The "Infamous" Breaking Gear
Discussion in 'Gen 2 Prius Main Forum' started by cyberpriusII, Jun 1, 2012.
  1. cyberpriusII
    cyberpriusII Maybe it was the roses
    1,157
    1,850
    Hyampom
    Driving down my 500-yard long, ultra-steep driveway a few days ago, with a friend, she asked, why, since I was basically coasting, the MPG bar read about 12 MPG.
    Since then, I watched it during the downhill jaunts, and while, at times, it hits 100MPG, it often sits around 10-20 MPG.
    Obviously, I do not have my foot on the accelerator, and I do have it on the brake for much of time, in addition to being in "B."
    Just curious....any thoughts?
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    1) Why would you be wasting energy in B mode on your driveway? Why not use the brake pedal and get all Regenerative braking instead of some engine braking?
    2) I spend most of my time on my driveway when my engine is cold, how sure are you that you are not watching the Prius try to warm up?
    secondspassed likes this.
  3. cyberpriusII
    1,157
    1,850
    Hyampom
    Shoot, I don't know, Jimbo. It seems to me, that I asked long ago on this board what I should use on this long steep pitch and the opinions were sort of mixed. But, for some reason, I came away with the idea that B was best (maybe because B and Best???).
    I do brake -- alot -- so that should be getting all that "re-g" stuff anyway, right? I don't know....I guess I could go back and read that thread from three or so years ago.....??? But was confused why MPG was not at the top....
    So, again it is really steep. And it is a safety issue. I have spun off a few times, although not in the Prius. We are talking seriously, almost mountain goat country....
  4. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I would recommend B when there was over 600 feet of drop, but it is not straight down!
    And if it is dangerous, safety wins over MPG, don't you think? Be safe and get good gas mileage later.
  5. cyberpriusII
    1,157
    1,850
    Hyampom
    I drop about 230 feet in about 400 yards.....not exactly off the cliff, but pretty good drop. I used to spin off the road in my Corolla near the end of the drive a couple of times a year. Luckily, we had a couple of nice turnouts right there, so no real damage....
  6. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    I always use B on any dirt road. It's like using a lower gear. There is only so much regen the battery will take and then the car will pretty much do B any way. Personally I'd rather know I am in control.
  7. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    Don't use B in this situation unless you are starting with a full charge (all green). B just wastes gas.
    As to your question, it depends on whether the engine is running. The Prius often needs to run the ICE to make heat, even when it is unnecessary for propulsion. At low speed you don't cover much ground, so the MPG is low when the engine is making heat.
    Tom
    Corwyn and cyberpriusII like this.
  8. cyberpriusII
    1,157
    1,850
    Hyampom
    OK, so Tom answered the "why I am getting crappy MPG" question in words I understand. Thank you, Tom.
    I also am getting from Jimbo and Tom that I must have misunderstood, or ignored what I was told a few years ago for my daily downhills plunges....so, no B gear for me.
    Just a lot of brake pedal action. Thanks, guys!!!! Now if either of you would like to come over and help me with the parking brake on Saturday....
    BTW, Tom's ICE Reference confused me for a bit. I was wondering where Immigration and Customs Enforcement entered....
  9. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I am pretending that Northern Michigan is closer than Mississippi. (I will actually be in Bellingham WA June 10 to 15th, but that is only close compared to Michigan)
  10. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    I have a similar situation here with my driveway. When I start down the driveway, the engine is in warm up mode, so it runs regardless until it gets up to temperature. Also, since I am going less than 8 mph, there is no regen braking possible, so friction brakes take over. Hence the mpg is not good, but then it is a small distance so not a concern.
    It's getting UP the driveway that makes for some serious low mpg readings. But much to my pleasure, it can make it up, which was a real question on the day I drove it home:D.
  11. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Hi CyperPrius, that's a 1 in 5 gradient, so yeah pretty steep. :)
    Since you're only getting 12 MPG at idle then I assume you're only doing around 10 MPH. In this case the distinction between using "D" or "B" is pretty much moot. Apart from needing to push the brake pedal a little harder in "D" there is no actual difference at such low speed. At higher speed however (can't remember the minimum off hand) "B" mode will cause the engine to always turn. So even though there may be no fuel injection once the warm-up phase has completed, "B" mode will regenerate slightly less efficiently due to energy lost in turning the engine.
    BTW. If you want to you can leave the Prius in "P" and let it warm up for about 50 seconds. It doesn't really waste the gasoline, as it uses it to gently pre-charge the battery. It probably wont change the overall fuel efficiency either way, but at least you can pose getting 100MPG down your driveway. :p
  12. Rokeby
    Rokeby Member
    3,033
    710
    75
    Ballamer, Merlin
    Would the regen-energy recovered picture change significantly if cyberprius had an
    EV mode switch?
    The sequence of events would be:
    Put the car in Ready.
    Switch on EV mode to surpress ICE On. (Note: Temps are neither too hot or too cold.)
    Negotiate the driveway -- preferrably at more than 8 MPH where it is said that
    regen kicks out.
  13. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    Huh? It is not much like using a lower gear. Going up hill, for example B is exactly like D. Going down hill, it uses engine braking instead of regen braking, but you only want to do that when you might 'run out' of regen braking. (that is, fill the battery) I can't imagine what difference the road surface makes. Nor how B is more 'in control' than D.
  14. dianeinreno
    dianeinreno Member
    104
    17
    Denver,CO
    Tom, I thought that while in braking (B) mode on a downhill without the gas pedal being pressed the engine merely spun and the pistons compress air without any gas being injected to the cylinders . When the gas pedal is pressed, either uphill or downhill, while in B mode the engine preforms exactly as in D mode. If that is true then how can the engine waste gas as you say while in B mode? What am I missing?
  15. Corwyn
    2,171
    659
    23
    Maine
    You aren't wasting gas per se, but wasting energy which could otherwise be going into your battery. Thus you will need to use gas instead of battery at some later point.
  16. dianeinreno
    dianeinreno Member
    104
    17
    Denver,CO
    OK that makes sense - but given the choice of potentially going out of control on a steep downgrade , experiencing brake fade from constant use, or saving a few ounces of gas.... well ..... :)
  17. Corwyn
    2,171
    659
    23
    Maine
    No one has been able to explain where is 'loss of control' comes from. Brake fade would only occur if you are using your mechanical brakes, as opposed to either your regen brakes or your engine brakes. If your batteries aren't full, 'D' is NOT more likely to result in any loss of control than 'B'. If your batteries ARE full, that is exactly the time when you DO want to be using 'B', as has been mentioned.
    fuzzy1 likes this.
  18. fuzzy1
    10,674
    I'd expand this to say that on hills where the battery is going to get filled, there is no reason to wait until it actually is filled. I.e. on those 7 mile, 7% downgrades, I always enter 'B' mode at the top to slow the filling of the battery and minimize the time the ICE howls like a jet engine.
    On the moderate 400 foot drop in one direction from my house, the battery usually doesn't fill (it depends on the vagaries of starting SOC / outside temperature / engine warmup cycle), so I never use 'B' there. For slightly taller hills, optimizing this matter becomes a juggling act between B and D and some footwork on the 'go' pedal that won't be worth the effort for many drivers, and missing the optimum won't lose enough energy or heat up the brakes enough to be of any concern. But somewhere between 600 and 1000 vertical feet, steep hills become tall enough to always use B from the very top.
  19. Feri
    Feri Active Member
    761
    144
    I can't imagine what difference the road surface makes. Nor how B is more 'in control' than D.[/quote]
    Even ABS can lock up on loose dirt, muddy or icy surfaces. Using B to decelerate and avoiding unnecessary touches on the brake means that you have just a little more control on these very uncertain surfaces.
  20. CookieGuru
    CookieGuru Member
    104
    Seattle
    2013 Prius Plug-in
    This is most definitely due to being in Stage I.
