Stereo dead
Discussion in 'Gen 2 Prius Audio and Electronics' started by jeffvk, Sep 6, 2011.
  1. jeffvk
    jeffvk New Member
    San Luis Obispo, CA
    Hi all-
    My wonderful three year old put a penny into the CD player. First it played, then it stopped and we got weird loud popping noises, even with the volume off. Now the radio/CD player is off and can't be turned on.
    It seems like a good time to upgrade, but what should I be looking for as far as no power to the audio? Fuse?
    I know nothing about this stuff.
    thanks for your help.
  2. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    discipline! hehe.. just kidding..
    sound like a problem... insurance? time to go aftermarket?
    you could always find a used one on ebay... there are a few people on here who fix and sell them too.
  3. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    Have you decided on a stereo, Jeff? :)
  4. MTKnife
    MTKnife New Member
    Seguin, TX
    With the popping, I suspect it's dead. However, check the fuse: if it blew, it might well have saved the radio, though before replacing the fuse, you'll almost certainly have to remove the radio and physically open it up in order to remove the penny (though you just might be able to shake it out).
    If you can't/don't want to fix it and don't want to go with an aftermarket stereo, and this is the non-JBL version, let me know--I just removed one from my car to replace it with a Pioneer, and I'd be happy to sell it to you cheap.
  5. jeffvk
    jeffvk New Member
    San Luis Obispo, CA
    I think my daughter was telling me my stereo sucked.
    I'm thinking Kenwood X995, so now I'm trying to figure out which PAC thing I need for the x995 to 2004 Prius, non-JBL. Do I still need the BHA1761 and BHO1761 with the PAC thing?
    All of this is confusing to me. Tools?
  6. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    Yes. Too bad you didn't live closer or I' d helps you installed it. It's pretty easy once you have done it before. Feel free to call me if you run into problems. I'll pm you my number.
  7. MTKnife
    MTKnife New Member
    Seguin, TX
    The stock stereo does suck. :) The PAC you're going to need is probably SWI-JACK (the "K" in there is for Kenwood), but the Axxess ASWC is universal and people seem to like it better, though I seem to recall that there are some special instructions (posted on the Axxess website) for Kenwood stereos. The problem is the documentation for the '04-'09 Prius is more or less wrong, but I just installed one, and I'll post a report with instructions within the next day or two (there's already a thread with instructions for it, but the wiring given there didn't work for me). Either of those things only handles the steering wheel remote controls; you'll also need a harness adapter for for the normal radio things, and yet another adapter (which comes with the Sosche mounting kit) to make the ASWC or SWI-JACK work with the radio (assuming, in both cases, you don't want to cut the wires off the factory harnesses). Check the thread "How To: Upgrade Head Unit (Kenwood eXcelon DNX6960)" for details.
    Finally, unless you do the "stealth" install (might want to check that thread as well) under the current unit, where the storage pocket is now, you'll need the above-mentioned Sosche adapter kit, which fills in the gaps in the dash with two plastic side pieces and, with a single-DIN HU like the X995, a second storage pocket above the first one, as well as giving you the aforementioned adapter (which, in addition to allowing you to plug in the the new steering wheel remote unit, adds the resistor that keeps the climate controls working after the old radio is disconnected).
  8. jeffvk
    jeffvk New Member
    San Luis Obispo, CA
    Thanks guys. I will wait to see your wiring post. That is the part that is the most confusing. I probably won't get to this for another two weeks. I will be installing "stealth".
  9. jeffvk
    jeffvk New Member
    San Luis Obispo, CA
    Thanks MT- Let me know what you find on Axxess versus PAC. I think I might move forward without that for now. Seems like people are having trouble with both.
  10. MTKnife
    MTKnife New Member
    Seguin, TX
    OK, let me post that right now.
