your nearly 3 hours from 67% to full charge is not so far off the mark.
    ETP likes this.
  8. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    Ultimately, you're gonna get 5 watts from Qi, most likely. The standard has room for higher power, but AFAIK, that hasn't actually been made available.
    Compare to 2 amps at 5 volts (10 watts) on most chargers, as much as 24-36 watts with Qualcomm Quick Charge depending on connector (although Quick Charge will probably be going away, with USB PD supplanting it), or whatever USB Power Delivery can do on your device.
    ETP and wrprice like this.
  9. raspy
    raspy Senior Member
    438
    699
    London, UK
    I followed your suggestion, still the same result.
  10. raspy
    raspy Senior Member
    438
    699
    London, UK
    In my example, wifi, BT & GPS were all off.
  11. raspy
    raspy Senior Member
    438
    699
    London, UK
    The soon to be released new iPhone 'may' have this, not sure.
    ETP likes this.
  12. raspy
    raspy Senior Member
    438
    699
    London, UK
    Plugging in my S7 Edge to my Samsung AC charger at home, highlights that it can do a full charge from 0% in 2 hours.
    ETP likes this.
  13. raspy
    raspy Senior Member
    438
    699
    London, UK
    Actually, in the case of Samsung, then they do offer fast wireless charging. I do wonder if there is any way to swap the Prius Qi charger for a fast one?
    Fast Charging Wireless Charger (Black)| Samsung UK
    ETP likes this.
  14. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    That looks like it's Samsung-proprietary (for the fast mode, anyway, it slows down to standard Qi rates on non-Samsung devices, apparently).
    ETP likes this.
  15. BlueCrushSteve
    BlueCrushSteve Junior Member
    Vancouver
    2026 Prius Plug-in
    SE
    I feel your pain, I don't think the on-board charger is very good. I have gone to plugging in a good quality charger int the power port and charging that way. You can purchase a fast charger for your car that plugs in but there is no wireless fast chargers for cars yet.
    ETP likes this.
  16. wrprice
    wrprice Active Member
    415
    308
    Houston, TX
    Four Touring
    Push the pedal to the right of the brake to make your charger go faster. Works for all phones. Experience may vary depending on shift position.
    Sorry, it was too easy. ;)
    ETP likes this.
  17. raspy
    raspy Senior Member
    438
    699
    London, UK
    Not quite true. I found at least one wireless fast charger for cars. Fast Wireless Car Charger – Qi-Infinity
    ETP likes this.
  18. Frolix
    Frolix Junior Member
    45
    22
    Here
    Inductive charging is very dependant on the distance between charger and phone. Could be that your case is thick or makes the phone lie a bit farther and it's making it charge slower.
  19. ETP
    ETP 2026/2021 Prime/24 Venza Limit/B52-D,G,F,H
    2,806
    1,170
    Auburdale FL
    Mine would show current going to the phone but would never charge on a cheap after market one.
    Pretty much given up on this feature and consider it a gimic as the phone charges good on the USB and cigar lighters.
    Not going to pay $28 for another experiment.
    alanclarkeau likes this.
