synthetic oil service dept opinion
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Bob Allen, May 27, 2004.
  1. JJay
    JJay New Member
    123
    Vancouver, WA (near Portland)
    In the 19 posts above, nobody mentioned the start-and-stop cycles that are so prevalent in the Prius ICE.
    Isn't it the old Castrol commercials where they drain all the oil out of two running cars, and the synthetic oil engine keeps on running while the other smokes to a stop?
    If this were true, wouldn't synthetic oil work better to keep the Prius ICE lubricated through all the start-and-stops in city driving?
  2. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    because the car is usually moving there is a mechanism
    that circulates the oil. so the cylinders dont start "dry"
    also because the ICE is usually started while the vehicle
    is in motion, there are no misfires or cranks that you
    would get with a normal car. the major wear on a car
    happens when the car is cranked over before starting.
    gas is still pumped into the cylinders and this gas is what
    thins the oil coating thus creating the extra wear.
