Steering recall performed, then 33 mpg instead of high 40s
Discussion in 'Gen 2 Prius Fuel Economy' started by ML Diggs, Jan 15, 2013.
  1. ML Diggs
    ML Diggs Junior Member
    71
    Portland Oregon
    Maybe it's a coincidence, but I got the steering shaft recall done on my 07 at the dealership last week, and after a fill up, my average mpg dropped from high 40s to low 30s. I've had the car and tires for 3 years and never got less than 44 even in winter. I typically reset the average every few fill ups, so its not an averaging issue alone. I topped off the tires too -- 40ish all around on Hankook Optimos. No significant change.
    Also, after recall job, the steering wheel is ten or so degrees down on the left. I've been told in the past that is not related to alignment, but I wonder if it is relevant here. I have an appt. for them to fix that (because it's just so darn annoying), but I'm interested in ideas about the mpg drop. Had 12v battery checked an oil change or two ago, charging fine then.
    Ideas??
  2. Adam Leibovitch
    498
    102
    Did you reset the MPG's after or before going to the service center? Is it possible they might have left the car running to install/test and used gas with no travel? That can lower the average.
  3. ML Diggs
    71
    Portland Oregon
    Ah, yeah, I thought about that too, so I did reset it after aBout 16 miles because it was so low and I thought that mighit have been the case. Still, maybe 45 more miles of typical driving and it's 33 nonetheless.
  4. Merkey
    Merkey Active Member
    315
    285
    Birmingham, Michigan
    Had my 2006 steering recall done last week. Mileage doesn't seem to be affected, but steering wheel is off center to left by about 5 degrees. Had to make another appt w/dealer adjust to center .
  5. ML Diggs
    71
    Portland Oregon
    you would think they could get the steering wheel centered..pretty basic and important with steering wheel controls for audio and heat...duh. Good to know your mpgs not affected.
  6. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Tyre pressures!
  7. Agent J
    Agent J Hypoliterian
    294
    111
    Sydney, Australia
    too early to tell as you haven't even reached half tank. you'll get a pretty good idea towards the 2nd half. Or, go for a drive of more than 60 miles return trip the way you drive normally and take note of what you get.
    does the car veer to the side if you let go of the wheel? might be an alignment or toe issue that increases rolling resistance. have it corrected when you get the chance.
    F8L likes this.
  8. ML Diggs
    71
    Portland Oregon
    Thanks, Agent J. I haven't noticed the usual alignment stuff. I get the steering wheel lined up Tuesday and I'll ask them to check the alignment. Can alignment get screwed up by the steering shaft recall (if so, they would have to do that free also, I assume).
  9. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    See Some interesting Recall happenings. Need advice | PriusChat regarding the misaligned steering wheel.
    Maybe one of the threads on this recall should be stickied and include the link to the recall procedure documents?
  10. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    The wheel alignment "toe in/ toe out" should not in any way be affected by the recall work, as the steering rack does not have to be disconnected from the wheels or sub frame.
    The steering wheel is however disconnected from the rack when the intermediate shaft is replaced and this if not reassembled correctly can lead to the steering wheel being offset.
    John (Britprius)
  11. ML Diggs
    71
    Portland Oregon
    Thanks, John. I'll fight for the straightening being free. I don't think the front end alignment is off..I've tested that. I also am back up to 42 mpg now with longer trips and 40 lb pressure, so I think it was just a cold week, short trips, 35lb pressure. I'll let you all know of it turns out to be something different.
  12. Britprius
    5,194
    1,921
    Thanks for the reply and keep us all updated.
    John (Britprius)
  13. ahmeow
    ahmeow Prius Lover
    366
    70
    North CA
    I also did the recall and nothing unusual after. Touch wood. My dealer is San Jose Capital Toyota. A nice dealer,per my fiften+ years of experience.
  14. ML Diggs
    71
    Portland Oregon
    Had them work on the steering wheel centering yesterday. The mechanic went for a drive with me, and it was 5degrees down on the right instead of 10 degrees down on the left. he went back in with it, we drove again, it looked better, maybe 3 degrees down on the right, and I started to worry that I was obsessing (I'm a picture straightener who can't stand things being off-center unless they are totally right or left justified), so I left, but after driving it for another day and a half, it's still bugging me...it's 3-4 degrees down on the right, so I drive with a seam under one thumb and not the other, an awkward reach to the map button.
    Whaddaya guys think? Am I just being obsessive, or do I have a right to expect perfect center and alignment of the Toyota logo etc.?
  15. Britprius
    5,194
    1,921
    No your not being obsessive take it back and if they will not put it right contact Toyota.
    John (Britprius)
  16. ML Diggs
    71
    Portland Oregon
    Thanks, John. Will do. And, by the way, the mileage is back up to 45 with some extended trips, not bad for 30 degree weather with Hankook Optimo 727s, so that's no longer an issue.
  17. ML Diggs
    71
    Portland Oregon
    So I went in agAin, and helped the guy line it up, but when he tightened the second bolt, it shifted slightly back down to the left. This is trickier than they think, and it is annoying as hell. maybe they chould make the emblem on the steering wheel perfectly circular with nothing horizontal or vertical inside it ;-).
    Merkey likes this.
  18. Merkey
    315
    285
    I cancelled the appt to center my wheel...thought I was being too OCD (I like things perpendicular & horizontal as well). Considering your re-centering dilema, maybe I'll just get used to it.
  19. ML Diggs
    71
    Portland Oregon
    I'm gonna pay to have someone else do it and get an alignment at the same time. I'm convinced the guy has some innate deficiency with this, and I'd rather pay $89 for an alignment than have this guy try to fix it again for free. i find driving much more tiring with the wheel off set...I'm constantly correcting unconsciously.
    Merkey likes this.
  20. Merkey
    315
    285
    My thoughts exactly.
