sound system upgrade + custom sub enclosure
Discussion in 'Gen 2 Prius Audio and Electronics' started by ashe, Jun 3, 2009.
  1. ashe
    ashe Junior Member
    34
    Newport Beach, CA
    as many fellow prii owners would agree, the jbl audio system can be disappointing for most audiophiles. it quickly became a fun project to tackle.
    an audiocontrol lc7 converted the rear speaker line outputs from factory amplifier & provided internal signal summing. the factory amp's left speaker output was re-wired to the center speaker - so voice for bluetooth comes from the center... now i'm talking to my dash instead of the door. an audiocontrol eql was added to provide fine-tuning capabilities to deal w/ the pirus cabin properties.
    i picked focal components for the front & focal coaxial for rear fill-ins. we gutted the jbl speakers to utilize its "casing" for mounting. if you have never auditioned focal speakers, you owe it to yourself to put them on your shopping list. all 4 doors were than covered completely w/ dynamat.
    we decided on right side cubby in the hatch (above battery) for subwoofer location. a fiberglass enclosure was custom-built. box provided adequate internal volume for a jl audio 8w3v3. the box is removable for easy access to the battery. if i were to do it all over again, i think i would go w/ a 10". the 8" just can't reproduce the same low-end extensions.
    all the speakers are powered by the alpine pdx-5. nice compact amplifier that produces a lot of power for what i need. low heat (perfect for where i wanted to mount the amp) & low power draw (ideal for our small prius auxiliary battery).
    all electronics were mounted inside the cargo box. a flashboard was custom fitted over the equipment to hide the wiring for a cleaner look. it can easily be removed for access to tools. the cargo box can also be lifted if spare tire is needed.
    i'm waiting for the grill to go over the subwoofer for the finishing touch (hopefully this weekend). i still haven't decided what to do about ipod integration. i'm not too impressed w/ all the current available options on the market. so i'm holding out for the time being & just using the auxiliary input. note: sound quality suffers a bit when using the auxiliary input.
    now on to the next project. :)
  2. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    Looks good :)
    So was the Alpine amp just powering the subwoofer or did you run it as a 3channel with front to the front speakers and the rear 2 channels summed to the sub?
    Another way to mount larger than factory speakers is to use wooden spacers. You can silicone or Dynamat the surface that mates to the door to reduce vibration. I did this to mount my 7" Diamon Audios.
  3. ashe
    ashe Junior Member
    34
    Newport Beach, CA
    i actually used all 5 channels of the pdx-5. plenty of power to the sub (300 watts rms). the lc7 comes w/ a subwoofer level controller which i mounted under the dash. plenty of volume just not enough of the low frequency response. i went w/ the 8" because i was worried there wouldn't be enough box volume for a 10" to fit into that space.
    we were actually going to use spacers but decided it would be easier just to cut through the jbl speakers. i wouldn't have any use for it after the install anyways.
  4. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    Ahh ok. I didn't realize it was a 5ch amp. Very nice :)
    It's so tiny too! My 2 amps take up 3/4 of the whole storage tray. :(
  5. hyo silver
    hyo silver Awaaaaay
    15,260
    1,598
    off into the sunset
    If the right cubby is about right for an 8", but that's too small, and the left cubby is about right for a 10", and that's not enough (though it probably should be) ;)...what about a custom floor over the 'trunk'? Is there enough depth and air volume in there for a pair of 12s? :eek:
  6. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    No need for a PAID of 12s my friend. Just get ONE of the subs I'm replacing my 2 10s with....
    Orion HCCA122! 2000watts RMS and 30mm Xmax (total cone movement). Damn thing weighs approx. 70lbs without a box! The picture does not do this thing justice. The first one that was delivered to the shop totally blew me away. Funny thing is, they sound awesome with rock music.
  7. hyo silver
    hyo silver Awaaaaay
    15,260
    1,598
    off into the sunset
    Only one? But what if I want to go deaf twice as fast? Isn't two always doubly good? :p
    Did you say two thousand watts? The windshield can only take so much deflection, you know. And you might need 'hood pins' on the hatch, just in case the catch lets go. But hey, no need to worry about your car rusting. It'll blow apart at the seams long before that. :eek:
  8. ashe
    ashe Junior Member
    34
    Newport Beach, CA
    i thought about building an enclosure in the cargo floor, but didn't want to lose the cargo box, tools & spare. i wanted a simple stealth system for the prius. who knows... maybe i'll change things up later on. for now, i'm quite happy w/ the results.
    here's a very clean install i found online that has a custom enclosure built into the floor (courtesy of bonpri35):
    [​IMG] [​IMG]
  9. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    LOL!
    I'm running 1500 watts RMS to the 2 10s I have now so swapping to the single 12 is just for convenience and to reduce the box size. ;)
  10. PriusLewis
    PriusLewis Management Scientist
    1,002
    84
    Denver Metro
    Nice install! I mounted my Clarion 5 channel in about the same place. My Rockford Fosgate Punch 10" manual says their 10" needs .7 (7/10) cubic foot enclosure. I use a very small down-firing box. You might want to measure your current enclosure volume - if it is close to .7 cu ft or bigger (that's about what that space looks like to me) it should be OK. You will get tighter bass out of the sealed enclosure than a ported enclosure, but it takes a bit more power to run it (no worry there with your amp). Plus a ported enclosure has to be bigger.
  11. hyo silver
    hyo silver Awaaaaay
    15,260
    1,598
    off into the sunset
    Well, I would hope so. No point going to all that trouble and expense to listen to Willy Nelson. :D
    Ashe, that's a very nice setup. Too bad we can't hear how it sounds.
  12. patsparks
    10,664
    567
    Adelaide South Australia
    Would the larger volume available by using the space in the storage box on the left rear make a 10 inch sub sound better? I know you would lose the storage but that would be a small price to pay I would have thought.
    Did you put any ports in the sub box?
    Sorry, I know nothing about car audio.
  13. hyo silver
    hyo silver Awaaaaay
    15,260
    1,598
    off into the sunset
    Yes, so I'm told. I don't know much about car audio, either, but I'm learning. The bigger the better, for bass, assuming a high quality speaker. The airtight enclosure has to be sized to the speaker to give it the right amount of oomph. And yes, that's a technical term. ;)
  14. PriusLewis
    1,002
    84
    Denver Metro
    The minimum size is more critical than the maximum, and there are marginal diminishing returns past the optimum size (going bigger won't have much effect). Ported enclosures need to be bigger. If you get the paperwork with your sub it should have a chart/table for these sizes. If not check their web site.
    EDIT: I just checked Crutchfield's site and they list the following enclosure sizes for your sub:
    sealed box volume: 0.3 cubic feet
    ported box volume: 0.35 cubic feet
    That's nice and SMALL! You should be in great shape for the enclosure you have.
    If you want to measure the volume of an irregular enclosure (like yours), or any enclosure for that matter, take out the enclosure, take the sub out and fill the enclosure with something like packing peanuts until completely full. Then poor them out into something to measure the volume. If you use something like a large kitchen measuring cup, you will need to convert cups, pints, or liters to cubic feet (look up the conversion you need on the internet).
    As for ported vs non-ported, most sites say ported gives more bass, but it isn't as crisp and defined as non-ported. I prefer the sound of a non-ported enclosure. If you like the trunk-rattling, buzzy type of bass, use ports (that buzzy sound is distortion, and ports usually add some distortion).
    EDIT 2: Here's the enclosure volume for a similar JL Audio Sub in 10":
    sealed box volume: 0.65 cubic feet
    ported box volume: 1.125 cubic feet
    You might want to measure your enclosure volume - it will be close for this. Also check the depth to make sure a 10" will clear before cutting out the front!
  15. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,000
    Fort Lee, NJ
    Sneak up someone on EV mode and blast it off. That would be fun! :D
  16. PriusLewis
    1,002
    84
    Denver Metro
    What an idea! Now I want to go find a CD of various dragsters launching. Pull up in EV mode, open all the windows, and fire off a Top Fuel Dragster soundtrack as you accelerate! :eek: That should take care of the "bell the hybrid" crowd! I gotta find one - it will be lots of fun for this summer's hot rod cruises here in Colorado!
    Oh! Oh! For burn-out competitions, I need to put smoke generators in the front wheel wells (or better yet, the BACK wheel wells) and kick them off with the burn-out soundtrack! Hmmm - where to find smoke generators? Gotta go surf the web!
  17. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
    The JL subs are good with a smaller than recommended box volume. Their own enclosures are smaller volume than what they recommend.
  18. ashe
    ashe Junior Member
    34
    Newport Beach, CA
    hyo silver is correct. the left cubby would actually allow you to customize a larger enclosure. if i had used that space, i would most definitely had gone w/ a 10". i didn't want to lose the small storage tray hence the decision to go w/ right cubby.
    my jl audio 8w3v3 requires sealed box volume of 0.3 cu.ft., while a 10w3v3 would require 0.625 cu.ft. i went w/ a sealed box since it requires smaller enclosure than ported. sealed enclosures tend to produce tight, accurate bass & have a flat frequency response. ported box will produce louder bass. depending on the sub you pick, be sure to check the required net enclosure volume.
  19. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    Additionally a ported box will usually play louder at a lower frequency until you go below the port frequency, at which point volume drops drastically and you tend to get more port noise. This is easily fixed with a subsonic filter to cut frequencies below that point. For playing ultra low frewuencies like whale songs then you would wish to stay sealed since the drop off frequency is quite low, well below our effective normal range of hearing.
    Most ported boxes are tuned to 40-58hz or so and since most music is recorded above those frequencies you won't be missing much with a ported box but you will get much more volume overall. Just have to choose your port size and style accordingly to reduce potential port noise. If you like listing to speed metal or tight jazz then seal is a better idea.
  20. ashe
    ashe Junior Member
    34
    Newport Beach, CA
    my enclosure was customized to provide close to 0.3 cu.ft. so unfortunately i would have to rebuild a new one if i were to change the sub. i'm very happy w/ it so far.
    i specifically went w/ the 8w3v3 because it required the least amount of box volume of all 8" jl audio subs. the 8w3v3 has a low frequency response of 28 hz. the 10w3v3 would have provided 25 hz. my untrained ear would probably have a hard time telling the difference.
