SM vs. SP oil; are they really different?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by NewHybridOwner, Aug 25, 2022.
  1. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    I just discovered that my two quart bottles of Mobil 1 Advanced Fuel Economy 0W-20 t-- one in the trunk and one on the shelf -- are labeled as "SM," whereas the 5-qt jug I just got from Walmart is labeled "SP." Is the "SM" oil actually inferior, or was that the top rating at the time it was manufactured and would now be labeled "SP"? I.e., it already met the not-yet-published "SP" standard?
    PriusCamper likes this.
  2. CR94
    CR94 Senior Member
    2,824
    1,238
    Northwestern S.C.
    It might, but only Mobil would know whether your SM oil could've met the later, tighter SP requirements. It must be over 12 years old.
  3. NewHybridOwner
    607
    283
    W. Michigan
    No: the Prius that we bought in 2018 is the only car I've ever owned that used Mobil 1 Advanced Fuel Economy, so the "SM" oil would not have been bought before then.
  4. CR94
    CR94 Senior Member
    2,824
    1,238
    Northwestern S.C.
    The SM category was introduced in 2004. SN replaced it as the latest and greatest API Service Category in 2010.
  5. NewHybridOwner
    607
    283
    W. Michigan
    I have no idea where I bought it, but it must have been old stock.
    CR94 likes this.
  6. NewHybridOwner
    607
    283
    W. Michigan
    I just looked at those quart packages again -- and I don't know where I got those "SM" labels from, because I now see that one is labeled "SN" and the other "SN Plus."
  7. CR94
    CR94 Senior Member
    2,824
    1,238
    Northwestern S.C.
    Good, that makes more sense. They're probably fine to use.
