The mpg difference 15s vs. 17s
Discussion in 'Gen 2 Prius Fuel Economy' started by F8L, Sep 25, 2011.
  1. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    I cannot help but be amazed at the mpg difference between 15" wheels and 17" wheels. Even though I switch back and forth multiple times a year, I still have a hard time accepting the results.
    I swapped back to my 15s yesterday, filled the tank and drove back home. I used basic hypermiling techniques on the freeway by driving 60mph and warp stealth on the downhill side of overpasses. This is much more difficult to do with the 17s.
    On this trip, slightly downhill by about 200 ft over the 36 mile stretch, I got nearly 64mpg. That included a half hour stop at Home Depot.
    With the 17s I would be lucky to get 50mpg on the same trip. The point to this thread is 15" LRR tires allow you to better employ hypermiling techniques. Don't get.me wrong, I love my 17s for looks and handling but numbers like this make me smile. I've done the reverse "uphill" trip and I usually get 58 mpg or so if I employ the same techniques.
  2. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
  3. hyo silver
    hyo silver Awaaaaay
    15,260
    1,598
    off into the sunset
    Well, if you're sure you don't drive more aggressively with the 17s - I know I would - that eliminates one possible explanation for the difference in mileage.
    What's the weight difference between the two sets of wheels and tires? Rotating mass is more critical than static weight, so any differences here would have a greater effect.
    What's the rpm (rotations per mile) difference between the 15s and 17s? I would imagine the 17s are lower profile, but if the outside diameter is significantly different from the 15 inch wheel and tire combination, you may be noticing a measurement difference, not a real difference in gas consumption. I'm sure you've thought of this, but you didn't mention that part, so I thought I'd ask.
    btw, have you ever measured a mileage difference due to using a high powered stereo system? :cool:
  4. oldasdust
    oldasdust Member
    356
    47
    illinois
    Years ago on a non hybrid vehicle i switched from 15's to 17's and had a similar reduction in mpg. A slightly different note, on my other non hybrid vehicle with LRR tires i have improved mpg using techniques learned from driving my Prius.
  5. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    Hyo, :)
    I 'veruled out more agressive driving because when I am testing the tire's mpg capability, I try to employ the same techniques on both tires. If I really try hard I can achieve 46mpg with the 17s and 55mpg with the 15s. This is based on my normal commute with a 1,200 ft. elevation gain.
    The17s are a bit taller and thus make my speedo more accurate. The speedo with oem sized tires is 18 1.5 to 2 mph too fast. So the 17s are likely giving me better mpg than is reported so I shave a couple mpg from the difference when I tell people to expect a real mpg drop of 4-6mpg when they upgrade wheel size. If I just took everything at face value I would say I see a 9 mpg difference. Due to speedo inaccuracies and tire diameter difference we know this is not a true value. With the 15s i'm traveling at 2 mph slower than when I have the 17s on. This assumes I am using the speedo as my guide and not trying to adjust for the 2 mph error with the 15s. Does this make sense? I have a low grade fever so I may just be mumbling rubish. lol
  6. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    That is the beauty of hypermiling, it works with any vehicle. :)
    P.S I apologize for spelling errors. I post mainly from my cell phone and it likes to auto correct what I type and I don't notice.
  7. oldasdust
    oldasdust Member
    356
    47
    illinois
    Yes F8L it is great with any vehicle and it took a Prius ,to teach an old dog like me, a few new tricks.
  8. SageBrush
    SageBrush Senior Member
    11,627
    2,532
    Southwest Colorado
    One trip of data is not enough, my febrile friend.
    Three or four days a week I drive ~ 25 miles one way to work at speeds mostly 50 - 60 mph, and a decline of I think 300 feet. Since temps have cooled down and AC is off, I average about 68 - 70 mpg, but twice in the past month have hit just over 80 mpg.
  9. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Interesting info F8L. I wonder exactly what part of the bigger tires it is that causes the MPG loss. Is it the lower profile? Is it the fact that they're wider? Or is it merely that the construction is not optimized for LRR?
    From what I've read there doesn't seem to much in the way of noticeable MPG difference between the same model LRR tires in 185/65/15 and 195/60/15. So I wonder what it is that makes 17" tires so noticeably different.
  10. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    from what i've seen.. they make a huge difference. i say huge because the cap with 17's on a genII tends to be in the high 40's.. (for me).. while with 15's i used to be able to get into the 50's...
    the one oddity i've seen: when i was towing long distance... basically up to semi valley and back to culver city (roughly)... i was getting 48mpg... (steal 5x8 trailer loaded 4 ft high with pipe insulation.)
    as a reference back to Hyo, when i was running my sub turned up all the way and blasting the stereo (till eventually the cone ripped on my sub)... i was getting a good 5mpg less then i'm getting now. but there could be a lot of things involved in that (i drive a little less aggressive at times now)
    going back a few years... aggressive driving with 15's never made me less than 42mpg... now my low is 38mpg... i could blame that on needing a throttle body cleaning and such... or the point that i'm always making shorter commutes than i used to make... shrug... idk
  11. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    Did you miss the part where I said I do this test multiple times a year? : p I've been playing with these tests since 2006 and I always get the same results but as time goes by and I learn to drive better, the result is a wider gap in mpg difference. The higher friction with the 17s just makes it harder to hypermile effectively.
    And I thumb my nose at you for getting such great gas mileage. lol
  12. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    I think it is a combination of weight and extra tire width. The 17" tires are approx 4-5 lbs heavier. Tire width changes quite a bit too since most people go from a 185/65/15 to a 215/45/17. My tires on both sets of wheels are LRR rated but due to these other factors you can really feel the rolling resistance difference. The 15s glide much farther and easier.
  13. SageBrush
    11,627
    2,532
    Southwest Colorado
    LOL, yeah, I missed the repeat testing part. Apologies for doubting your scientific approach :p
    I hope Qbee ventures an opinion, since the physics of weight changes in tyres frankly eludes me. I know bicyclists moan and groan over extra grams in their tyres. Certainly the tyre width plays a part in extra friction -- the overall tyre friction between two tyres that only differ by widths should be proportional to the ratio of the widths. Tyre friction is going to be most apparent right where you are testing: not fast enough for air friction to account for the lion's share of friction, and not in the city where brake use dominates mpg.
    I know you can read the tyre spec format (I keep forgetting), so what is the ratio between your 17 and 15 inch tyre widths ?
  14. SageBrush
    11,627
    2,532
    Southwest Colorado
    OK, if I read correctly the first number is the cross-sectional width, so 215 mm for the 17 inch tyres and 185 mm for the 15 inchers.
    215/185 = 16% !!
    According to Wayne Brown, half of the friction at 60 mph is not air, and we know that the drivetrain uses about 3% of the energy to move the wheels at that speed, so tyres account for 40 - 45% of energy losses. 40 - 45% of 16% = 6.4 - 7.2%.
    So just the width difference will drop 64 mpg to 59 mpg.
  15. hyo silver
    hyo silver Awaaaaay
    15,260
    1,598
    off into the sunset
    So, part of it is a measurement difference. It's reasonable to 'knock off a few mpg', but this isn't scientifically accurate. Is there a better way to do the testing? A scangauge may not work, because it still uses wheel input. Could a gps be used, along with precise measuring of the gas consumed?
    I've teased F8L before about having a ten horsepower stereo. ;) I'm curious to know if there's a real difference. Part of it may well be the fact that driving aggression seems to match the music. The same seems to be true of caffeine levels, too. :)
    Each? Meaning 20 lbs heavier for the set of four?
    I've noticed a gliding difference just with tire pressures. With this car and the driving techniques typically used, the gliding is bound to make a big difference - it's not just accelerating the higher rotating weight up to speed.
    Definitely. When you're supplying all the hp (human power), the differences are very noticeable. My mountain bike has big knobbies on it that sound like 4x4 truck tires on pavement. Off-road, it's obvious they're designed for traction in dirt, and that's where they come into their own, but on-road, they're painfully slow. On the road bike, I have to balance lightness with durability. Having a super light tire blow or puncture doesn't save any time or effort, and becomes a significant risk in traffic or on high speed downhills. Wet traction and cornering profiles are also important considerations, in addition to weight.
  16. V8Cobrakid
    3,790
    152
    someone did a test on here that calculated hp used to sustain at a certain speed.. for the 15's it was somewhere around 12hp... but for the 17's it required almost 20hp to maintain the same speed.
    sage... you're right. the first number is the width of the tire in mm... people don't realize how much of a difference that much more tire can make.
  17. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    Sage, thanks for doing the math. :)
    The extra width is likely the culprit for much of the actual loss. The perceptual loss associated with speedo changes and lower revs per.mile account for the extra loss beyond what can easily be teased out with math. We must also account for aerodynamics because the wider tire will increase air friction at higher speeds which accounts for 90% of my driving.
    Hyo, the wheels weigh about the same as the oem 15s. I think they are 1 lb heavier so the total weight gain is approx 24lbs of extra rotational mass. I'm sure the stereo creates a loss of mpg but when I am testing for mpg I just turn it off.
    The mpg I knock off due to speedo change and diameter difference is a lazy way of determining what someone will lose when they upgrade their wheels. I know it is not scientifically sound but because wheels and tires vary so much I don't think it matters much. :)
    Vcobrakid8, I have observed exactly the same measurements on the scangauge that you mentioned. It takes much less HP to maintain speed with the 17s than it does with the 15s. The numbers are close to those you posted.
  18. SageBrush
    11,627
    2,532
    Southwest Colorado
    Here I think is a bit more accurate math analysis of increased friction from a wider tyre, again using Wayne Browns overall energy consumption and aero contribution results, and knowing that a 215 mm tyre has 16% more ground contact than a 185 tyre just from the width (ignoring increased ground contact from weight):
    At 60 mph, 215 wh/mile using 15 inch tyres,
    air accounts for 102 wh and non-air is 112 wh.
    4 wh used by the drivetrain, so 108 wh by the 185 mm tyres,
    and 108*1.16 = 125 wh by the 215 mm tyres.
    Adding everything back up, (102+4+125)/(102+4+108) = 1.079439252
    8% hit in fuel economy, so a 64 mpg on thinner tyres becomes 59 mpg on the wider version.
  19. SageBrush
    11,627
    2,532
    Southwest Colorado
    I wonder if this testing was at constant low speeds where tyre friction becomes a larger fraction of total friction losses
    Addendum -- Nah, that does not make sense. The limit should be 16% more fuel/distance from width considerations only.
  20. SageBrush
    11,627
    2,532
    Southwest Colorado
    F8L, perhaps you can measure longitudinal ground contact of your two sets of tyres ? Part of the answer here is additional work involved in tyre deformation as it rotates.
    One other thought: what does LRR mean, anyway ? If it is a measure of compound, then tread differences are not taken into account. I would not be surprised if 17 inch tyres are designed to have better grip than smaller tyres since they appeal to the 'performance' crowd.
