The hunt for hydroedges :/
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by GasSaver1, Aug 15, 2010.
  1. GasSaver1
    GasSaver1 Member
    220
    South Florida\Long Island NY
    Tires installed, will see how much gas i save on the next fill-up. I am at 43.5 right now but I was more than half way through this tank.
    I did reject the gas pedal fix, floor mat removal, and software upgrade to disable the gas when the brakes are pressed. In all my years of prius, I never had "sudden acceleration" that that is with 3 years on my 08, and driving an 04 and 05 on and off.
    Total for dealership tire install and alignment: $148.00 + 2.5 hour wait
  2. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Don't be disappointed if you don't see an immediate improvement. Tires take a while to break-in and your mileage will improve some after they break-in.
    Most of the improvement should show up on your second tank.:cool:
  3. roverguy78
    roverguy78 Elite Lurking Member
    118
    24
    San Antonio, Texas
    There is no software upgrade for that. All GII Prius already have that brake over-ride feature.
    Enjoy the tires. They're an excellent upgrade!
  4. GasSaver1
    GasSaver1 Member
    220
    actually no- my 2008 does not have the brake override and I want it that way. When someone is on my nice person I jam on the brakes but keep myself rolling with the gas. I know it eats the brakes and I do not do it for a long time but I can assure you that the brakes do not override my gas in anyway.
    This is really for those extreme situations and despite not doing it often I wanted to preserve my ability to do it so I said hell no to the software upgrade.
    They ran my vin and asked me if i wanted it so I guess something came up on it
  5. GasSaver1
    GasSaver1 Member
    220
    Also, I tested to make sure they did not upgrade anything anyway at the dealership when I backed out of the parkingspace by holding the service brake about half way with my left foot and accelerating in reverse with my right. The car dragged but moved from a resting position. I tested it again driving through the lot, same method just in drive this time- same result. At all times I was able to get the car rolling with some pressure applied to the service brake. If i was flooring the brake and pressed the gas I do not know what would happen but that isnt really the point. At no time did engaging the brake not allow me to accelerate.
  6. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    That seems odd. I'm curious if you would continue accelerating if you had the pedal floored then applied the brakes at 50% or so. Seems weird that the 2005 model would have this feature yet your 2008 does not.
  7. GasSaver1
    GasSaver1 Member
    220
    I dont know. For sure I can say that at speed (like 70ish mpg) I can brake and hold speed at the same time. It works very well dealing with the tailgaters and typically they change lanes after you scare them like that. Naturally I feel the drag doing it, but it is not the feeling of braking when you just take your foot off the gas and brake normally.
    Maybe the 2005 car is question was serviced and upgraded?
    Experiment, hold the brake at 50% and try to accelerate. Am I really the only one that can do it?
  8. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    My car has only been to the shop once in it's 117,000 lifetime and that was shortly after purchase in 2005 so no updates have been applied other than that.
    I'm noticing that you are applying the brake then trying to accelerate which is different than going WOT then trying to brake. I'll try it your way and report back. :) Unfortunately I rarely have access to a computer over the weekend so it won't be until Monday that I can reply. lol
